Question about Garden
How to remove clutch assembly from crankshaft on a TB525 EC Trimmer
I am down to the 3/8-24 NORAM and can't get it free from the shaft. What tools or how to remove?
SOURCE: Troy built Trimmer....tb575
Attached to this response are the front and back photos of the clutch assembly from a TB575SS trimmer motor.dave8459.jpgdave8459_0.jpg
Posted on Nov 28, 2010
SOURCE: how to remove(unscrew?) centrifugal clutch
Remove spark plug and insert some cord into the spark plug hole to freeze the crank shaft. This way you can unscrew the clutch from the engine .
Posted on Jun 23, 2009
  • 199 Answers
SOURCE: I need to replace the assembly starter cup on my
http://weborder.husqvarna.com/order_static/doc/HOUS/HOUS2005/HOUS2005_O0501501.pdf
down load the manual see if this helps
Posted on Jun 25, 2009
  • 127 Answers
SOURCE: replacing pull cord on 4 cycle gas trimmer, troy bilt
these usually are threaded counter clockwise need a pair of channel locks to hold the flywheel then with the other hand crack nut open
Posted on Jun 30, 2009
dropndeal
  • 2931 Answers
SOURCE: remove the trimmer head from shaft
The entire trimmer assembly (from the gearbox forward) will slide off of the drive shaft cover. On the side of the aluminum gearbox assembly, you will find a single screw. This is the "anti-rotation screw" (do not lose this). Then remove the small (approximately 1" diameter) clamp from the end of the gear box assembly and simply pull the entire cutting assembly off of the shaft.
If you just want to remove the trimmer bump head assembly, then you will need to lock the bump head assembly to prevent rotation while you are working. If you purchased this new, then there should be a small metal rod included with your accessories. This will fit in a small hole in the base of the gear box assembly 791-182193 and prevents the trimmer head from rotating.
Then proceed to remove the following items:
791-180814B (replaces 791-180814) Bump Head Knob Assembly
791-147495 Inner Reel (hold the trimmer string)
791-610636B (replaces 791-610636) Spring
791-612026 Retainer (be careful removing this so you do not inadvertently destroy it). If you intend to reuse the trimmer head. If not, then hack, pry, stab, etc.. until you mangle it enough to remove.
791-683301 Outer Spool & Eyelet Assembly should now slide out leaving only 791-612483
Spool Shaft which I will assume that you want to keep.
I replaced my entire string head assembly a couple of years ago (and subsequently misplaced it and am in fact wanting to purchase one) and replaced it with a grass-gater or similar.
I hope this helps.
Posted on Jul 19, 2009
Starts up when choked then dies. Has a new carb and using 4 cycle fuel that is fresh. Ran great till 3 weeks ago then this.
I just went through the same problem with my Yardworks trimmer that is identical to this. If it starts when chocked after priming but stall immediately would usually indicate that there is no fuel getting to the engine. I also found that switching to non-ethanol premium fuel made all the difference in the world.
Jun 06, 2015 | Troy-Bilt 29cc 4-Cycle Curved-Shaft Gas...
Craftman weedacker
  • Hole in the end of the clutch housing where the cable slides in has a # 20 torx screw in there.
  • Pull the spark plug, stuff some rewind starter rope in the plug hole, use a water pump pliers and turn off the clutch plate(s). NOTE: curved shaft trimmer will be a standard right-hand thread, straight shaft will be a left-hand thread.
Oct 04, 2008 | Craftsman 25cc Gas Line Trimmer
Can not separate the intermediate shaft assembly from rack and pinion
After removing the pinch bolt and nut it is usually necessary to tap in a small chisel or large screwdriver to open up the slot sufficient for removal. Sometimes burrs hold components together and sometimes there is a corrosion bond so a squirt of penetrating oil is a good idea too.
Jun 17, 2017 | 2005 Toyota Sienna
How to remove a screw with no head
Instructions 1 Use a center punch to put a deep hole right in the center of the screw shaft. This step is just so you have a starting place for the drill to begin. Tapping a thin nail into the center can sometimes work. 2 Start with a very small drill bit and drill a hole down into the shaft. Once that's complete, go to the next size of bit and drill a little larger opening in the screw shaft. Stop when the hole is big enough to use an easy-out tool in it. 3 Turn the tool gently. You never want to be rough in this step, lest you break the easy-out. Keep turning until the screw shaft is out. The tool is designed to grip the interior of the screw shaft and turn it as you turn the handle. 4 Remove the easy-out if the screw shaft is being stubborn and still won't come out. You definitely don't want to break the easy-out off in the hole. 5 Continue to use the drill, each time enlarging the hole until only the threads are left. 6 Peel away the threads of the screw with a large plastic headed pin. Pull them out of the threads of the opening.
Aug 05, 2012 | Cars & Trucks
When pulling rope it clicks
This is a problem with either the starter pulley ( rope pulley) if the corners are worn it will not engage with the pawls, or the pawl/pawls them selves have worn
Jun 19, 2012 | Troy-Bilt 29cc 4-Cycle Curved-Shaft Gas...
How do I fix a stuck float on briggs and stratton 19.5 twin
take the float out and test iff the pin holding it in is free by holding the with pliers and moving the float up and down once back in the float should lift up and down free'ly iff not the pin needs to come out of the float and free'd up [sand with fine sand paper or polly-pad or steelo ]
Jun 05, 2012 | Briggs & Stratton Briggs Stratton Intek V...
Remove spool from Troy Built TB525 ec
the nut on the trimmer head has left hand threads so you need to turn it like you would tighten most other bolts
Apr 25, 2012 | Garden
Vehicle shakes at 60 mph all wheels and struts replaced
Hello, Are the tires and wheels balanced? If they are balanced then check the drive shaft. This drive shaft transfer the power from the engine/auto transmission to the rear differential/rear wheel.
Now, on each end of the drive shaft is a flexible yoke, this splined yoke has a U-joint with four bearing cups. Two of the bearing cup is attached to the splined yoke and two are attached to the drive shaft. Now, on the rear differential end is a yoke but it has 4 bolts and nuts, it also will have a U-joint attached to the 4 bolted yoke and to other bearing cups attach to drive shaft. U-Joint is called "Universal Joint" Each U-joint has about 10 degree circular travel without any type of binding to the U-joints or the drive shaft.
Two things here. First, take a pry bar and wedge into the U-Joint and move the bar forwards, backwards, up and down. If the drive shafts moves in any direction and clanks. The u-joints need to be replaced and I would replace both of the U-joints. Secondly, if the U-joints aren't loose, then there is a good possibility that the drive shaft is out of balance. In other words, it has lost it small welded plats on the drive shaft and when you are drive you Chrysler the drive shaft is vibrating.
To replace the U-Joints and/or balance the drive shaft. You'll need to remove those 4 bolts and nuts on the differential yoke. Once the bolts are removed then push the drive shaft forward, it will slide forward. Now, under the transmission yoke place a pan/bucket/container to catch the transmission fluid that will drain out once the drive shaft is pull free from the transmission.
If you don't have a press, vise, brass 5 lb hammer, bushing, punches, then I would tackle this job of replacing these U-Joints. Without the proper tools, one can damage the U-joint yokes and the drive shaft. I wouldn't do this without the tools and experience. I use a cutting torch but I have been do it for 50+ years.
If the drive shaft is out of balance, then you will need to take to Drive Line Specialty Shop to have it balanced. Also, have them replace the U-Joints. They have all equipment to do this job. I wish you luck in your endeavor. GB....stewbison
Sep 21, 2011 | 2004 Chrysler Sebring
How do I remove the hassel free head of my craftsman trimmer model 358.791170
I can get you part way there. Remove the spark plug and shove some clean rope in the cylinder to prevent the engine rotating. Take the front housing off to access the clutch assembly, pull off the black plastic cover from the shaft end, and use a torx wrench to loosen the screw in the end of the shaft. After it's loose, the clutch drum will come right off. Unfortunately, I am stuck now trying to get the rest of the clutch assembly off without damaging it.
Sep 17, 2011 | Craftsman 27cc 2 Cycle Crank Straight...
Garden Logo
355 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
