Question about Sewing Machines
Kenmore 1792080 Sears Kenmore sewing machine 158 1792080. Thank you!!
  • 323 Answers
SOURCE: instructions for theading a Sears Kenmore Sewing machine model 158.14000
all machines thread the same. TTN tension,take up, needle.
Beginning with the spool, guide the thread through the thread guides to the tension assembly. Pull the thread through the tension assembly and test it to make sure the tension is working correctly.
(To do this test,adjust your tension setting to normal or medium or 5 or something in the middle. Raise the presser foot and pull the thread through the tension. It should pull easily!! Lower the presser foot and pull the thread. It should pull noticeably harder.) If it passes this test, continue up through the take up lever,then down through the thread guides to the needle. Make sure your needle is fully inserted and turned the correct way.( If you load your bobbin case from the left side,the needle rule is normally FLAT to the RIGHT is RIGHT. There are some exceptions. If you have a newer style drop in bobbin or your bobbin case loads in the front then the rule is FLAT to the BACK.
To wind the bobbin, guide the thread around the thread guide on
the left top of your machine, then to the bobbin winder. Wind the thread around the bobbin several times, place the bobbin on top of the bobbin winder, push it against the wheel and press the foot pedal. It should stop winding when the bobbin is full or you take your foot off the control
Sewman7
Posted on Jun 05, 2008
SOURCE: Kenmore 10 Sewing Machine
kenmore sewing machines relics
Posted on Jul 13, 2008
  • 323 Answers
SOURCE: Where to oil a Kenmore 158-17600
Remove the top and bottom covers. Turn the wheel and put a drop of oil anyplace that moves and rubs.Also at the ends of each shaft. Open the side cover and oil the needle bar and all the parts inside that move and rub.Put a drop of oil on the hook.Do not put a good piece of fabric in the machine right after you've oiled it. Sew it off on some scraps that you can throw away.
sewman7
Posted on Apr 18, 2009
SOURCE: users manual for OLD kenmore sewing machine(158
I need the instruction manual for a Kenmore sewing machine 158.19141
Posted on Jul 12, 2009
  • 255 Answers
SOURCE: how to "tune-up" mechanical Kenmore sewing machine
Sure! Jenny at http://blog.sew-classic.com/categories/Sewing%20Machine%20Repair.aspx has several very good, in-depth articles about servicing your own machine, but here are the basic steps:
1. Take out the bobbin case and bobbin holder.
2. Take the needle plate off.
3. Brush out all the old lint in the bobbin area and under the needle plate. Remove any loose bit of thread.
4. Open the head of the machine (should swing open). Clean any lint or thread that's caught in there.
5. Locate your machine's oil ports and put one drop of sewing machine oil (only use sewing machine oil) in each of them. One drop is sufficient. General rule of thumb: Put one drop of oil wherever metal moves against metal.
6. Using unwaxed dental floss, floss the tension disks.
7. Put everything back together.
If you need a manual, I found one at http://pages.sewing-machine-manuals.com/173/InventoryPage/1834489/1.html.
Hope this is useful!
Robbie
Posted on Jul 30, 2010
Kenmore Sewing machine 158.523 Does it use flat cams only, or cylinder base ones?
Perhaps this photo may help:
Machine Reviews Kenmore 158 523
Sears Kenmore Heavy Duty Industrial Sewing Machine 158 523 Cam 1 1A 1B
FWIW, it appears to me to take flat cams.
P.S.--keep that lovely lady! She's a gem.. . just keep her cleaned and oiled!
Jan 20, 2016 | Kenmore Sewing Machines
How do I refill the thread bobbin on a Kenmore sewing maching,,model 148-19371
You can try a couple of YouTube videos:
Loading thread on the bobbin old Kenmore sewing machine
(do not wind the bobbin as fast as he does as it tends to stretch the thread and also could cause the spool to fly off the machine!)
How to wind Bobbin Winder Sears Kenmore Sewing Machine 158 12270 158
or order an Owner's Manual for your machine:
... Sewing Parts Online Search
Sep 04, 2015 | Kenmore Sewing Machines
I have a Kenmore model 158.19411 and I want a walking foot for this model. Is this model a high shank or low shank?
The Kenmore 158.19411 uses super high shank presser feet. Sears Parts Direct has the zipper foot still available for the 158.19411. http://www.searspartsdirect.com/kenmore-sewing-machine-parts/6759/0020/158/model-15819411/0582/1220000.html . Other compatible feet are available here: http://www.sewingpartsonline.com/kenmore-158-18023-sewing-machine-parts.aspx . This site also has an adapter for connecting Kenmore-compatible low shank presser feet to the Kenmore 158.19411 .
I hope this helps.
Aug 23, 2015 | Kenmore Sewing Machines
Model #158 12290
http://www.tias.com/173/PictPage/3924074944.html Sorry, Sears doesn't seem to have a free copy of the manual. But Linda at Relics is a very reputable manual supplier.
Feb 05, 2014 | Kenmore Sewing Machines
Kenmore 1792080
go to these sites and contact them about a manual
sewusa.com
a1sewingmachines.com
Jul 26, 2013 | Sewing Machines
I need a down loadable mauel for model 158-14000
I tried for several minutes to find
158-14000at sears parts. It does not recognize those numbers. You might want to call Sears and see if they can help you over the phone.
Sep 15, 2012 | Kenmore Sewing Machines
Looking for the manual for the Kenmore sewing machine model 158.1320
here you go you will need your serial number to match to the specific manual but im putting you in the right direction.
kenmore Manuals
Mar 25, 2010 | Kenmore Sewing Machines
Sewing Machines Logo
27 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
