Question about Air Tools & Compressors
Graco airless super nova 700 paint sprayer - Air Tools & Compressors
  • 256 Answers
SOURCE: DECLOGGING DRIED PAINT VEINS IN MANIFOLD
You can't hurt it any more than it is, so I would try a liquid paint remover/stripper and let the metal parts soak over night. I'd be more careful with the plastic parts. Poke in the holes with a fine wire (paper clip) or pin. About the service manual, use a search engine (Dogpile, google) and search the web.
Posted on Jun 01, 2009
  • 20 Answers
SOURCE: where can i find a instruction manual for a wagner
Goto http://www.wagnerspraytech.com and click on "sprayers" and select your model. If not listed goto "customer service" then "discontinued product manuals".
Posted on Oct 14, 2009
  • 98 Answers
SOURCE: Bought anCampbell Hausfeld airless paint sprayer,
no fluid gets to nozzle or comes from nozzle.
sounds like your fluid line is pluged or the gun is pluged at or before the tip
Posted on Feb 21, 2010
  • 98 Answers
SOURCE: need to repack pump on graco gm5000 gas paint sprayer
http://www.graco.com/
you can put your model in or if you have a part # you can enter it into one of the fields eventually you will fing a parts diagram for your unit.
  • 885 Answers
SOURCE: Airless sprayer, paint comes out like silly string
In order of ease/cost to fix: First, check your spray tip. Most of them are reversible to help spray out any debris that may be lodged in them. Next, check that all of your filters are clear and let paint flow freely. Depending on your model there are up to three, one filter in the spray gun, usually in the handle, another filter is at the pickup tube and some sprayers also have another filter on the machine where the hose hooks up. Another cause may be because your paint is way too thick or not mixed well. A highly recommended paint additive for airless sprayers is Floetrol, it makes the paint flow extremely well. If none of these fix your problem you may well have a worn packing or diaphragm, again depending on your model, and the machine isn't developing enough pressure to atomize the paint. If you have the means put a pressure guage in line with the hose at the machine and turn it on. You need at least 1200 to 1800 psi for most latex paints, a little higher for enamels and thicker paints.
Posted on Dec 17, 2010
A graco ultra nova 395 stand model airless paint sprayer Will packing go bad after sitting an extended period of time ? It is not a tool I use very often but I do like to have a quality tool ready
yes
the gland packing will go hard from the paint contamination ( even though you washed the unit properly)
the secret is to get spares now before they become hard to get
talk with paint shops as there may be something you can spray through the system to keep the packing and seals supple
Jan 03, 2017 | Graco Air Tools & Compressors
Graco XR7 motor won't run. Worked fine then quit. Now hums barely
Feel free to contact Graco Techinical Support at http://www.graco.com/us/en/customer-care/technical-support.html
Mar 19, 2016 | GRACO INC Magnum Pro X7 Airless Paint...
I would like to know where to find the diagram for a graco nova model #390 pump
I have a copy of the parts manual for you, but its not a video or a photo, so I will try to send it as a photo.
Tried this but Fixya doesn't like it, so I will ask them how to send it, or you can send me an email and I can send it back to you.
Please keep by email address confidential:
david.dundas1@gmail.com
Mar 07, 2015 | GRACO INC 390 Stand Airless Paint Sprayer
390 graco airless spray painter manual
Go to Graco's website at www.graco.com/us/en.html. Under the customer Care tab you can look for Instruction Manuals. Search on your model number and you'll get a list of files that refer to your model. Usually the manual and/or parts breakdown are in the first two or three files.
Aug 20, 2012 | GRACO INC 390 Airless Paint Sprayer 253958
Graco Magnum XR5 electric airless sprayer won't start
It could be something as simple as you have the pressure turned down so low it won't appear to be working try to turn the pressure up and see what happens.
The worst thing could be you did not clean the sprayer out properly and now the paint has dried and the shaft is frozen to the packings and the other internal parts of the your sprayer.
Jun 27, 2012 | GRACO INC Magnum XR5 232740 Paint Sprayer
Graco magnum paint sprayer won't prime
Airless won't prime- I always start trouble shooting an Airless that won't build/hold pressure look at sump hose inlet filter (the hose that goes into the paint if its got paint debris on it clean off filter and pour the paint thru a strainer bag into a clean 5 gal bucket-also remove the filter housing on the spayer and clean and flush and replace filter and housing- the shaft or the metal sleave has two ball bearings called "check balls" that maybe stuck turn on sprayer and put a piece of wood on shaft and give it a few good taps this will knock the check balls loose if after all this fails then you need to have new packings put in becuase the old ones are worn this is pretty easy to see because the rod the compresses the paint will have signs of paint on it indicating that the packings are worn.. Note keep rod and other moving parts oiled ith graco throat seal and finally Graco sprayers with the X on them are there (Graco) home owner line of sprayers that sell at home depot they are rated for only a certain amount of Gal per year keep it in good condition and cleaned store with coro-check inside of the pump when you are done using it.....
May 27, 2012 | GRACO INC 232745 Magnum XR-7 3/4-HP...
Spraying kitchen cabinet doors 40 degree weather airless graco sprayer enamel water base paint at first finish is great then bubbles start to form
first problem is the waterbase paints ( ****) the other is how did you mix your paint , you cam trap air in the paint if you padle or stired it without a shaker mixer air will gas out of the paint, tofix this use a foam brush to flaten air bubbles
Jan 23, 2011 | Air Tools & Compressors
Air Tools & Compressors Logo
228 people viewed this question
Top Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
