Question about Whirlpool Dryers
I have a Whirlpool duet steam dryer/ WED9470WW1 it turns itself off and flashes F70 What is the problem
Dryer turns off and flashes F 70 what is the problem?
  • 36 Answers
SOURCE: Whirlpool Duet Dryer WED9600 Beeping during drying
Dear Customer
Please perform the following
please rate this,thank u
Posted on Dec 16, 2008
jsrock516
  • 5911 Answers
SOURCE: I have Whirlpool Duet Dryer that has a noise.
It is common for small items (such as coins) to get stuck inside the dryer drum baffles. You can easily remove them without disassembling the entire dryer. The screws that hold them in place are located on the outside of the dryer drum. In order to access, follow these steps:
1. Unplug the dryer.
2. Remove the top panel of the dryer by removing the three screws located in the back of the dryer holding the panel in place. Once the screws are removed, the top panel slides back, then lifts off.
Each drum baffle has two screws holding it in place. Remove the screws and the baffle will drop into the drum allowing you to easily check inside each one.
Another source of dryer noise is something caught in the blower fan housing. You will need to remove the lower toe panel directly below the dryer door to access. Follow these steps:
1. Open the dryer door and remove the lint screen (the blower fan cover will not come off with the lint screen in place).
2. Locate the screws that hold the toe panel in place along the bottom front edge of the panel. HINT: Propping the front feet of the dryer up can give you better access to reach the screws (a 2x4 works well for this). With the screws removed the toe panel will drop down, then come off.
3. Remove the screws that hold the blower fan cover in place.
Inspect the blower fan housing for any objects that may be vibrating against the fan blades.
If you still need further assistance, please let me know. I hope you find this helpful.
Posted on Sep 01, 2009
jsrock516
  • 5911 Answers
SOURCE: My whirlpool dryer (Duet) will not heat. What
If your dryer runs, but does not heat, the following link explains how to troubleshoot an ELECTRIC dryer with a no heat problem:
http://www.fixya.com/support/r3576548-dryer_runs_but_does_not_heat
First, begin by unplugging the dryer and verifying the voltage at the wall receptacle. You should read 220-240VAC across the two Hot terminals (left and right slots). If the voltage is incorrect, check to make sure you don't have a breaker tripped. Some homes use 2 separate 120VAC breakers to provide power to the receptacle vice using one 240VAC breaker.
If the voltage IS correct, leave the dryer unplugged and remove the cover plate on the terminal block in the back of the dryer (this is where the power cord is installed). Plug the dryer back in and take a voltage reading across the two hot (RED and BLACK) wires at the terminal block. You should read 220-240VAC. If the voltage is good, you have an internal heating problem. If the voltage is bad at the terminal block, but good at the receptacle, you have a bad power cord.
NOTE: If the wires at the terminal block are not color coded, the outer two wires (left and right) are the hot leads. The center conductor is neutral or ground.
The reason a dryer will still run if the input voltage is incorrect, is because the drive motor only uses a portion of the 220 service. The motor runs off 110-120VAC, while the heating circuits require 220-240VAC. So, if you are missing 1/2 your input voltage due to a tripped breaker or bad power cord, your dryer may exhibit these symptoms.
If you determine the problem to be internal, the heating circuits will either be located in the rear of the dryer on the right hand, or under the dryer drum on the right hand side. Usually, an easy way to determine is by the location of the lint screen filter. If the filter is on top of the dryer, the heating circuits are in the back of the dryer. If the lint screen is in the door, the heating circuits are located under the dryer drum.
The Heating Element is located inside a heater box. The Thermal Cut-Out (TCO) will be located on the outside of the heater box on the end opposite the heating element terminals. The Hi-Limit Thermostat will be located adjacent to the heating element terminals.
If either the TCO or Hi-Limit Thermostat are determined to be bad, replace BOTH components at the same time. That is why these components are commonly sold as a set. Failure to do so may result in premature failure of any parts you replace.
Replacement parts can be found at appliancepartspros.com, searspartsdirect.com, pcappliancerepair.com, or repairclinic.com. The average cost of these components varies, so shop and compare.
If you need further assistance, please post back and let me know. I hope you find this information helpful.
Posted on Dec 23, 2009
SOURCE: Error code E6 on a Whirlpool Duet Dryer
Whirlpool Duet electric dryer only dries clothes on heavy duty selection. what is wrong?
Posted on Jan 19, 2010
Jahn27
  • 1554 Answers
SOURCE: What does code F70 and F71 mean on my whirlpool duet?
Error code F70 means no communication is detected from the Central Control Unit (CCU) to the User Interface while F71 is the reverse; no communication detected from the User Interface to the Central Control Unit (CCU). This could simply mean a loose or poor connection between the two communicating boards.
Disconnect power to the washer prior to servicing to avoid the risk of electric shock.
Remove the three screws attaching the top panel to the rear of the washer then slide the panel rearward and lift it off the washer.
Disconnect the User Interface ribbon connector from the left side of the Central Control Unit (CCU) and clean the connector and terminals thoroughly. Reseat the connector several times to ensure a good connection between the Central Control Unit (CCU) and the User Interface.
It is highly recommended to clean and reseat every wiring harness connector from the Central Control Unit (CCU) to prevent the same problem in the near future.
Reconnect every wiring harness to the CCU and make sure all connectors are firmly seated. Slide the top panel back into position and secure it to the rear of the washer with the screws previously removed.
Let us know if the problem persists for further assistance. We will be happy to resolve your problem.
Posted on Mar 19, 2010
How can I get my dryer running?
You need a new machine control board
Oct 02, 2016 | Whirlpool Dryers
Can you stack this washer and dryer?
You can stack, will you be able to reach. Racks can be made to stack any normal washer and dryer.
Mar 14, 2016 | Whirlpool WFW9750WW Duet Steam Front Load...
On Whirlpool duet steam front loading DRYER...What does the error code F70 mean?Do you have to have a certified whirlpool appliance service professional to repair?
F70 code says...
Replace the machine control electronics. You should first unplug the machine and then remove and plug back in all connectors on the front panel model as well as the electronic control module.
If that doesn't take care of the problem then it may be time to consider replacing the rear board. The FSP # 8183259
The control board is part # 14 in the link below.
Sears parts direct /Whirlpool-Parts/Model-WFW9400VE01
Mar 13, 2015 | Whirlpool Washing Machines
Dryer displays F 70 code. How do I get it to stop?
Unplug the dryer for 30 minutes. Then reconnect the power cord to the outlet. This will reset the code temporarily. Unfortunately, the code means that the central control unit (clock) isn't communicating with the rest of the components correctly. You probably will need a new clock or dryer (depending on the warranty status). If the unit is under warranty, contact Whirlpool or the store where you bought the dryer (if it is brand new).
I wish that I had better news for you.
Jun 05, 2013 | Whirlpool Duet Steam WED9500TW 7.2 Cu. Ft....
F 70
What is the model number?
Nov 21, 2012 | Whirlpool Dryers
F70 was displayed on Whirlpool duet dryer what does F 70 mean
Isnt F70, really is F07... this means Motor Control Unit Error
Description: The Central Control Unit has detected a short in the motor control unit. If a failure occurs during high-speed spin, the door will be unlocked after 3 minutes.
Check or Repais:
- Check wire harness connections between the Drive Motor and the Motor Control Unit (MCU), and between the MCU and the Central Control Unit (CCU)
- Check the MCU
- Check the Drive Motor
- Check the Wire Harness
Hope helps.
Aug 22, 2011 | Whirlpool Duet GHW9150P Front Load Washer
My dryer shows F 70 on the panel
For a Whirlpool dryer F70 is an electronic control issue. It can be as simple as the wire came loose off the control in the top console or as complex as both control board and console electronics have failed. Here is what the manufacture says:
F:70
F:71
No
Communication
Between
Electronic
Assemblies
F:70 / F:71 flashes when there is no communication between
the machine control and the console electronics.
■ Check console electronics harness connections to the
machine control.
■ Replace the machine control electronics.
Apr 23, 2010 | Whirlpool Dryers
Same problem but I have a 3 week old maytag 9000 steam dryer, ran for a few minutes then turns off and display reads F 70
From everything I have read on the F70 code (can't seem to find an exact explanation of what it is) It seems like people are getting replacement dryers due to a electrical problem within the dryer control circuitry. Since it is only 3 weeks old, get it replaced. Good luck
Feb 02, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool duet gas dryer
Call your warranty service,thats what its for.
May 21, 2008 | Whirlpool Dryers
Dryers Logo
110 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
