Sony tv kp e41mh11
Tv on standby mode.no disply
ctf1800
  • 4402 Answers
SOURCE: SONY KP-57HW40 TUNS OFF AND STANDBY LIGHT BLINKS 6 TIMES
6 blinks is usually associated with failure of the horizontal deflection amplifier - which shuts down the high voltage system as well.
The repair requires testing to determine the exact parts that have failed. There are, for example, a few hundred parts and a section of the Jungle IC chip involved. So, repairs could require something as simple as replacing some inexpensive passive components OR as complicated as replacing the jungle chip (very expensive).
most of the time it's the horz. transformer and transistor.
Posted on Dec 20, 2007
welcomejee
  • 10594 Answers
SOURCE: Sony KP-46WT520 Standby Blinks 10 Times
High voltage in TV got problem and thats why TV gives 10 time blink error code.
Qualified TV tech will fix it as its bit complicated fix.
Posted on Apr 15, 2009
  • 135 Answers
SOURCE: sony widescreen projection TV -- Model KP-51WS510
The tv is in shutdown protection due to overdriving video signal. If you are handy you can pull the front cover off and there are 6 controls on a HV block. 1 set says focus, do not touch those. One set says screen. One at a time turn them down, counter clock wise putting each one back where you found itTurn the first one down and then turn the set on. Do this for each untill you get a picture. You will most likely find a bad blue gun. You can also remove the board from each gun 1 at a time with the set unplugged and find the shorted gun. good luck.
Posted on May 25, 2009
  • 178 Answers
SOURCE: Sony KP-46WT520 TV won't come on.
That is a diode in the sub power supply, it is a small board with only a few parts on it to the left of the d board, for the zero crossing detector. D6301 sony part number 6-500-567-21
Posted on Sep 02, 2009
Testimonial: "WOW!! Impressive. Thanks for the fast reply"
  • 4234 Answers
SOURCE: Sony kp-46wt520 rear projection tv: standby light flashes
Two things here.
1) This is a CRT based set so there is no "lamp" involved.
2) The standby light should be blinking a repeated count of blinks with a 2 second pause between counts. Please report the exact count here. This will indicate the circiut in which a problem was detected.
With the above information, we can provide you with a more detailed description of the problem as well as the likely solutions and cost.
Thanks,
Dan
Posted on Sep 18, 2009
SONY PROJECTION TV Model KP.E41MH11
Probably have to replace both as a unit. Try Ebay if not available through Encompass or Fox.
Apr 13, 2014 | Televison & Video
Sony Rear Projection TV - KP-46WT500 Screen went blank
When Sony TV gets problem it goes to standby as protection mode and LED start flashing.
Do you see standby light blinking?
There would be 3 seconds interval between blinks so count from pause to pause and let me know.
Thanks.
Sep 20, 2009 | Sony KP-46WT500 46" Rear Projection...
I have a sony KP-57WV600 Big Screen Rear projection television. The problem is this: When I first turn the tv on the picture is fine, than after it warms up- the screen turns red. What would the problem...
Let me know when TV warms up does it go to standby?
If yes, standby light would be blinking, let me know how many times it blinks?
And if TV does not go to standby mode, does picture remain with red tone?
Dec 06, 2008 | Sony KP-57WV600 57" Rear Projection...
Sony KP-46WT520
Replace Diode 6301 and D6116,6117
Nov 21, 2008 | Sony KP-46WT520 46" Rear Projection...
Service menu
How to Enter Service Mode
1. Turn on the main power switch to place this set in standby
mode. (LED will light in red.)
2. Press the buttons on the commander as follows, and enter
service mode.
PRESS these buttons in sequence
ON SCREEN DISPLAY---> (DIGIT 5) ---> (VOLUME +) --->STANDBY
Method of Cancellation from Service Mode
1. Set the standby mode (Press “ (TV STANDBY)” button
on the commander), then press “ (TV STANDBY)” button
again, hereupon it becomes TV mode.
Thanks
Oct 29, 2008 | Sony KP-53HS30 53" Rear Projection...
Sony KP-61HS10 61 in. Rear Projection.
Put tv in standby then press above said buttons. You will be in service mode.
Be Care Full while in Service Mode data handling.
Oct 03, 2008 | Sony KP-61HS10 61" Rear Projection...
Sony kp-53s10
Power supply or scan failure is the usual cause. You will require service for this set.
Jerry G.
Apr 13, 2008 | Sony KP-53HS10 TV
Timer Standby light flashing No pitcher
Sony
Model # KP-53HS10
Serial # 9718217
MFG 2000
Plugged in TV. Timer Standby Light just flashes continusly. No Picture and No Sound.
Apr 02, 2008 | Sony KP-51WS500 51" Rear Projection...
Sony KP-53HS10
The problem seems to be in Secondary supply of Switching Power supply.
Mar 31, 2008 | Sony KP-53HS10 TV
Sony KP-46S17
does the standby light blink?
Nov 09, 2007 | Sony KP-41T65 41" Rear Projection...
Televison & Video Logo
16 people viewed this question
Top Televison & Video Experts
Electro Med Services...
