Question about Garden
Lawn boy 10685
No spark - LV195EA bought coil #1A138-52-12-5109
  • 208 Answers
SOURCE: can't get my lawn boy started
check for a faulty wire to the engine kill switch it may be contacting the ground
Posted on Jun 22, 2009
  • 3600 Answers
SOURCE: lawn boy mower bought used wouldnt start then the rope broke
there are 3 bolts that you remove and thatwill allow the coil houseing to come off pull off buy new rope and wind the rop onto the rope holder then roll the spring to it's tighest postion put pull handle on and tie know it rope burn the end of the rope with a lighter to keep it from comming apart, be sure to thread the rope threw any holes before tieing knot. then replace it back on and bolt it together. and your set.
  • 7 Answers
SOURCE: Tecumseh LV195EA Starts then dies.
If the engine is running at all then your sensors should be ok. It sounds to me like its starving for fuel? Once the engine runs out of prime then it starves. Does the fuel system have a shut off valve? How about an inline fuel filter? Either could be plugged. I think what you will need to do is remove the carb from the engine and check to see if its clean and if fuel from the tank is flowing easily to it. Once you have the carb off the engine, remove the bowl from the carb by removing the bottom bowl nut. Use a small can or an ash tray to hold the small pieces. Shake the float back and forth to see if there is anything in it. Some floats are plastic and some are tin. If there is any liquid inside the float there is your problem. Otherwise continue on with your diagnosis by using a bread bag wire, minus the outer covering, and a little jet spray to probe and clean the internal jets. Pay particular attention to the center main jet which will have a small perpendicular air bleed hole near the bottom and to the air vent hole that is on the face of the carb where the air cleaner mounts. Any tiny piece of chaff will cause these to plug. For reassembly, the inlet needle slides into the float, and they are held to the casting by a pin. You can push the pin out with a small screwdriver and then grab it with a pair of needle nose pliers to get access to the float. Finally, check the O ring for cracks that goes between the bowl and the casting. This is an easy job, just take your time. Lawnboys are one of the better machines.
Posted on Aug 31, 2009
  • 89 Answers
SOURCE: what locks in the left and right torsion springs
the proper set up on thre bar which hols thr springs is plate lock handle part 107-3946 then the right hand torsion spring 108-0953,make sure the spring hooks over the plate lock, then left hand torsion spring then bar slides through left hand hole and lever release 40-1823-03 attaches to end of bar with a set screw
Posted on Nov 04, 2009
SOURCE: The rear wheels will not turn in reverse at all. I
Rear wheel drives like this have pinion gears with rachet pawls that allow them to go backwards freely while locking when the transmission drives them.
You need to take off your rear wheels and carefully remove the pawls. They look like little squareish metal shaft keys with springs under them. You should notice that the keys or pawls are covered in what looks like grease.....which is actually worm metal from the pinion gear and oil mixed together to form this pastey greasey substance. Clean all that stuff off and lightly oil *( light oil...3 in 1 kind of oil) and reassemble.
You should hear the nice clean clicking of the rachet pawls as you roll backwards again!
Good luck and be careful!
Posted on Jul 01, 2010
How to test a Lawn Boy ignition coil
you will need a spark test about 10 to 15 dollars hook the tester to it on the plug try to start it watch to see if it sparks the other way is to do without spark tester is to pull the plug out and lay it on engine block try to start it and watch to see if plug sparks
Aug 07, 2014 | Tecumseh Lawn Boy Push Mowers Insight...
Have Lawnboy Kohler 149cc smart choke 6.5ft lbs engine bought last year won't start doesn't seem to be firing?
REMOVE THE SPARK PLUG, RECONNECT THE CABLE AND WHILE THE SPARK PLUG IS RESTING ON THE BLOC OPERATE THE STARTING PROCEDURE AND SEE IF THE PLUG IS SPARKING.
May 09, 2014 | Tecumseh Lawn Boy Push Mowers Insight...
I have a Lawn Boy 10685 with a Tecumseh motor will it run with rear mulch switch off and either wired together or left open?
If you are getting spark, it should run, usually safety switches connect to ground out the coil to give no spark.
Apr 17, 2013 | Tecumseh Lawn Boy Push Mowers Insight...
Replaced keyway but lawnmower still will not start.
The last one I worked on needed a new coil, was not getting spark. Check to see that yours is getting a spark, also check to see that the coil is close enough to flywheel, since you changed the key way. I assume that you removed the flywheel.
Sep 13, 2009 | Tecumseh Lawn Boy Push Mowers Insight...
Garden Logo
87 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
