Question about Exercise & Fitness
Everyoung treadmill 86800
After about 10 minutes on low speed treadmill hesitates stop go stop go etc.
  • 9 Answers
SOURCE: Nordictrack treadmill C2100 belk is not slipping
Several issues, drive belt that drives the walking belt could be loose but you should smell rubber if its slipping.
Something could be caught in the track causing extra drag, its easy to do if you have kids or pets
Check for when you last lubed the track and walking surface, with no silicone it will drag and bog at low speeds
Posted on Oct 22, 2009
SOURCE: Have the same problem with my Everyoung Treadmill
End up dismantling the unit and disposing everything except for the motor and belt and rollers. Was a good machine except for no parts support.
Posted on Dec 31, 2009
rockmeister
  • 2047 Answers
SOURCE: How do I lower my Everyoung 86800F treadmill from
This might be of a little help. My treadmill is not an everyoung but on the control panel it has two buttons which are used for adjusting the position. While i was searching for a solution on this i came across an individual whop has one for sale you could call him and find out if you are in the US here is a link to his advert.
http://fayar.craigslist.org/spo/2036394410.html
Hope this solution has been helpful?
Posted on Dec 12, 2010
ercupa190
  • 12223 Answers
SOURCE: F63 sole treadmill, low speed error when inclined
If the calibration does not pass you may need to check the speed sensoralignment. You must understand the instruction for calibration is under the hood for motor.
1) Remove the motor cover hood by loosening the 4 screws that hold it inplace (you do not need toremove them completely).2) The speed sensor is located on the left side of the frame, right nextto the front roller pulley (thepulley will have a belt around it that also goes to the motor). Thespeed sensor is small and blackwith a wire connected to it.3) Make sure the sensor is as close as possible to the pulley withouttouching it. You will see a magneton the face of the pulley; make sure the sensor is aligned with themagnet. There is a screw thatholds the sensor in place that needs to be loosened to adjust thesensor. Re-tighten the screw whenfinished.
2) if the problem persist you must Test the main motor for open, ground 3) the main control board faulty. See the block diagram that I did as person like you that understand that 90% of functions the main motor controller board has effect.
good luck. sincerely. God bless you.
E.CUADRA
MANAGUA, NICARAGUA. C.A
Posted on Dec 01, 2011
ercupa190
  • 12223 Answers
SOURCE: looking for owners manual for everyoung 86800F model
go for free download: www.fitness.manualsonline.com or www.manualsfactory.com or www.retrevo.com
Posted on May 07, 2012
My treadmill won't go down the platform how to lower it please help
If it is stuck in the incline position all you need to do is re-calibrate most of the time
The first step to re-calibrate the incline. ProForm provides calibration instructions in the treadmill owner's manual.
Hold down the "Stop" button and the "Speed" up button. Insert the safety key into the console then release the "Stop" and "Speed" buttons.
Press the "Stop" button then press either the "Incline" up or down button. Wait while the treadmill raises then lowers the incline ramp. Press the "Stop" button and remove the safety key.
Hope this helps or solves the problem, if you have any further questions please do not hesitate to contact us at 888-713-2880 or visit us online at
http://www.sportsmith.net/supportsearch.aspx
May 18, 2015 | Proform 1050T Treadmill
see the video attached. and lube the rollers bearing front+back.
God bless you
Oct 18, 2013 | Exercise & Fitness
Looking for owners manual for everyoung 86800F model
May 07, 2012 | Exercise & Fitness
How do I lower my Everyoung 86800F treadmill from a vertical to horizontal position ?
Dec 10, 2010 | Exercise & Fitness
EverYoung 75900 needs to be reprogramed Display unit show F1 can you pls provide the code thanks Joanne Pekar
I have a problemwhen i start the ever young model 75900F
on screen F1
please send me solution
Nov 05, 2010 | Exercise & Fitness
The belt on my 68600F EverYoung has quit turning. The display screen is still on and says E2.What does that mean? gaylesues@hotmail.com
e2 normally refers to error in the speed sensor - iff the treadmill starts moving and then stops it is speed sensor related, otherwise if it never starts at all you will need to test your drive motor with an external 18v battery (cordless drill battery) to see if the motor will still turn. if it still turns then that narrows the problem to the motor controller which also means that the motor relays are not working and the controller would need replaced
Aug 04, 2010 | Exercise & Fitness
Have the same problem with my Everyoung Treadmill EY88800K. Display was zapped with static and treadmill became inoperable. Great condition and hate to toss out. Any hope?
Dec 28, 2009 | Exercise & Fitness
Hesitation problem
try cleaning the inside of the MAF sensor and do the following procedure as well.
Here is the most common cause of surges and stalls at stops and low erratic idle speed and rough idle, it is in most cases the idle speed control air-bypass valve and or throttle valve and upper intake, these area's get full of gunk and combustion residue over the miles and cause idle issues (stalls, low idle) like yours, Get a can of intake cleaner from any local parts store, not carb spray, intake cleaner, it is made by a company called CRC, remove the air intake hose to the engine, hold the idle high so the engine won't stall, then spray the can of cleaner into the intake while keeping the engine running, use at least 1/2 the can, shut down the engine and disconnect the battery for 5 minutes, then restart and complete a number of mixed driving cycles, town, freeway, stop and go etc., after a few days the problem will go away as the system will relearn to the clean intake.
Mar 24, 2009 | 1994 Cadillac Fleetwood
Exercise & Fitness Logo
41 people viewed this question
Top Exercise & Fitness Experts
Electro Med Services...
Howard
Howard
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
