Question about Tablets & eReaders
Octavo tablet cracked screen - Tablets & eReaders
Cracked screen
    wholesale lcd 1024x600 ips 7 - AliExpress.com
    www.aliexpress.com > Wholesale Product
    7" 7Inch 1024*600 1024X600 IPS TFT LCD Dispaly Screen For ... 100% Original LCDScreen Replacement Repairt Part For Freelander PX1 1024X600 IPS Screen ... Original New 7" IPS Tablet Touch Screen Touch Panel Digitizer Glass For ... images for Cracked screen 7 inch panel 1024x600 ips
    More images for Cracked screen 7 inch panel 1024x600 ips
    Cheap screen 1024x600 replacement tablet 7 deals
    guide.alibaba.com > Computer Hardware & Software > Tablet PC
    7 inch 1024*600 IPS screen Capacitive touch panel nfc android tablet .... Front TouchScreen/Panel Glass Screen Replacement Repair Parts for RCA Tablet 7 ...
    Touch Screen 1024x600 - Alibaba
Jan 01, 2016 | Tablets & eReaders
I have a irulu tablet 7"ich and my screen is cracked but it still works I just can't pick an app because the screen is cracked help
You need to replace the cracked screen with a new one. But it would be cheaper to buy a new tablet.
Aug 29, 2015 | Tablets & eReaders
Its a crack inside my screen and i didnt know how to fix it so i opened my tablet to see what was wrong and i didnt see anythning. so i put it back together and its not turning on!!!!!!! please hel
(1) Is the battery charged? I'd connect the charger for at least 10 to 15 seconds anyway, while doing the following step.
(2)Are you holding the Power button long enough when you try to restart the tablet? It will need to be held down for a few seconds (perhaps 5 or 6) while you wait for the TRIO start-up screen to appear. Once it gets there leave the tablet to boot up fully.
If that does happen without further glitches should be able to go back to using the tablet as before.
(Was it working even with a cracked screen? Were you able to get the cracked touch-screen - I'm assuming that was what is cracked- to accept your fingertouch-inputs? Can you select items from all areas of the screen? If it was doing THAT, and it does it again NOW, I'd forget about the cracked screen , put a screen-protector on my tablet and press on ahead! Lucky dog!)
Nov 30, 2014 | Trio Stealth G2 7 inch Tablet with 8GB...
Screen is cracked and require a replacement screen for coby kyros MID 8042 tablet
It is cheaper to buy a new tablet than it is to replace a cracked screen with a new screen. Buy a new tablet pc.
Jun 28, 2014 | Coby Kyros 716829701508 Tablet PC
Octavo zeus tablet will start but just has android sign on the screen - how do I re-set it ? I have put a pin in the reset hole but this just powers it down again
My tablet wont even start at all. It just shows up the android picture on and on for the whole day until its flat. I need help to fix this problem. I reset it too many times and it does the same thing. I upgraded by pushing the on and go back buttong to start the upgraded but it turns out to do the same thing over and over. It would not start :( The android image just stayed frozen until its flat
Oct 10, 2013 | Tablets & eReaders
Can my nextbook android tablet cracked screen be fixed?
Sure... You can find new screen on amazon. take a look here Amazon com nextbook screen replacement. Hope this was helpful. cheers
Jan 27, 2013 | Tablets & eReaders
I cracked my Polaroid 7" tablet screen what can i do?
take to repair shop and see if it can be fixed, mine couldn't cause it cracked in thee inside of the tablet and i have a 10.1 inch tablet.
Dec 26, 2012 | Polaroid Tablets & eReaders
I have a NAXA 7in tablet and The screen is cracked, can you tell me how I go about getting this fixed.
There is no solution for you to fix the crack of your tablet pc even if you use an adhesive to bond it again the crack..If you want to get rid of the crack buy a new screen or go to the nearest technician and ask him to replace a new screen for your tablet pc...
Jul 05, 2011 | Tablets & eReaders
Tablets & eReaders Logo
27 people viewed this question
Top Tablets & eReaders Experts
Are you a Tablet and eReader Expert? Answer questions, earn points and help others
