Question about Hoshizaki Kitchen Appliances - Others
Water pressure regulator
Leaking
  • Hoshizaki Master
  • 1,253 Answers
Need model and serial numbers. I am assuming it is water cooled.(?) let me know more and we can try to fix
Posted on Aug 14, 2014
RANDOM leaking from top back of toilet when refilling water after flushing.
sounds like regulator set for too much water to refill turn screw on reg to close aperture to trickle of water after flushing and adjust accordingly for flow of water to just fill level or just below regulator
Mar 22, 2015 | Cars & Trucks
Leaking water
Check pressure gage on furnice,when cool about 15psi, when up to temp. no more that 20 psi. If at 20psi when cool, reduce pressure at water pressure regulator.(wattsreg.com shows how) Replace vent by shutting off power to furn. shut off water supply line, drain water from boiler until pressure reduced. use teflon tape on thread before installin
Sep 24, 2013 | Taco Inc. 400 Hy-Vent 1/8" NPT Yes 150...
Leaking hot water heater
If it is older than 15 - 20 years and leaking on the floor under the tank, purchase and install a new appliance, If the T&P valve is leaking, change the valve. If it still leaks, replace the expansion tank which should on the supply water line. Try not to install an expansion tank "on its side". BEFORE YOU DO ANYTHING, make certain your incoming water pressure does not exceed 65 -70 psi. This could be the real problem. If so, install a new water pressure regulator. It is usually located inside the basement wall. In a Garden Home, it may be outside at the curb in the ground by the water meter. It may be in the ground buried near the entry through the foundation. It may be near the water heater.
Feb 02, 2013 | Water Heaters
Vacuum valve leaking water
Question is unclear.
What is a vacuum valve?
You posted under electric water heater.
Water heaters are associated with TP or 'safety overflow' valve, water shut-off valve, tank drain valve, pressure-regulating valve, mixing valve and possibly a few other plumbing valves.
Vacuum valve implies that a compressor is creating pressure on one line while creating vacuum on another line. I don't know of a water heater that uses air compressor.
Open following link to help troubleshoot leaking water heater:
http://waterheatertimer.org/Leaking-water-heater.html
Jul 23, 2011 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
Low Pressure
I worked at a tool rental while attending college and had the opportunity to work on a variety of pressure washers, however, they were of the commercial type. Commercial washers are slightly different in that they usually have seperated components for easier service. Attached to the pump by fittings or rubber hose were the pressure regulator (which has the bypass unloader inside), chemical injector, pressure gauge as well as the hot water release safety all external to pump. Your pump has all these components in one case. By far the most troublesome component is the pressure regulator/unloader which when failing will result in low pressure because it will bypass water back into the intake as you suspect is happening to yours. Here are a few things to check. I believe that your pump is 2500 2.4 gpm. Test gpm water capacity by running pump normally with hose and proper tip attached. Spray water into bucket for one minute and verify that you are pumping 2.4 gallons of water (or what ever gpm your machine is rated). Measure the amount of water that your machine delivered. If it delivered proper gpm and pressure is low then problem could be worn or improper tip. The pressure is created at the tip and pressure will drop as the tip wears. As the unloader/bypass wears, water will bypass at a lower pressure. (Try lowering the pressure regulator all the way ) If water measures less than rated delivery than the machine is bypassing water due to worn regulator/bypass, checkvalves pitted, oring in front of checkvalve worn or cut or missing, or body of pump where checkvalve/oring seat is pitted allowing water to leak past valve. The cap that is removed to access checkvalve must presses against checkvalve with enough force to prevent water from leaking thru oring and body of pump. Examine checkvalves and orings with maginfy lens and look for pitting. Valves surface and orings must be very smooth and tight fitting to work properly. Body of pump where checkvalve oring snuggs against must be very smooth. Any surface where oring seats must be smooth. As water bypasses it cuts metal and orings just like a leaking faucet so look for cuts in metal and rubber. This info and my experience is better suited for larger pumps and higher pressure but maybe it will help. Good luck with your repair.
Jul 11, 2010 | Karcher 2500 PSI Pressure Washer
Leaking fuel pressure regulator
Release fuel pressure by removing fuel pump relay and turning engine over to release pressure. Place a rag to catch any fuel under regulator Fuel pressure regulator has a locking clip pry clip off remove vacuum line pull regulator out with twisting motion,replace fuel pressure regulator install clip connect vacuum line install relay. Check for leaks,your done.
Feb 23, 2010 | 2001 Pontiac Grand Am SE
Where would I get an inline pressure regulator for my refrigerator. My refrigerator model #FRS23K5CQ2 started leaking out of my icemaker cartridge compartment into my front door shelf. one of the solutions...
I have had the same problem, and can't fix it at the refrigerator. You need an presure reglator or bladder on your hot water heater. when you have to much pressure it usually starts causeing problems at the hot water heater with leaks and works its way down in other areas of the house. We put a regulator at our water meter at first and it did not help.. if it is leaking at your fidge, you may want to check other appliances.
Hope this helps
Mar 30, 2017 | Frigidaire FRS3R5EMB Side by Side...
Karcher G 3050 OH the pressure is not constant, I think that is the pumps pressure regulator but I'm not sure
Check the suction line for leaks. It needs constant water
supply to build a constant water pressure. You may also
check the pressure regulator for leaks. You may also
check the carbide or ceramic pistons for breaks. Send you e-mail for further assistance.
Sep 06, 2009 | Karcher G2500PHR Factory Refurbished 2,500...
Open Questions:
Kitchen Appliances - Others Logo
44 people viewed this question
Top Hoshizaki Kitchen Appliances - Others Experts
Dennis Boxerman
Mike Squire
Are you a Hoshizaki Kitchen Appliances - Other Expert? Answer questions, earn points and help others
