Question about GE Spectra JGBP30 Gas Kitchen Range
Burner flame adjustment
When the right front burner is adjusted to "LO" the flame goes out. how do i adjust the flame height to coincide with the burner adjustment?.
  • 3 more comments
  • uncelchuck Aug 30, 2007
    i need to go to the range burner service place to get a narrow enough adjustment tool to fit inside of the knob shaft.
    thanks
  • Anonymous Mar 13, 2014
    the flame is burning yellow how do I adjust the flame.
  • Anonymous Mar 14, 2014
    replaced the oriface holder and burners. burner LOW setting was adjusted so flame would not go out. Stove MDL 3468vvv
  • Anonymous Mar 27, 2014
    Yellow flame
  • Anonymous Mar 28, 2014
    the flame is irregular and yellow and "wavy" rather than crisp edges. also turns the pans black on the bottom.
  • 625 Answers
There are two considerations for burner height. 1) the gas adjustment screw on the knob and 2) the gas-air mixture to the burner. establish a flame and adjust the screw for a standing flame at the burner. adjust the gas-air ratio orifice so that the flame has no yellow tips.
Posted on Aug 30, 2007
Unclechuck,
My problem is How do I adjust the burner in the oven to blue flames on a GE propane gas range?
Posted on Oct 10, 2008
  • Jack2728 Oct 08, 2010
    This is a simple fix. You will need a flashlight and a flat blade screwdriver small enough to fit into the burner knob shaft and extend to the adjustment screw inside it.
    Pull the knob off the knob shaft for the problem burner. Use the flashlight so you can see the orientation of the screw head slot inside the shaft. Insert your screwdriver and turn it to the left about a 1/2 turn. Remove the screwdriver, put the knob back on and turn on the burner, then adjust the burner to the lowest setting - it should stay on. If the flame is too high now on the lowest setting, pull the knob off with the burner still on and use the screwdriver to adjust the flame until you are happy with it. Use small, incremental adjustments, as it will be fairly sensitive to the changes you make.
    New Friend:
How do I adjust the flame on a GE PGP - Instruction from GE says to adjust with a screw that is under the on-off knob === there is no screw of any type under any of the knobs.
Flame is to how boils on low??
thanks
Posted on Jul 31, 2011
SOURCE:
Control knob doesnt adjust flame height?
Use a manometer to insure lp gas pressure is correct. The regulator for the stove may need adjusting. The air mixture adjustment may not be correct for PL as well.
Aug 18, 2014 | DCS Professional RDU305N 30" Pro-Style...
Pilot light flame too loeeds adjustment
Adjust the pilot flame height using the adjustment screw for each burner.
Mar 12, 2014 | Magic Chef Ovens
Orifices burner flame adjusted
Most burners have an adjustment under the knob. Pull off the knob and use a slender flathead screwdriver. Turn burner down to low, insert screwdriver into knob shaft and rotate internal screw until flame is at "simmer" height. Can adjust each burner separately this way.
Jan 17, 2014 | Kenmore 71042 / 71044 Gas Kitchen Range
Gas fireplace manuals
There are two things that control flame height gas volume and air volume. Some fireplaces have a flame control knob on the gas valvd to adjust flame height. Air volume is controlled by an air shutter usually located where the main gas orifice enters the burner. There is usually a small cover that will need to be removed to access the shutter. Closing the shutter will cause the flames to become taller and more yellow colored. Closing the shutter too far will cause sooting problems so great care should be taken in adjusting this shutter.As a rule, L.P. gas fireplaces do not have as high of a flame as natural gas unit do.
Hope this helps
Dec 14, 2013 | Heating & Cooling
Kitchenaid stove burner
You need a new gas valve for that burner
Nov 10, 2013 | Kitchen Ranges
Adjusting front (most powerful) burner on kitchenaid (Left front)
There is an air port near the adjustment knob. Open for a more blue flame and close for a yellow flame. If these haven't been moved before, you probably have a clogged jet at the burner. Just clean it out with a pin.
Feb 04, 2012 | KitchenAid Blenders
Gas fire place flame to low, do you have a schematic to increase the flame ?
Generally, whether it's a Vent-free or Vented fireplace, lower than normal flame height is caused by 3 things: Low Gas pressure; The air shutter control valve is clogged or needs adjusting; The burners need cleaning.
I haven't seen a unit in the past 10 years, that has a flame height adjustment, other the flame height control knob, that's part of the control assembly. Have you checked that, to see what height it's turned to low?
Perhaps, if I knew who the manufacturer was and the model number, I could be of more help to you.
Mar 15, 2011 | Honeywell Heating & Cooling
Flame burns too high t0 simmer
if you look closely, down the center of the knob ther should be an adjustment screw to lowert he flame
Jan 26, 2009 | Amana AKS3040 Gas Cooktop
Burner flame height adjustment
All ignitors will always arc whenever one of them does.
I haven't worked with propane systems much, but it seems you may need the propane pressure regulator adjusted.
If the problem is only with the power burner, I would ensure that particular orifice was actually changed. The hole in a propane orifice is smaller than for natural gas.
Jan 08, 2008 | Kenmore 78812 / 78814 / 78819 Gas Kitchen...
Kenmore 32099 Cooktop burners regulation
remove the burners and adjust the air ration with the slide at the bottom of the burner tube
Jul 25, 2007 | Kenmore 30 in.32099 / 32094 / 32092 Gas...
Open Questions:
See all GE Spectra JGBP30 Gas Kitchen Range Questions
GE Spectra JGBP30 Gas Kitchen Range Logo
6,864 people viewed this question
Top Kitchen Ranges Experts
Ismael Rodriguez...
Steve Allison
Steve Allison
Craig Butler
Craig Butler
Are you a Kitchen Range Expert? Answer questions, earn points and help others
