Question about Plumbing
Corrego faucets manual
We have a leaky handle on our faucet. Where can I get replacement parts for this type of faucet?
  • 148 Answers
SOURCE: Kohler Forte Single Handle Faucet Leaks
you will have to replace the ball assembly with a repair kit
1 turn the water off under the sink (hot and cold)
remove the handle ( you may need an allen head wrench to remove a hex screw or you may have to take a channel lock pliar and unscrew achrome
nut over the ball mechanism
after the handle comes off there is usually some type of lock nut that you must remove to remove the ball mechanism
remove the ball (usually chrome or brass(ther are usually little springs and rubber washers under ball
take ball and washer to ACe or lowes and match the pieces (usually sold as a kit
follow directions and installl
turn water on and pat yo!ur self on the back !
Posted on Jan 05, 2009
SOURCE: kitchen faucet single handle pull-out. The base of
I have the same problem with an American Standard Reliant Kitchen Faucet that wont swivel anymore. I called American Standard and they are sending me the replacement parts to fix it free of charge, I have had mine 6-7 years and they said it was under warranty. Call 800-442-1902. Good Luck
Posted on Apr 05, 2010
  • 94 Answers
SOURCE: leaky moen 2 handle faucet
if memory serve's me,you will need to remove a stem extension,screw in center,and you may need a tool #103462 to remove cartridge.1'st stem ex't is red,(hot) blue (cold), remove, look down,white piece w/ 2 notch'es, this hold's cartridge down, ya might try needle nose plier's to remove,a little lube help's upon re assembly, carefull w/plastic thread's
Posted on Apr 26, 2010
SOURCE: leaky eurostream kitchen faucet
if its leaking under the handle, all you need to do is remove the blue and red cap on the handle under you will find a 1/8 allen screw, loosen screw and remove handle and tighten the brass nut a little which will seat the packing underneath.
Posted on Aug 25, 2010
  • 693 Answers
SOURCE: How to fix a leaky Moen faucet that leaks at the
These faucets can leak in three different places:
  1. Internally at the valve seat
    You'll see water dripping from the spout. This means the rubber washer is worn or damaged. To replace the washer, remove the decorative cap from the handle. Remove the retaining screw and pull off the handle. Remove the decorative cover, called an escutcheon, if there is one. Unscrew the packing nut counterclockwise. Unscrew the valve stem and remove it. Remove the screw that holds the rubber washer in place. Because these washers come in many shapes and sizes, you'll want to take the old one to the hardware store and buy an exact replacement. Be sure to buy two washers so you'll have one for the other valve. Replace the washer and reassemble the faucet.
  2. Around the handle
    If you see water coming from below the handle, the packing nut is leaking. Older faucets have a string-like graphite packing material wrapped around the stem. Newer faucets use an O-ring. First try tightening the packing nut clockwise... about one-half turn. If this doesn't stop the leak, remove the packing nut and replace the packing or O-ring; then reassemble the faucet. If the valve is using the graphite packing material, it might be a clue that you should shop for a new faucet.
  3. Between a pivoting spout and the body
    The spout might be held in place with a packing nut, similar to the faucet stem, or it might have a nut at the top of the spout. In either case, remove the spout and replace the packing material or the O-ring seal. Then reassemble the faucet.
Single lever faucets also are known as "washerless" faucets. They are easier to repair than compression faucets after you determine what type of faucet you have. There are three types of washerless faucets: ball, ceramic disk and cartridge.
Leaks are evident in two places... dripping from the spout and seeping from around the spout where it joins the body of the faucet.
Leaks from the spout indicate that the ball, disk or cartridge is leaking. To repair, turn off the water to the faucet, then remove the handle. The handles on ball-type faucets are held in place with a setscrew that requires an Allen wrench to loosen. Ceramic disk and cartridge-type handles usually are held in place by a screw hidden beneath a cap.
On ball and ceramic disk-type faucets, remove the ball or disk and replace the seals. You can buy replacement kits for these faucets at the hardware store or home center.
On cartridge-type faucets, remove the spout and pull out the retainer clip that holds the cartridge in place. To remove the cartridge, pull on the cartridge stem with a twisting motion. If it resists, install the handle so you can a better grip on the cartridge to pull it out. Take the cartridge to the hardware store or home center and purchase an exact replacement kit.
Reassemble the faucet according to directions.
Leaks at the spout-to-body joint indicate an O-ring failure. Disassemble the faucet as described above. Remove the spout sleeve and replace the O-rings. It's a good idea to replace these seals if you have the faucet disassembled for repair of the ball, disk or cartridge.
Posted on Sep 10, 2011
How do i remove the stem from an Elkay kitchen faucet model # LK7124?
Leaky Elkay single handle kitchen faucet - DoItYourself.com ...
www.doityourself.com/.../292646-leaky-elkay-single-handle-kitchen-fau...
Can I replace the cartridge (A54236R) from our single handle Elkay (LK-6360) kitchen faucet without removing it from the sink top? If so where is the secret inhex ...
Jan 14, 2016 | Elkay Plumbing
How do I fix a leaky, old style, screwless faucet?
there is a screw under the center c or h label,or there is a nut that needs to be turned to take the cartridge out
Jun 08, 2015 | Plumbing
Leaky kitchen faucet
What kind of faucet? (single handle, double hndle, kitchen, bathroom) Where is it dripping from? (handle, aerator or faucet head, under the sink) There are many types of faucets and many types of leaks. Sorry to be so vague but there's a pretty wide spectrum of possibilities, a little more info will go long way.
Feb 04, 2013 | Plumbing
Leaky faucet
Need more info. Is it leaking in between the faucet and hose or the end of the faucet or around the handle of the faucet? If leaking between hose and faucet a little rubber washer will do the trick. If its the faucet it could be inside the faucet. You can buy a new one, or take it apart and take your parts to the local hardware store whom can assist you there. If its around the handle simply tighten screw ontop of handle.
Nov 11, 2012 | Washing Machines
How to fix a leaky Moen faucet that leaks at the spout ,which is separate from the handle?
Sep 10, 2011 | Moen Plumbing
I am trying to fix a leaky danza single handle bathroom faucet. I cannot figure out how to remove any part of the faucet from the top to be able to change the washer.
There is a allen set screw on the handle it may have a cap over it locate it and unloosen screw and remove handle then un screw bonnet nut then replacement kits available at most hardware,home improvement,or plumbing stores take note of how the parts are removed so to reinstall the way they came out.
Jun 05, 2011 | Danze D203112 Melrose Single Handle...
Leaky faucet in shower
delta is one of the better faucets, you can call them and they will send you new cartridges all you have to do is change them and you will be fine,, they have lifetime warranty on there products just give them the faucet number and they will send it to you
Mar 09, 2009 | Delta Victorian 2155-SSLHP Bar Two Handle...
Leaky faucet
Finding brand specific replacement parts in stock for a 20+ yo faucet without a Mod.# is quite the task, implying that you would have to do a side by side compareson/inspection. If in fact that part is not obsolete.
Maybe you should consider replacing the entire faucet.
Good luck
Feb 22, 2009 | Plumbing
Plumbing Logo
53 people viewed this question
Top Plumbing Experts
Donni Steen
Tom Chichester
Are you a Plumbing Expert? Answer questions, earn points and help others
