I sure hope you got an awesome deal on that refrigerator. I would hate to think they charged extra for the mouse :-) Unfortunately, the ice bucket in this model does not just slide out like your other one did. You should be able to remove the front cover & flap of the ice bucket to reveal the ice maker and yes, it is bolted in. below is an exploded parts diagram of the ice maker. As you can see, the whole thing can be taken apart - of course you then have to put it back together. If it were me, I would toss it & replace the ice maker rather than try to disinfect/ sterilize the one in there. Good Luck!!
What you think is probably correct. Water valves can seep water and freeze the fill tube. Remove the ice maker and the fill tube remove ice from the fill tube and replace the water valve.
If the ice maker has completely stopped producing ice.
Check to see whether the ice maker has been turned
off. Here's how to check. Look for a wire along the right side of the
ice maker that looks a bit like a coat hanger. If this wire is in the
raised position, the ice maker is turned off. On some units you simply
lower the wire to the down position to turn the ice maker on. On others,
you lower a small red plastic lever to lower the wire. If the wire is
in the proper position check the freezer temperature, it should be
between 0-8 degrees Fahranheit. If it is warmer than 10-12 degrees, the
ice maker may not produce any ice. Check your door seals and thermostat,
repair/replace as necessary.
If the ice maker is producing ice poorly.
When an ice maker is producing ice poorly--when it
produces just a few cubes or none, or when the cubes are too
small--it's usually because of a clogged water line or a defective water
inlet valve. First, check the water line attached to the back
of the refrigerator for good water flow. To do that, first turn off the
water supply valve. Then remove the water line from the back of the
refrigerator. Next, place the water line into a bucket and momentarily
turn the water valve back on to test the flow. If the flow is poor, you
need to repair, clean, or replace the tubing or the shut-off valve that
supplies the water. If the flow is good, you may have to replace the
water inlet valve.
Not sure what setup your ice maker has to let it know when the ice tray is full, but some ice makers have a bail that goes up with rising ice levels. When the ice bucket fills up, the ice maker shuts down. Lifting the bail up all the way until it catches on a small ledge turns this type ice maker off. If ice is allowed to stack in the bucket too high, or is shoved back as someone scooped out ice, the bail may inadvertently have been pushed onto the ledge. Bottom line; check whatever method your ice maker uses to turn off ice production when the bucket is full to see if it is in the OFF position.
When an ice
maker is producing ice poorly--when it produces just a few cubes or
none, or when the cubes are too small--it's usually because of a
clogged water line or a defective water inlet valve.
First,
check the water line attached to the back of the refrigerator for good
water flow. To do that, first turn off the water supply valve. Then
remove the water line from the back of the refrigerator. Next, place
the water line into a bucket and momentarily turn the water valve back
on to test the flow. If the flow is poor, you need to repair, clean, or
replace the tubing or the shut-off valve that supplies the water. If
the flow is good, you may have to replace the water inlet valve.
hi my name is mark, do you have a water filter on this unit. shut off water to ice maker. remove water line from ice maker, hold water line in a bucket slowly turn on water. if you get water. then the fill solinoid has failed. if you do not get water trace water line back to water shut off. if it is the solinoid valve. you will need model and serial number to order part
well i dont know if you still need help or you already solve it. when i repl repl the ice maker it works on all GE'S you probalbly bought part #wr30x10061 right that is all you need some older model have diferent ice maker that were mechanical this is an electrocnic ice maker is ok if you just repl it just use the extension if you need to coonect the wire harness
