I have a Sony Trinitron Model KV-32FS320. a while back it just would not turn on. The red indicator light keeps flashing. I have unplugged it for a long period of time and tried to see if that would reset what ever was wrong but no luck. any suggetstions?
the red light flashing tells you and a service person why the tv will not power up . if you have test equipment to work on electronic equipment then we can move forward if not ,your tv will need parts replaced or board replaced . you dont have a failure that you can change a setting or push a reset button to repair . you will need to get in there with equipment inject signals,look at waveforms ,and check voltages . and know what you are doing with the information you gather ...the other answer you need to send it out for repair .... most repairs on this set will run 100.00-200.00 for common problems .........Please if this answer helped , please rate this 3 or 4 stars . and keep me in the paid answer department . A 1 or 2 may knock me down into the unpaid ranks. Thanks Cactus Bob .
The standby light should be blinking in a repeated count. That count will indicate the circuit in which the problem occurred that forced the shutdown. Please post that count and I will be able to provide additional details about the problem and its possible solution.
My sony kv 32fs320 is having a problem with the colors. The overall hue slowly shifts from normal...
(More)
My sony kv 32fs320 is having a problem with the colors. The overall hue slowly shifts from normal to pinkish, then bluish, then greenish. This is particularly noticable with whites. It is somewhat intermittant.
I have a Sony Trinitron Model KV-32FS320. a while back it just would not turn on. The red indicator...
(More)
I have a Sony Trinitron Model KV-32FS320. a while back it just would not turn on. The red indicator light keeps flashing 5 times then pause then 3 times. I have unplugged it for a long period of time and tried to see if that would reset what ever was wrong but no luck. any suggetstions?
Blinks 5 times and then pauses and then 3 blinks....Repair shop I spoke with says it means no h...
(More)
Blinks 5 times and then pauses and then 3 blinks....Repair shop I spoke with says it means no h drive issue...Any help would be appreciated
I have a trouble where my sony kv-32fs320 blinks 5 times. called service repair centers and all 3 gave me a different problem description. Just wondering if an explanation of what is wrong can be given to me.
