Lg 20ls7d front green light is on but the screen is black. no sound
SOURCE: LG 20LS7D
It uses a regular power cord, the kind that you would use for a PC.
Posted on Dec 21, 2007
SOURCE: LG LCD TV 32LC4R BLACK SCREEN
same here How do you change the Power regulator?
Posted on Jan 28, 2008
Ajkill
  • 2035 Answers
SOURCE: LG 20LS7D TV
1. Try this - hold the menu button down for 10 seconds. TV should power up; you will have to turn off front panel buttons on menu.
2. You can also try a hard reset: Unplug TV from AC mains and remove all cables from TV. Wait about 30 minutes and replug to AC power and redo the cabling. Switch on the TV and see if it works..
3. Powering down the set or putting it in standby may have allowed the power supply to cool. Weak capacitors often go out of spec when they cool, thus preventing a section of the power supply from firing up properly again. There is a simple trick...just warm the back of the TV with a hair dryer for 5-7 mins after you have unplugged the TV. Look for the little areas of holes in the back panel of TV. Use these as your guide at where to use the hairdryer, but don't hold the dryer too close (say 5-6inches away). (Make sure the dryer is on High heat). If the TV doesn't turn on after you have heated it up (like it tries to come on but then turns off) you need to unplug the TV again, this resets it. And repeat those steps till it works. Resetting the TV after it fails to turn on is the key.
then the fly back unit is failed you need to resolder the contacts or get it serviced...............
Posted on Jun 08, 2008
SOURCE: LG RZ 37LZ55 37 in HDTV LCD Screen Dead
This is likely due to a failed power supply. Replacing the power supply board should solve the problem.
http://www.reviewcentre.com/reviews110919.html
Cr1spy
Posted on Apr 06, 2009
  • 22 Answers
SOURCE: Black screen on a 20ls7d LCD TV
I work at CNN Have had 6 of these monitors go out in as many months. Take out the power supply and change the 2 exploded 680u capacitors. They're being overheated by the underrated MOSFETs on the reverse side of the board. I'm looking for some substitute MOSFETs that handle power better; but replacing the caps will usually fix the problem. Otherwise replace the supply.
Posted on Apr 01, 2010
I have a 15 inch TV LG Smart TV something went out on it what could it be the model number is 50LN5700UH the LG light comes on but no picture
LG TV : Picture not coming on screen, but TV is on. - Forums - CNET
www.cnet.com > Forums > LG
CNETJul 14, 2014 - Dear All, Have a peculiar problem with my LG flat screen TV. It stopped working suddenly, that is no picture when switched on, I noticed the ... However, in my case the RED light keeps on blinking and there is a ticking sound ... LG Plasma Flat Panel 42PC3D - No picture just sound
Jun 11, 2015
No Picture from LG 50PS60 Plasma TV
Nov 16, 2013
More results from www.cnet.com
LG LCD TV REPAIR - NO PICTURE SCREEN FIX REVIEW ...
? 5:29
www.youtube.com/watch?v=PWoz_-3OHIM
Jan 25, 2013 - Uploaded by Tampatec Common LG LCD TV REPAIR - NO PICTURE OR BLACK SCREEN FIX ... came on good with green light working properlybut still no picture.
Oct 20, 2015 | LG Televison & Video
Error on start up
Do you have sound when the screen goes black?
Nov 02, 2013 | LG 42LC7D-UB Television
Screen on LG goes to black right after turned on.
It looks as if the backlights are being switched off at start up, this will be due to a fault either with the inverter board or a fault with the screens backlights which would mean the screen needing replaced. Contact your repair centre to have an engineer give you an estimate on the cost of repair.
Oct 24, 2009 | LG 20LS7DC 20 in. LCD TV
Screen is black even though the green light is lit
Tv has power supply board inside defective. This board needs replaced.
Aug 18, 2009 | LG 32LB9D TV
LG 50PG3000 SOUND BUT NO PICTURE
This sounds like a screen problem, possibly the internal connecting cable (LVDS) which connects from the main board to the screen may have become loose. If not a replacement screen would be required.
Jun 29, 2009 | LG 50PG30 Plasma HDTV
Jun 07, 2009 | LG 20LS7DC 20 in. LCD TV
I KEEP GETTING THIS BLACK RECTANGLE IN THE MIDDLE OF THE PICTURE BLOCKING OUT THE MIDDLE OF THE PICTURE. I HAVE A 20LS7D LESS THAN A YEAR OLD
Hello!! Go into the menu and set "closed captions" to OFF. You have closed captions set to "TEXT".
barneyluc
Oct 01, 2008 | LG Televison & Video
I have an LG 20LS7D flat panel LCD TV. Sound is on but no picture. The problem was intermitent but now nothing but sound. Help
Possibly th emain board needs to be replaced actually you need to check some voltages first but with just a sincere guess signal cba
Sep 26, 2008 | Televison & Video
NO POWER
I ended up unplugging both sides of the power cord (from the TV and the wall), waiting five seconds, plugged it back it, and it worked fine.
Sep 11, 2008 | Televison & Video
LG 20LS7D
Dec 07, 2007 | Olevia LT23HVX 23 in. LCD Television
Televison & Video Logo
42 people viewed this question
Top Televison & Video Experts
