Trane com pzs
T stat blinking change filters, filters have been changed
2 Suggested Answers
billyvangogh
  • 108 Answers
SOURCE: how to unlock a trane pzs programmable thermostat
Unlock???? You mean reprogram???....should be a button says Program or set program etc....Mode.....or remove the batteries for 10 minutes and start over
Posted on Oct 25, 2009
Trane XB80, no heating, limit circuit open
Sometimes these can be reset by gently taping them on the floor. Can be caused by not changing your furnace filter.
May 18, 2014 | Trane American Standard Trane American...
Changing From Trane to Honeywell
Color ---> New stat terminal
Blue--------C
Green------G
Yellow-----Y
Orange----O
Red---------R
White------E and Aux.
Tan---------unused, tape and secure it
If there is Rh and Rc or R and Rh, these terminals should be jumpered together.
I used to install Weathertrons eons ago. Whatever you do DO NOT connect the blue wire to the B terminal, you will short out your low voltage transformer immediately when you switch to heat
Jun 13, 2013 | Honeywell RTH3100C - Digital Heat Pump...
Wiring diagram for Bay SEN SOL 9-B, Need to know what the numbers control on the thermostat, lost manual with wiring diagram.
trane used dc t-stat for a while with a sensor in line.It was designed to run off of the sensor in the event that the t-stat failed.If your model is like that get a dc-ac converter board and you can use any 24vac t-stat.Will take alot of problems away because the dc will pick up residual current if using unshielded wiring.
Mar 05, 2010 | DeLonghi Trane 5t Rooftop Air Conditioner...
Hello i want to conect a trane condensator 2twb0036a1000ba to a trane evaporator mww536k10raa i need a wiring diagram
Your wiring concerns may be more with the thermostat wiring connections than the condensor connections. if you look inside the cover of the evaporator unit (usually called air handler) there should be a wiring diagram glued to the panel cover. This diagram will show all 3 units (stat,cndsr, airhndlr) and the wiring needed between them. Trane and Lennox are notorious for having the most wiring between components. You also need to be sure the stat is the correct type for the system (i assume this is a heat pump system) and there can be as many as 9 wires from stat to system and 6 wires from inside to outside units. Also, the stat will have a wiring diagram with it that shows most typical system wiring including the wiring between in and out units. Your best bet (if you have no diagram on the unit or with the stat) is to call trane and have their tech division fax a diagram to you. Goodluck,Macgivor
Jan 27, 2010 | Heating & Cooling
New Trane XV95 furnace runs and stops nine
if it is a mechanical thermostat the heat ant. does that on cheaper digital tstats it is set by span and on better stats like honeywell model 5000,6000,8000 series you set the cycle rate. what kind and model number is tstat
Dec 19, 2009 | Goodman GDS80904BNA Open Flame Heater
How to unlock a trane pzs programmable thermostat
Oct 25, 2009 | Heating & Cooling
I had a 14 seers Trane installed 18 months ago. The thermostat goes blank and the system doesnt come back on until I flip the breaker or disconnect power to the ac.
try replacing the batteries in the thermostat on your wall. probably has 2 AA's this may fix it if not may have bad or old wiring from tstat to main indoor system. when you had a trane installed did they change the air condition components only(likely) or did they put in new furnace, new wiring, new t-stat, a full install?
Sep 11, 2009 | Ruud Central System Air Conditioner
Trane XT300 thermostat reads HOLD-AC. Unit will
by simply turning power off to furnace or air handler may not work but there might be a reset button in the t-stat. remove the faceplate off of the t-stat it might be in their.
Aug 16, 2009 | Heating & Cooling
Programmable T stat
your trane heat pump energizes the reversing valve with O - orange y - is to turn on the unit make sure you have your orange wire hooked up and the tstat programming set to heatpump otherwise your reversing valve might be bad
Jun 30, 2009 | Honeywell Electronic Programmable...
Trane XL19i 8? ton heat pump not heating very well
Your second stage heat check the dip switches on the board and the wires to the proper two stage heat t-stat.
Feb 06, 2009 | Omega Trane Furnace Draft Inducer Blower...
Heating & Cooling Logo
16 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
