Question about Sony Cyber-Shot DSC-S40 Digital Camera
DSC-S40 images in open and close area
Shots in open places is very white, no images can be seen. If the area is closed, the shots appears like with stripes on the screen.
  • 69 Answers
Sound to me like the shutter assenbly is worn, this cause ventian blinds to appear in you shots and incorrect exposure times. sorry their is no cure
Posted on Sep 21, 2007
SOURCE:
Canon 80D operates as normal except all shots taken are white with a wide pink band running across the screen. Camera plays back old shots on card normally but all new shots are just pink and white.
Sounds like your imaging sensor has failed and is not recording blue or green tones. Take your camera to a good camera store or send it to Canon for a service estimate.
Apr 07, 2018 | Canon Cameras
I have a kodak 4600 scanner that has an error " white patch not seen". i have tried to cleaning the imaging guides and calibration as wellthe scanner does not calibrate too please how can i resolve this.
Hello, I had a similar problem. The guides have a white stripe facing the camera (facing the inside of the scanner), the scanner uses this white stripe to define the image. If the guides are in place, and you turn the scanner off, you can see there is a black tape on one of the borders of the guide it is black on one side, and white on the other. You can take the guides off, and check if you can see the white stripe, sometimes this stripe has some scratches, or is not completely white. You can try placing a white piece of paper of the same size as the white stripe on top of the existing white stripe so that it serves the same purpose, if that does not work, you might need to take the black tape that has the white stripe on it, and try to replace it. The scanner needs that white stripe to be completely white. Hope it helps
Feb 26, 2014 | Kodak i1440 Pass-Through Scanner
Hallo, my canon powershot A420 camera shows horizontal white lines in LCD screen mostly in night shots and the day light shots appear blurred as if more light is entering and the image is not clear.
I am afraid this seems to be a hardware error in the sensor. If the image is purplish in color when blurred it is similar to my and another user's problem. He/she contacted the manufacturer and they said they can fix it for $250. I am not a repair specialist so there may be a simpler cause and solution- good luck.
Dec 03, 2010 | Canon PowerShot A420 Digital Camera
My Canon EOS-5D 12.8 Megapixel SLR Digital Camera gives me many shots during a shoot with areas in the picture of different colors, like stripes running thru the whole image, usually one color. They run...
Image transfer chip from lens may damager or not getting proper connection from lens. Thats why does not fixed on a perliculer location. Please visit canon service center.Just close your eyes and think how a image comes via lens & showing in display. You will get the ans. watch the photo.759a276.jpg Thanks, i am waiting for your feed back & if you satisfied then thumps me please.
Feb 01, 2010 | Canon EOS-5D 12.8 Megapixel SLR Digital...
LCD viewing monitor has "optimize image" screen on it
Press up/down on the multiselector to cycle through different views of the image.
Feb 11, 2009 | Nikon D80 Digital Camera with 18-135mm...
Nikon d80 frame count
264 is the minimum number of shots you can fit onto the memory card. A shot with large areas of black or white uses less memory than a more complex image and so the camera recalculates the number of shots remaining and so the number appears to go back up to it's original value.
Sep 10, 2008 | Nikon D80 Digital Camera with 18-135mm...
Lumix TZ3 zebra stripes in daylight pictures
hello sodaclub, this fault is normally caused from to much light entering through the lens, the shutter is not closing or working at all.
Jun 24, 2008 | Panasonic Lumix DMC-TZ3 Digital Camera
"graph" on reviewed pictures
Press up or down on the 4-way command button to toggle between histogram, shooting info, custom settings, highlights, or none.
May 13, 2008 | Nikon D50 Digital Camera with 18-55mm Lens
THIN VERTICAL WHITE LINE on my photos
If you have the images in your computer them click on the 'Add image to your post' instruction and follow the prompts. But from what you tell me this appears to be a CCD problem and the camera should be returned to the vendor if under warranty or contact the Customer support at Nikon other wise. for the camera to be replaced
Jul 21, 2007 | Nikon D70s Digital Camera
White screen with ghost images
If the photo shoot out show white , the obscure (quality variation), and even horizontal line ( white lines), and so on over-exposure cases, even if the use of anti-tremor, set to default values are invalid, because the camera shutter fault.
It's need repair camera machine shutter.
more detail casio ex-z500 overexpourse
Jul 12, 2007 | Casio Exilim EX-Z500 Digital Camera
Sony Cyber-Shot DSC-S40 Digital Camera Logo
80 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
Dan Dangel
Dan Dangel
Level 1 Expert
Are you a Sony Camera Expert? Answer questions, earn points and help others
