Question about Zebra GX420t Thermal Printer
Zebra GX420t "Alert Paper Out"
Turn it on, turn it off, still shoots out 3-6 pages then displays "Alert Paper Out" even though there is a full roll. Holding the "arrow" key and the "green" key until it blinks four times, but it still errors out.
  • 9 Answers
SOURCE: zebra s4m error condtion paper out
Sounds like you will need to perform the calibration procedure.
when you access the menu system go to advanced menu, the password is 9999, use the keys to navigate to manual calibration and follow the instructions. when it states load backing this is refering to backing paper, so remove the labels from the backing and place in label path. hope this helps
Posted on Jan 27, 2009
SOURCE: Zebra TLP 2844 tis not detedting the paper.
It turns out that I kept overlooking one printer setting. It was set for thermal printing rather than direct.
Posted on Mar 20, 2009
SOURCE: my zebra 4M+ get me a cutter jammed status
Sometimes debris builds up in the bottom of the cutter assembly preventing the cutter from going all the down. There is a switch inside the cutter which trips the "jammed" error if the cutter can't go all the way down. The cutter can be removed and disassembled to remove the problem. Caution should be exercised. There are washers and springs on the cutter face plate guide screws which have to be removed.
Posted on May 20, 2009
  • 124 Answers
SOURCE: Zebra TLP 2844-z green/red light flashing
Check their website. It should let you download the user's manual after you've logged in.
http://www.zebra.com/id/zebra/na/en/index/products/printers/desktop/tlp2844z.4.tabs.html
I work with these at my work-work, and the manuals are pretty handy to have!
Posted on Jun 15, 2009
  • 62 Answers
SOURCE: TLP2848Z blinking red, will not print
1: Is it a TLP2844 or a TLP2844Z.
Operationally they are completely different printers. TLP2844 uses ELP (Eltron Programming Language. but TLP2844Z uses ZPL (Zebra Programming Language). You need to calibrate the printer to the labels.
Calibration:
If its a TLP2844. Load media. Connect power.
Hold down feed key, power on, count one, two, release feed key. The printer will go through a calibtation routine and print config label. IMPORTANT - When it prints this label you must press the feed key and see the message OUT OF DUMP. Your printer will now be calibrated. Check this by hitting the feed key a few times and printer will feed one label each time feed is hit.
Calibration:
If its a TLP2844z.
Load media. Turn printer on and wait for green light (Approx 1 minute)
Press feed key and keep it pressed until green light blinks once, then twice, now release feed key.
Posted on Jul 13, 2009
I changed the Label Roll in my Zebra QL 220 Plus. After I turn on the printer it prints labels continuously and on the screen it shows "Extended Two Key". How do I get rid of this problem?
Extended two key means one of the buttons by the LCD are sticking and not releasing, you use the two key sequence to print a device configuration but if you hold in the buttons for too long r they are sticking that's when you get the extended two key error.
Nov 18, 2014 | Zebra QL 220 Plus Label Printer
Gx420t printing blank configuration pages
Could be faulty printhead. OR ribbon is put in the other way around. hard to say. It would be better off call the service technician.
Sep 27, 2013 | Zebra GX420t Thermal Printer
Cardiocare 2000 (Bionet) machine won't print full page!
hi, if i want to start running unit. after that always on display data error, plz turn off. why? what can i do for that? thax
Jan 22, 2013 | Life Science Bionet Cardiocare 2000 12...
Led display shut down when the detector detect an alert
You have the unit in dark mode. Press the Dim/Dark button again to get the unit to full brightness. THe unit has 3 levels of DIM. First the unit is at its full brightness, pressing the dim/dark button will dim the display and the unit functions normally. Press the Dim/Dark button again will futher darken the display but when the unit alarms the display is turned off and remain off during the alert. After the alert is over the unit waits 20 seconds of no alert to turn the display back on.
Mar 09, 2011 | DE-1740 Radar Detector
Changed rolls of labels on Zebra GX 420T and now nothing prints
Were the new labels thermal paper? Thermal printers need specially made paper to work right.
May 28, 2010 | Zebra LP 2844 Thermal Printer
Mar 19, 2009 | Zebra LP 2844 Thermal Printer
Zebra 4M printer stopping due to error message
The printer is dirty sensor label or no label is calibrated. Turn off the printer and press FEED, CANCEL, PAUSE and turn on, release the keys to advancing the label, and let print be calibrated. Roberto Martinez Mexico bartech9@yahoo.com.mx
Feb 26, 2009 | Zebra Z4M Printer
Zebra TLP 2844
Call BarcodeWarehouse.biz 1-888-422-9249 - they offer free tech support on Zebra printers even if you didnt buy it from them. They helped me fix mine in about 3 minutes when I had given up was calling to buy a new printer!
Jan 28, 2009 | Zebra LP 2844 Thermal Printer
Loading label roll into Zebra tlp2824-z printer
If you are using thermal paper and don't have to use ribbon, you will only need to spread apart the roll holsters and place the roll in there, At the front of the printer, next to the printhead and the pressure roll you will find two paper guides which you can spread apart (depending on the exact model by muving them with the fingers or by turning a wheel in the right hand side of the pressure roll. feed the paper through them guides and close the printer.
Ensure that the printing surface is at the top.
Jan 20, 2009 | Zebra LP 2824 (clp2)
Zebra GX420t Thermal Printer Logo
221 people viewed this question
Top Zebra Office Equipment & Supplies Experts
Dave Busselle
Level 1 Expert
Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
