Question about Garden
Lazy boy tiller md 12013 style LT5054
Looking for chain for transmission
5 Suggested Answers
  • 8404 Answers
SOURCE: i have a lazy boy tiller the belt keeps slipping
As your tiller ages and as you use it, the belt stretches. There is also some wear on the inside of the belt. These belts take a beating, by the way. Your tensioner should be spring loaded and should accomodate some stretching.
My suggestion is to tighten the tensioner to match the specifications the manufacturer lists in your owners manual. If you dont have the manaual, tighten it slowly until it stops coming off ... or ... replace the belt.
I hope this helps you.
A
Posted on Sep 22, 2009
SOURCE: I have a lazy boy tiller with chaine drive, its
The gear box can be removed, reset and resealed using gasket magic. It is not a quick fix and during this process I also replaced the tine shaft seals as I had lubricant leaking from the gear-box to the tine shaft. When you are tilling you should avoid rocky areas. It iseems sudden tension due to bouncing is what knocks the chain loose.
DO NOT remove the belt pulley from the top of the gear box. It is unecessary. You must remove the entire assembly from the rear of the machine. It is set in place by 6 bolts and come off as a whole unit. Once it is removed then undo the three bolts and spacers that hold the case in place. Remove the case from the frame by sliding it out the open end. You will have to remove all of the bolts around the outside of the case; a cordless drill really comes in handy here. Lay the case on its side, as you remove the bolts you may experience lubricant dripping from the centers of the removed bolt holes, or at the center holes where the case connected to the frame. This is not a problem as you will need to replace the 90 weight lubricant after you have resealed the case anyway. Once you have removed all of the bolts, using a flathead screwdriver and a mallet or hammer. break the seal around the outside of the case. You may have to go around a few times, but eventually it will pull apart revealing the sprockets, bound chain and remaining lubricant. Since it is open this is an ideal time to check for wear on sprockets and remove any large debris from the case. reset the chain so that the tine shaft moves freely and the corresponding sprockets spin as you move the tine shaft. Using a gasket sealant (Gasket Magic**) put a thick bead of sealant in the center of flat outside edge where the two sides of the case come together. Add a little extra around bolt holes. Replace the two covers snugly together and begin finger-tightening the bolts back into the crank case. Once you have completed this task, go back over the bolts and tighten with a hand wrench. Once the case is back together allow 45m to an hour for the sealant to completly harden before introducing lubricant to the system. Then reattach the case to the rear assembly and then put your tiller back together.
This occurrence seams to be an issue with these machines, however the problem is avoidable as it is persistant use in rocky or hard ground areas which causes causes the system to jump and bind. If you happen upon a hard patch of earth or rocky area, go slow, do not force the tiller and remove any large debris when possible before tilling.
Posted on May 08, 2010
  • 430 Answers
SOURCE: I have a lazy boy front tine garden tiller. i want to have the proper amount of 90 wt gear oil in the transmission. I can see one hole with a plug that says gear oil. Do i fill the gear box up to tha
ITs not really a lazy boy brand is it? If we a re talking about garden tillers... then if the fill hole is on top the oil level should be about 1 ( one) inch below the hole. If the hole is on the side of the gear case then it is a peep hole and should be filled till fluid runs out.
Posted on Oct 25, 2012
  • 3698 Answers
SOURCE: what size belt for lazy boy tiller
www.hyperparts.com/ope/LazyBoy-oem-list.htm
Posted on Jul 06, 2014
How do I keep the tiller from bogging down when it goes in the dirt.
Adjust the depth bar on the back higher and push the handles down to rasie the tines somewhat.
Sep 12, 2014 | Garden
What size belt for lazy boy tiller
Jul 05, 2014 | Garden
Lazy boy recliner with heater an d massage: I
Sorry we do not have any wiring diagrams for this chair here.
Apr 14, 2017 | Coaster 500663 Tri-tone Lazy Boy Style...
I have a lazy boy front tine garden tiller. i want to have the proper amount of 90 wt gear oil in the transmission. I can see one hole with a plug that says gear oil. Do i fill the gear box up to that...
Oct 24, 2012 | Garden
How can I properly clean my new Lazy Boy recliner?
I have located a great article that explains how to properly care for your Lazy Boy recliner to keep it looking nice and ensure that it will last longer.
http://ezinearticles.com/?How-to-Clean-Your-Lazy-Boy-Recliner&id=1829676
Aug 09, 2012 | Furniture
The tiller wont engage the transmission but it clicks into the FORWARD, NUTRAL,REVERSE
You may have a chain driven transmission and the chain is broke inside the transmission. Get your model number off the tiller and go to www. searspartdirect.com. Put your model number in and look at the IPL to see if they break the transmission down in several parts. If not you may have to replace the whole transmission.
HTH
Good Day.
Oct 25, 2009 | Craftsman Garden
I have a lazy boy tiller the belt keeps slipping off the tensioner
A
Sep 22, 2009 | Garden
Rototiller transmission
I am having transmission problem (loud noises). I am looking for a repair manuel for a roper rear tine tiller. Model RT150GR chain drive.
Mar 27, 2009 | Craftsman Garden
Garden Logo
111 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
