Question about Bruder Toys
928g cat loader
Lacks fuel prime when starting
3 Suggested Answers
dnewcombe1
  • 1564 Answers
SOURCE: Ct332 track loader stalls shortly after starting.
Check the spark plug very closely, check it by tapping it in the palm of your hand. Make sure there are no droplets of water tucked up into the ceramic insulator. That's all it takes is one droplet to pull the spark off target. Of course if it is black, change it.
Posted on Aug 24, 2009
morganret64
  • 41 Answers
SOURCE: mower starts when primed but stops due to lack of fuel
If gas/fuel is more than 3 months old, replace with fresh fuel or add octane booster to fuel.
Posted on Dec 16, 2014
Mower starts when primed but stops due to lack of fuel
Dec 16, 2014 | Briggs & Stratton Garden
1988 aric cat 440 jag when primed will start and run then dies
Sounds like there is water in your fuel. If there is, you can see it in the bottom of the tank or just drain it and put fresh new gas in it. If straight fuel is left in small engines in the off seasons, they will gum up the carb with varnish and the carb will need to be removed, cleaned, and reinstalled.
Sep 21, 2014 | Garden
Yamaha trouble shooting
lack of power might mean lack of fuel check fuel filter had same problem with a honda v twin i changed fuel filter and it solved the problem,Lack of fuel leads to lost of power and engine running to lean ,which will lead to engine getting hot and exchust pipe getting hot
Apr 12, 2014 | Motorcycles
Catepiller is not starting l dont know where to start,its a cat engine 950
start by spraying a little wd-40 into the intake/air filter and see if that helps, if not check fuel filter, prime fuel pump, etc.
Dec 15, 2013 | Cars & Trucks
Engine is Bogging as throttle is opened up
Nothing like guessing! There can only be 2 sources of issues. Lack of fuel, lack of air flow. Check fuel pressure and flow, check EGR and IAC.
May 24, 2017 | 2004 Mercury Grand Marquis
1993 grand voyager won't start
anti theft malfunction. seriously put your ear near the filler neck uncapped and have someone turn the key. is there s whining. then that rules out a bad fuel pump> try carefully priming the injectors with fuel and then crank. standby with a garden hose in the even it backfires and pukes out the fuel. remove a plug wire and put any plug in the boot rest it against the valve cover have someone cranlk and looks for spark. 2 main causes for no start lack of fuel, lack of spark
Sep 04, 2012 | 1993 Plymouth Grand Voyager
1994 Isuzu Pickup 2.3L carbureted motor with mechanical fuel pump lost prime
If it were just that you would be ok once the engine started.
You might have a float problem with the carb. or something in the tank.
Are you sure the pump is not pumping ?
Jun 28, 2012 | Isuzu Pickup Cars & Trucks
Have changed plug and gas. hard to start but will
I would suggest cleaning the carb (remove it) and air filter. There are a few really small passages in the carb that need to be cleaned which get gummed up due to the 2 stroke mixture and sitting for the winter. (Even if you drained the fuel)
DO NOT use a piece of wire or anything to clean out any small passages. Use carb cleaner and compressed air, put it back on, and see if it's better.
If that doesn't do it, a carb rebuild is in order. Not very many parts on those little buggers. If the cleaning doesn't solve it, it's most likely a bad diaphram from sitting and drying out. (Which I'm learning towards due to the lack of pressure when you prime and having it starve for fuel and die after a minute of running). There is a square plate on the bottom of the carb held on by 3 or 4 screws. That's the cover for the diaphram. Remove the screws and plate and look at the diaphram to see if it has a hairline crack, if it's sticking (there's a spring under it), or if any thing else looks out of whack.
Apr 29, 2010 | Echo Rapid Loader, Trimmer Head
Tractor ran out of gas, put more in, now won't start again
battery may be weak, must have fully charged battery to sustain operational working condition, or alternatoor may be out, anyway check electrical system
Sep 10, 2009 | RTO Tractor Forks Bucket Forks, Pallet...
Toys Logo
22 people viewed this question
Top Bruder Toys Experts
ptpumpman
Marc Taylor
Colin Stickland
Colin Stickland
Are you a Bruder Toy Expert? Answer questions, earn points and help others
