Question about LG Rumor 2 Cell Phone
Lg rumor 2 enter diagnostic mode - LG Rumor 2 Cell Phone
  • 124 Answers
SOURCE: LG Rumor 2 won't get past the lg logo on startup
this is a software problem !!! change the software fo your mobile in the nearest outlet
Posted on Jul 17, 2009
SOURCE: LG Rumor won't turn on
I had this problem too. Do you have a micro sd disk installed? If so, remove the micro sd disk. When you restart it should start right up, and then you can put the micro sd disk back in and all should work normally. I know, it is a big pain in the rear. For some reason when it boots up, IF there is a micro sd disk in, it tries to boot from the sd disk, and can't get out of that cycle. I don't like little bugs like this and will wait and see if I buy a rumor 2 or not the next time I replace one of my other phones.
Posted on Sep 01, 2009
  • 821 Answers
SOURCE: Micro SD Slot in My LG Rumor 2 isn't reading Micro SD Card
hello,kindly check if it is inserted properly,you will see a directive arrow on the memory card to show you how it is to be inserted,if after you have inserted it correctly and it still does not sees it,i would suggest you suspect your memory card is corrupt if their is any message displaying on your mobile phone screen,and if it does not show any message like memory card corrupted,then you will have to visit a mobile phone repair expert to help you change the memory card slot,after this your mobile phone will now read your memory card.
kindly rate this solution if it's helpful,
take care.
Posted on Apr 16, 2010
  • 532 Answers
SOURCE: how to fix screen on lg rumor 2
What you need to do is to get a screw driver, open the phone and remove the flex that connect the screen to the panel and put it back.
If the problem continues, then you have to change the screen with a good one.
Thanks
Posted on Jul 30, 2010
ajpn920
  • 241 Answers
SOURCE: Do you have the codes to unlock the LG Rumor 2
LG Rumor 2 unlock codes can be obtained from an LG UNLOCK CODE provider.
Posted on Feb 06, 2011
No display
1) Press the "Express Freezing" key and the "Colder" key of the Freezer Temp function at the same time and hold for 3 seconds. The refrigerator will enter Test Mode 1. Test Mode 1 allows diagnostic function of the compressor and freezer fan, stepping damper open, defrosting heater off and display LEDs all on.
2) Touch the "Express Freezing" key and the "Colder" key of the Freezer Temp function at the same time while in Test Mode 1 and hold for 3 seconds. The refrigerator will enter Test Mode 2. Test Mode 2 allows diagnostic operation of the compressor and freezer fan, stepping damper close and defrosting heater off.
3) Press the "Express Freezing" key as well as the "Colder" key of the Freezer Temp function together while in Test Mode 2 and hold for 3 seconds. The refrigerator will go into Test Mode 3. Test Mode 3 allows diagnostic operation on the compressor and freezer fan off, stepping damper close and defrosting heater on.
4) Press the "Express Freezing" key and the "Colder" key of the Freezer Temp function at the same time while in Test Mode 3 and maintain for 3 seconds. The refrigerator will reset to the state prior to entering test mode.
5) Unplug the blog798088-troubleshooting-lg-refrigerator-defrost-cycles.htm&opts=1,3,5Lg refrigerator from the wall outlet, then plug it back in to reset the appliance after coming out of test mode.
Oct 19, 2012 | LG LFX25961SB (247 cu ft) Side by Side...
How do i turn on bluetooth feature on my rumor 2
    • 1 Turn on the Bluetooth-enabled device and enable it to be in "Discovery" mode. Check the owner's manual of the device to learn how to put it in "Discovery" mode.
    • 2 Press "Menu/Ok" on the LG Rumor2, which is the middle button on the phone.
    • 3 Press " * " to access the settings menu.
    • 4 Press "1" for the Connections menu.
    • 5 Press "2" for the Bluetooth menu then press "1." Press "Yes" when prompted to turn on the Bluetooth feature. A list of available devices appears in the menu.
    • 6 Highlight the listed device, which should be showing.
    • 7 Click "Ok."
    • 8 Enter the passkey provided in the owner's manual of the Bluetooth device. The standard passkey is "0000." The Rumor2 is now paired with the Bluetooth device.
    • 9 Press the "Call" key on the phone or the "Call" button on the Bluetooth device to answer calls through a Bluetooth headset while paired.
Mar 01, 2012 | LG Rumor 2 Cell Phone
How do i turn the bluetooth feature on for my rumor 2
  • Insert a microSD card into the slot on the right side of the phone.
  • 2 Connect the phone to your desktop with the USB cable.
  • 3 Select "Transfer Music" on the phone by pressing the "OK" key after highlighting "1 Yes" on the display.
  • 4 Go to your desktop and use Windows Explorer, which will have now opened up, and you can drag and drop files from the desktop to the phone just like another directory.
Use the Rumor Bluetooth to Connect to Your PC or Other Bluetooth Device
  • 1 Set your secondary Bluetooth device into the pairing mode.
  • 2 Open the "Tools" menu on your phone by first making sure it is in the standby mode and the slide is closed. then press the "OK" key and select "Tools."
  • 3 Select "Bluetooth" and press the "OK" key to choose "Pair with Hands-Free." If "Bluetooth Wireless Technology" is turned off follow the prompts to turn it on by pressing the "Left Soft Key."
  • 4 Highlight secondary Bluetooth device on the list of found devices and press the "OK" key.
  • 5 Enter "0000" pin code and press the "OK" key to initiate the pairing process.
  • 6 Enter the device's name and press the "Left Soft Key" for "Save."
  • 7 Connect to your device by pressing the "Left Soft Key."
Blue lg rumor 2 security code forgot
Menu > Settings > More > Security > Enter Lock Code > Delete/Reset > Reset Phone
Where the default lock code is the last four Numbers associated with the phone.
Jan 02, 2012 | LG Rumor 2 Cell Phone
Can still operate phone but it constanly blinks..
The LG Rumor cell phone is a practical and easy-to-use device that offers two modes of typing through a regular number dial pad and a full QWERTY keyboard. Like any cell phone, the LG Rumor can have errors that prevent it from working properly. Troubleshoot common issues by updating software or checking the power cycles.
Instructions Things You'll Need
  • Internet connection on LG Rumor cell phone
  1. Check and update device software
    • 1 Locate and click the home screen icon.
    • 2 Locate and click "Menu," "Tools" and "Update Phone."
    • 3 Click on "Update Firmware."
    Update device data profile
    • 1 Click the home screen icon.
    • 2 Locate and click "Menu," "Settings" and "Data."
    • 3 Click "Update Profile."
    Power cycle cell phone
    • 1 Turn off the cell phone.
    • 2 Locate and remove the battery.
    • 3 Install the battery after one minute.
    • 4 Turn on the cell phone.
Jun 12, 2011 | LG RUMOR Cellular Phone
I need a manual (instructions) on how to upload pictures from the LG Rumor 2 camera phone to my e-mail address.
Go into your picture gallery and choose to send as a picture message or MMS. Instead of entering one of your contacts into the To: field, enter you email address and hit send. It should come to your email as a .jpg attachment.
May 14, 2011 | LG RUMOR Cellular Phone
Does anyone know how to have the LG Rumor2 phone automatically lock
Locking Your Phone
When your phone is locked, you can only receive incoming
calls or make calls to 911, Sprint Customer Service, or special
numbers. (See “Using Special Numbers”on page 63.)
1. Press Menu > Settings/Tools > Settings > More... > Security
and enter your lock code.
2. Select Lock My Phone > Lock Now. (To setyour phone to
lock the nexttime itis turned on, selectOn Power Up.)
Unlocking Your Phone
1. From standby mode, press Unlock(rightsoftkey).
2. Enter your lock code.
Here's the link to the manual if you need it: LG Rumor Manual
If you found this information helpful, please give me a big thumbs-up when you rate my answer. Thanks!
Feb 04, 2010 | LG Rumor LX260 Cellular Phone
Dont Worry You Can solvethis easily
with the help of unlockcodes you have to type it through the keypad ............................
and you can over comeproblem easily ...........
you get the code fromofficial black berry code provider itself
Click Here To Get Codesto unlock your phone
Dec 30, 2009 | LG Rumor 2 Cell Phone
LG Rumor 2- deleting sent message contacts
THIS WORKS!! This will erase ALL phone numbers saved by text messaging. Go to tools and settings... Select settings.... Select more.... Select security.... Enter lock code, if you have not changed it, it is either 0000, or the last 4 numbers of your phone number... select erase reset... Select erase messages... Select yes. You have no saved numbers under text messaging if you followed these steps. My pleasure.
Oct 09, 2009 | LG RUMOR Cellular Phone
Deleting recent recipient text log from Rumor 2 phone.
LG Rumor 2: Go to Menu>Tools & Settings>Settings>More>Security>enter the lock code(last 4 digits of the phone number if it hasn't been already changed by the user)>Erase/Reset>Erase Messages. Your text recipients will be erased but so will your messages.
Jun 29, 2009 | LG RUMOR Cellular Phone
LG Rumor 2 Cell Phone Logo
Top LG Cell Phones Experts
Computer Repairing
Computer Repairing
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
