Question about Ovens
Hi there we have a tricity fanfare double oven and dont know how to change the striker pin. It's really old, we think its ftom 1960/1970 but still works. We need to get inside the side of the oven to put the new, slightly larger pin in. Thanks in advance.
2 Suggested Answers
barkencoa
  • 3463 Answers
SOURCE: SMEG DO4SS-5 double oven not heating up
If the fan is running, then it is safe to say that the oven element has gone.
Replace with a new one,(element that is).,
Plz rate this solution.
Thanks.
Posted on Dec 15, 2008
Tricity double oven
Hi Les. We had a tower oven with three ovens! One oven we constantly used had the element distort, and it had to be replaced.
Most likely the element is on its way out. If you have a multimeter, you can check the voltage supplying the element.
You will need to find the make, model number, and maybe the serial number of the oven to progress.
The details may be inside the oven door or on the rear of the oven. Do a google search, and you should be able to find replacement elements, and a local supplier of original parts or aftermarket replacements.
Jan 29, 2014 | Ovens
Hi I have a Bosch Double Oven/convection Oven I
Don't know but have you tried the old tea towel in the corners trick to see if its the hinge alignment and not the seal? Put two tea towels in the lower corners sticking out of the oven part way and push the oven door closed a few times. Saved me from trying to replace the seal.
Oct 04, 2013 | Ovens
Manual for tricity contessa cooker, double oven and grill with slow cooker button. Just brought this reconditioned cooker, but it hasnt got a manual and I need one. I can't get the oven to turn on, it...
i have a vey old tricity contesssa cooker(which i love!)
The rings are heating but the oven and grill have stopped working,any suggestions on how to fix please??
Oct 08, 2011 | Ovens
Thermostatic switch fo 30 year old tricity marquis double oven the oven heats up but the temperature control does not work.
More than likely a faulty thermostat, I doubt you would get a replacement for a cooker of that age.
I would recommend that you seriousyl think of replacing the cooker.
Dec 09, 2010 | Ovens
Oven door won't stay closed
You don't state the exact model but on every oven I've ever fixed this problem on it's a broken door striker catch. Depending on your model, the catch will either be in the oven door or in the oven body; usually they're straightforward to replace but on older ovens spares can be almost as rare as dodo ****. Usually what breaks is a hardened tempered metal spring, so when they're not available as spares I can usually visit a local spring making company and get someone to make one up as a one-off using the fragments of the old one as a pattern. After the catch has been replaced the striker itself (usually a specially shaped pin) may need to be adjusted to engage correctly once more. Undoing the lock nut and screwing it in and out adjusts the depth, and is done after the striker catch has been adjusted side to side or up and down to meet the centre of the striker.
Mar 04, 2010 | Imperial Ovens
I have a very old tricity double oven with a top part and bottom part of the oven it doesnt have a hob as thats separate.It has three nobs to the left that are for the grill, the lower oven and the main...
I think I might have a manual for this oven! Is it a built-in job with the grill at the bottom and main oven at the top, made by Thorn Tricity?
Aug 07, 2009 | Ovens
Tricity president double oven
if this a uk model and less than 15 years old you can ring tricity,they should be able to supply you with a manual
www.tricity-bendix.co.uk
Mar 06, 2008 | Ovens
Ovens Logo
24 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
