Question about J.Crew Timex Andros watch
Timex Andros Set the day of the week
How do I change the day of the week on the Timex Andros watch that you can purchase at JCrew?
Setting timex analog mens watch with small window in face of watch indicating day of week, I think
Lots of older watches needed to have the hands advanced 24 hours to advance the date one day. Fortunately most modern watches require the hands to be wound backwards to advance the date, often at the rate of a day per hour. A combination of the backward and forward winding of the hands made adjusting the day and date much simpler and quicker.
A few premium watches had a third position when pulling out the winder, a position dedicated to adjusting the day/date
Jun 16, 2016 | Timex Watches
Cannot set month and day of week
If It's digital, follow this link. If Analog, pull the crown half way out to move the day and month. How to Set Timex Expedition
May 05, 2016 | Timex Watches
How to set the day on the timex, as i am able to set the date but i dont know how to set the day of the week in T46601-V1 model watch
it can only set by turning the time for 24 hour using the crown the day of the week changes every 3 AM, i hope i had helped you.
Sep 10, 2011 | Timex Expedition T46601 Watch
Where do I find a user manual for a Timex Expedition (H2Y518)? I had Timex install a new battery and although the date 3-17 is correct, the day of the week is SUN. I have tried changing the date for over...
You are very observant! Timex watches don't have a way to adjust the day.
However, if you turn the hands clockwise you will see the day advance.
So, heres the secret, follow exactly:
1. Turn the hands until the day of the week shows the day before. If today is Wednesday then turn the hands until the watch shows Tuesday
2 Adjust the date to the day before. If today is the 17th then adjust it to the 16th
3. Now pull the crown all the out and and advance the hands until the date changes to the correct date, 17 in this example. This happens at midnight. Continue the movement in a clockwise direction for a few more hours and you should see the day change to the correct day.
4. Now continue to move in a clockwise direction until you have the current time. Remember that your date/day changed at midnight so if the current time is after lunch(noon) you must continue past noon to get to the correct time. If you don't do this correctly your date will change every day at noon instead of midnight.
If you don't succeed the first time, try, try again! Good luck, Michael, Watchmaker to the Stars!
Mar 17, 2011 | Timex Watches
How do I change the day on my Timex WR30M Easyreader Indiglo watch. I can change the date, but not the day of the week. Help....
When you bought the watch, did you find a little manual in the packaging? The manual has all the info.
Dec 19, 2010 | Timex 27191 Wristwatch
How is the day of the week changed in a TIMEX Traditional analog watch. Pulling the stem out half way and rotating will only change the date. Rotating the time through multiple 24 hour periods will work,...
Setting the date is covered in the instructions which you can get instructions from the Timex web site "timex.com".
At the bottom of the screen click on "manuals/downloads", then on "product
manual download"
Enter your watch type in the search box and click on "search"
Mar 15, 2010 | Timex Expedition47761 Wristwatch
Change day but not date on Timex Expedition
HI..
HERE IS STEPS FOR SETTING OF YOUR WATCH... STEP3 EXPLAINS THE SETTING OF DAY,DATE.....
  • Step 1 Push in the lower right button until you see the seconds flash. Press the upper right button to run the seconds display down to zero. Push the bottom left button to get into the mode to set the hours. Press the top right button to scroll through the numbers. Watch that you choose a.m. or p.m. correctly.
  • Step 2 Press the bottom left button to get into the mode to set the minutes. Again, push the top right button to scroll through the numbers until you reach the correct time.
  • Step 3 Repeat the process from Step 2 four times to set the month, date and day of the week and to change to military time if you wish. Push the bottom right button to save your settings. You'll notice the colon between the numbers will start to flash.
  • THANK YOU
  • Jul 28, 2009 | Timex Expedition Outdoor Athletics Watch...
    Day of the week
    Switch the watch into 24 hour mode - should be a simple task - while in normal time mode, press one of the buttons other than light, mode or set button - which I'm guessing leaves only one.
    I'm guessing that the watch does not show am / pm?
    By putting in 24 hour mode, should be easy to get the right day at midnight changeover.
    Hope this helps.
    Jun 12, 2009 | Timex 1440 53591 Sports Quotient...
    J.Crew Timex Andros watch Logo
    90 people viewed this question
    Top J.Crew Watches Experts
    Ansel Alberto
    Ansel Alberto
    Are you a J.Crew Watch Expert? Answer questions, earn points and help others
