Question about WSM 1995-1997 Kawasaki Zxi 900 Cc Jet Ski Motor Mount
Kawasaki serial number jh900a-600673 does this give me the year of the jet ski as i have just bought this through a car disposal company
I have just bought a kawasaki jet ski zxi 900 and want to find out what year it is as i need to get some parts for it
I have a 1987 Kawasaki js550 Jet Ski with low compression. it has 170 in the front piston and 50 in the back what could be done besides having a stuck piston ring?
You will have to pull the engine out and rebuild the top end. You will probably have to bore the cylinders. Purchase a piston kit that comes with gaskets and seals. Reseal the crankshaft with the new seals and your motor should be good for another 23 years.
Oct 22, 2010 | Encore Software Kawasaki Jet Ski...
Kawasaki jet ski starter motor removal
To get access to the starter you will probably have to lift the motor out of the machine. Most Kawaski hulls do not give you much room to work. When you take the exhaust off you may have enough room to unbolt the starter.
Aug 24, 2010 | Encore Software Kawasaki Jet Ski...
''how to replace starter in 1993 jet ski''
Unbolt the electronics box (swing out of the way), take off the box mount plate, and remove the exhaust upper manifold and expansion chamber. This should give you good access to the starter.
Jul 04, 2010 | 1993 kawasaki ZXR 400
How do you replace a starter on a 2003 kawasaki 1100 jet ski
You will have to unbolt and move the electronic box, unbolt and remove the upper exhaust manifold, and the expansion chamber . This should give you access to the starter underneath.
Jun 01, 2010 | Encore Software Kawasaki Jet Ski...
I have a 1995 kawasaki zxi the bolts on top of
The numbers on the head are the torque pattern/order. Two stroke motors generally use a torque value of 18 to 22 foot pounds on the head bolts/nuts.
Feb 01, 2010 | Encore Software Kawasaki Jet Ski...
ISchematics for 89 kawsaki jet ski
Go to the site below where you can see a parts diagram for your specific WATERCRAFT. You will select the actual brand, year, model, etc., once you go to the site. Part numbers and prices are also shown. You can order parts from this site. In the event no price is shown on a particular part and/or the notation "Not Available" is in the description, the part is not in stock. www.babbittsonline.com/pages/parts/viewbybrandand/parts.aspx
If looking for an electrical schematic this site will not help. You will need a service manual for that.
Aug 20, 2009 | 1981 kawasaki KZ 1300 A3
WSM 1995-1997 Kawasaki Zxi 900 Cc Jet Ski Motor Mount Logo
49 people viewed this question
Top WSM Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a WSM Boating Expert? Answer questions, earn points and help others
