Question about Nokia 6230i Cellular Phone
Head set logo do not disaapear after removing headset
The head set logo appears on the scrren and not fade away afterremoving the head phones. Cannot answer the phone directly only through headphone or loudspeaker
    Guru:
  • 104 Answers
As a quick solution I can offer you to go to the setup and change current profile to general (currently the phone is set to headset profile) it should fix your current problem. The cellular should do it automatically after you removing the headset. you can try in the future: 1. Close and open the cellular - easy 2. update software, maybe Nokia fix that bug.
Posted on Aug 30, 2007
VIZIO M3D470KD TV TURNS ON, HAVE BACK LIGHT, V LOGO APPEARS ON SCREEN THE FADES AWAY.
Corrupted firmware. An update is necessary. If you wish to get some details; check the site linked here. Pull up older posts.
http://electronicshelponline.blogspot.com/ Firmware (Software) update procedure of many popular brand TVs and other devices are given in detail.
Sep 30, 2016 | Vizio M3D470KD 47 inch Class Theater 3D...
Why does my headset keeps fading in and out of a conversation?
This tends to happen when the battery is low or your far away from the phone. My Bluetooth ear piece was doing this fully charged, but it was almost 7 years old. So if it is that old then it may be time to replace it.
Oct 15, 2014 | Jabra EasyGo Bluetooth Headset
See White Screen + Nokia Logo + Failed to Start contact Retailer
Try formatting your phone and see if it works.
First make sure your phone is turned off.Then press the following buttons simultaneously (at the same time:
Power button + * + 3
This will restore and reformat your phone into factory settings. Hopefully your phone will be able to start again as if it were being used the first time from the box.
Let me know if it works,
Hope I have been of assistance to you,
Cheers :)
Sep 03, 2009 | Nokia 3230
Unable to sync a bluetooth headset
It appears your phone might not be syncing up with the headset since there might not be any signal at all. Do you have some one else's head set you might be able to borrow in order to test this possible problem? Maybe even stop by a mall phone booth to see if the blue tooth head set they have there for demo will sync up with your phone [besides you can always walk away after you test that and not buy anything just dont tell them before hand..].
See if this helps figure out the problem. It's one of the ways to test the problem and find a solution.
Let me know how it goes!
p.s. sorry it has taken so long for some one to get back to you. Let us know if you found a solution to this problem already in the mean time!
Sep 02, 2008 | RIM BlackBerry 7290
Bluetooth problem
I have an lg sprint muziq and I cant get my blue tooth headset connected. The phone can't read or see the blue tooth head set
Jul 01, 2008 | Motorola Mobility HS850 Consumer Headset
N keypad sound, enhancement logo showing
The key sound problem:
Attempt the following:
1) Hit Menu
2) Go to Settings
3) Go to Profiles
4) Select General
5) Select Personalise
6) Scroll down to Keypad tones and if set to OFF select it, then using the centre button press right THREE times, then press the centre button to select.
7) Press Back
8) Go to Activate and Select.
NOTE: Follow this procedure for every profile you wish to use keypad tones for.
For the headset logo problem: (this is a temporary fix, you might need to have your phone checked or wait for another solution)
1) Hit Menu
2) Go to Settings
3) Go to Enhancement Settings
4) Select Headset
5) Select Default profile
6) Select Silent
NOTE: If this does not remove the logo, then you should follow the (instructions) above.
Regards
May 11, 2008 | Nokia 6230
Low sound on n73me
i think ur not using nokia approved genuine headset accessory . even though some head sets have nokia logo they r not original made by nokia . they cause low sound quality while hearing music and diaphram bets can be heard during playing high bass songs . try with another genuine headset
Dec 12, 2007 | Nokia N73 Cellular Phone
Nokia 3230 headset icon can't be removed
If factory settings didn't work,this will SURELY help:
1.Turn off your phone..
2.Press and hold three keys, i.e. Green Button(call answer key) + " * " button + " 3 " button and while holding the buttons boot the phone..
3.Hold till the phone shows the Nokia Logo/formatting screen..
The problem will be solved for sure..
Regards..
Dec 02, 2007 | Nokia 3230
Strange symbol on screen. able to make calls but not talk or hear
This rings bells. On some of the early Nokia GSM phones, shorting out a certain combination of the contacts on the connector on the bottom of the phone would kick it irreversibly into the "headset" profile. Never did find out what this feature was for, but it was a real pain if you kept a buch of keys in the same pcket as your phone. Things that might help: 1. Changing profiles (perhaps set the phone to "meeting", then back to "general" 2. Finding and using "restore factory defaults" in the settings menu. A.
Apr 27, 2007 | Motorola Mobility V171
Nokia 6260
try a master reset on your phone, this will be located somewhere in the settings
May 15, 2006 | Nokia 5100/6100/6300/7100 Series Black...
Nokia 6230i Cellular Phone Logo
137 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
