Simpson Washing Machine SWT954 will not power on.
Purchased in April 2012. The machine was set to do a wash. We checked later and there were no lights showing on the display panel. We have a power surge protector in the power point. Tried switching off and on, and different power points. Still would not show power to the display. Wash was not completed, it seemed to have filled with water and stopped, but I am not sure if any wash action occurred.
  • 1122 Answers
SOURCE: Machine doesnot agitate or drain once filled with water
it sounds like a bad lid switch if it will not drain or spin,the switch controls that-mike
Posted on Apr 24, 2009
barkencoa
  • 3463 Answers
SOURCE: washing machine stops mid cycle and lights start flashing
Drain the water by lowering the hose into a bucket or something and then try it on spin, if it spins o/k then you probably have blocked pump or filter.
The filter is located in the large black hose that is fastened to the bottom of the drum, remove and clean.
Hopefully this will solve the problem.
Plz rate this solution.
Thanks.
Posted on Dec 17, 2008
  • 4 Answers
SOURCE: Simpson washing machine not turning on
check outlet with multimeter for 120 volts .If voltage found check cord for 120 volts .If cord has 120 volts turn on timer jumper lid switch . did this help?
Posted on May 30, 2009
  • 208 Answers
SOURCE: Simpson front loader won't power up !
that wa the first thing that came to my mind i think your on the right track call a service department give them the make model number of the washer they should be able to help you locate a reset switch if it has one . good luck
Posted on Jun 22, 2009
beltronic205
  • 1466 Answers
SOURCE: simpson esprit 550 washing machine stops mid-cycle
Could be timer fault although good chance its stopping as it gets to rinse indicating faulty Solonoid valve..Good luck
Posted on Mar 31, 2010
Testimonial: "thanks for the tip"
Hi i have a 9.5kg simpson washing machine error code PU31 what does that mean as my machine is not spinning out washing
Pump error. It means drain pump is either blocked or faulty. Water is not draining out or very slowly. Water has to all drain away before the machine will spin. Get the water out by lowering the drain hose down into a bucket. When machine is empty then remove and check the drain pump.
Dec 24, 2016 | Simpson Washing Machines
My Simpson (SWT954) top loader washing machine wont empty, it beeps/E20. I've checked the drainage hoses (in/out of the pump)- no blockage. Can anyone tell what to check next, and where is the filter?
don't know much about them. However you can go to you tube, thuis is the link "https://www.youtube.com/watch?v=8n8lxcUf484" and you will see this Phone number 1300 000 500 for 24/7 customer support. Good luck
Jun 21, 2015 | Simpson Washing Machines
Simpson encore 503 washing machine
Hello:
The first thing to check is at the water inlets, normally these have screen in them. If the screens are clogged no water will flow.
Jan 07, 2014 | Washing Machines
Simpson eziset 750 manual
Hi our eziset 750 simpson washing machine has stopped working. It randomly just turns off and then will start again few days later. Cheers
Aug 28, 2010 | Washing Machines
May 30, 2009 | Washing Machines
My simpson espirit 700 has been in storage for
check first the continuity of the power cable. next is the fuse if it is not busted. then try to open the control portion there might be some coroded contacts.
Apr 07, 2009 | Washing Machines
Simpson 175 HD washing machine Programme keeps stopping Is it the timer or some other problem
image_bubblequestion_04.gif Can you please identify the problem with my washing machine?It appears all the functions of my simpson 175 washing machine work normally except the agitator only moves briefly and harshly for between 1 and 2 seconds.
Simpson 175 HD (Dual Action Agitator) Washing Machine.
1517 5M40 A 28 June 1990
Jul 12, 2008 | Washing Machines
Washing machine defaults to clean washer option
Sounds like user interface board. Try unplugging the machine, press power button for 3 seconds, plug machine back in and try again. If this does help, it will probably be a temporary fix. The user interface board is the one mounted directly to the console.
Sep 04, 2007 | Kenmore Oasis HE 27082 Top Load Washer
Washing Machines Logo
159 people viewed this question
Top Washing Machines Experts
