Wont spin burning smell
SOURCE: Maytag top loader washer
The brakes are probably stuck or the cam that releases them is damaged
Posted on Sep 27, 2007
SOURCE: Maytag Washer will not spin
Pull the unit forwardand lean it back about 45 degrees. You'll have to play with it a bit, but once it's far enough out, it will lean back without you having to hold it. Remove and inspect the belt(s) are they in good condition? Next, check the pulleys (wheels) underneath. Do they turn? One is for your pump, one is for your transmission and one is for the motor. (in case one doesn't turn, you'll know what portion needs to be worked on). Also check the track on your pulley the belt sits in. Is it dammaged or worn?
Posted on Jun 16, 2008
SOURCE: Front load washer doesn't spin
My Maytag® Neptune® washer filled with water, but it won't spin or drain-what now?
Start by making sure the machine is plugged into a live (working)
electrical outlet. Then check the appropriate circuit breaker and reset
it if necessary (or check the fuse if you have a fuse box).
Next, inspect the drain hoses and remove any kinks. Take a look at the
drain, too - if it's clogged, call your usual drain service person.
Then close the washer door and firmly press the START/STOP button. In a
few moments, after the door locks, the washer should begin to spin.
(For your safety, the washer will not tumble or spin unless the door is
closed and locked.)
If this doesn't work, please contact Customer Service at 1-800-688-9900
for toll-free assistance and service scheduling if necessary.
Posted on Oct 04, 2008
SOURCE: maytag washer stop spining and smell burned
two main things pump and motor pulley.the motor pulley on admiral designed maytags is plastic and melts and causes belt to burn.also pump pulley spot welds break causing pulley to drag.tip machine so rests on wall in back and you can inspect from there.hope that helps God bless ,tom
Posted on Jan 04, 2009
SOURCE: washer wont spin, smells like burning glws1649
Burning smell could be the windings in the motor. Better not to use it and have it looked at. If the smell is a rubber smell then the belt is jammed while the motor spins. still needs intervention as it can catch on fire and you will have a bigger problem than the one you have now
Posted on Jul 31, 2009
Sep 02, 2016 | Maytag Legacy Series Top Load Washer
Dec 03, 2012 | Maytag Washing Machines
Oct 16, 2011 | Washing Machines
Oct 10, 2017 | Maytag Washing Machines
Apr 20, 2011 | Maytag Washing Machines
Sep 11, 2010 | Maytag Performa PAV3200
Aug 07, 2010 | Maytag Washing Machines
Jul 31, 2009 | Frigidaire Washing Machines
Jul 12, 2009 | Maytag LAT3600A Top Load Washer
Mar 17, 2009 | Maytag SAV5710 Top Load Washer
16 people viewed this question
