Question about FixYa Computers & Internet
How to become a fixya tester - FixYa Computers & Internet
  • Official Brand Answer
  • 322 Answers
Currently we are not using outside testers but we appreciate your offer.
Posted on Jul 14, 2014
I tried to apply for your tester offer, your site won't accept my email
probably because fixya site doesn't have a tester offer
Oct 20, 2017 | Computers & Internet
Tip
Checking Relays (and fuses)
This tip is useful for all types of vehicles:
If you think that you may have a bad (burned out) relay: before you go buy a new one: purchase (if you don't have one) a fuse tester.
1. Disconnect the battery.
2. Pull suspected "bad' relay
3. With fuse tester adjusted accordingly:
a. make sure relay is not melted, or coming apart
b. With the two prongs on the tester, touch two prongs on the relay until the light on the tester comes on. There is no way of knowing with two are the live ones except by touching two together.
c. If the light comes on, you're good to go; and if not...well, you know...replace the relay.
Thank you for checking out the tips at fixya.com.
carsandcomps
Guru, fixya.com
Oregon
on Apr 13, 2009 | 1998 Plymouth Grand Voyager
Have spark with plug out. no spark with plug in . What is causing this
It sounds like the spark is weak and is breaking down under compression in the cylinder. Your spark should be fat at blue, when the coil is failing it becomes thin and white.
Dec 13, 2015 | Garden
Replaced dryer drum bulb but light won't come on
First, test the bulb you just installed to make sure it works. Assuming it is a 110-120v bulb, you should be able to do this with any standard lamp in the house. If it's good, next test the socket in the dryer to make sure it has electricity going to it. Do this with a multi-tester and please be careful -- this is a live circuit. Set the tester to its highest AC Voltage setting. Touch the center "button" of the socket and with the other tester probe, touch the outer screw-in shell. It should show 110 to 120 volts. If no power, you'll need to break into the back and make sure all wires going to the socket are connected . . . which may have become jostled.
Aug 20, 2014 | Kenmore Dryers
How long does it take to become a fixya expert
How long did it take you to answer the first question?
You become a Level 1 Expert by getting at least one point. You become a Level 2 Expert with one hundred points, and a Level 3 Expert with one thousand points.
See http://www.fixya.com/FAQ.aspx
Jan 03, 2014 | FixYa Service
How to preform a compression test on a valkyie
Remove the spark plugs. Using a screw in compression tester, screw the tester into a plug hole and tighten it slightly. Open the throttle and crank the engine about six full revolutions. Record the reading and proceed to the next plug. Do the same on all the plugs, recording the readings and cylinder number each time. That is all there is to it. If you can only obtain a press in type compression tester it becomes a two man job as one person has to hold the tester while the other holds the throttle open and cranks the engine.
Mar 22, 2011 | 2001 Honda Valkyrie Interstate
Insatllation
You have switch-plug combo.
1) Screws are color-coded.
Dark screws, brass screw, silver screw.
2) Electricians don't guess, they test
-Separate wires for testing. Do not untwist any wires that are twisted together. Note which wires were connected on same screw on previous device.
-Tape tester leads to wood sticks to keep hands away from power
-Turn power ON
-Test each wire to bare ground wire.
-Tester lights up on Hot wire. Hot connects to dark screw.
-Hot is identified.
-Test Hot to all other wires, except bare ground.
-Tester lights up on Neutral. Neutral connects to silver screw.
-Final wire goes to Load (light, fan, motor). This wire connects to brass screw.
3) Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, expert speaks with you over phone while you work on circuit or any do-it-yourself project.
Fixya is always less expensive than a service call.
Jan 24, 2011 | Leviton Decora Combination Switch - 5625-I...
I can't seem to get my T5225 combo outlet to work. I connected it as directions said but only the light switch works, I tried changing it around & the outlet only works when the light switch is turned...
Electricians don't guess, they test.
Remove device.
Use ordinary 2-prong tester.
Tape wood sticks to tester leads to keep hands away from power.
Turn on power.
Tester will light up on Hot wire. This wire connects to dark-colored screw.
Hot is identified.
Now test Hot wire to each other wire in box, including white wires in back of box (exclude bare ground wire)
Tester will light up on Neutral wire. Neutral wire connects to silver screw. This will complete circuit to receptacle part of device.
The last wire goes to Load (light). This wire connects to brass-colored screw, and will complete circuit to light..
You can also take advantage of fixya phone support.
Fixya expert will walk you through the steps shown above for a price.
Dec 24, 2010 | Leviton 5225WSP Switch and Outlet
Where can i download
Minefield is currently not released but you might be able to become a pre-release tester. Please go here for more info; http://quality.mozilla.org/
Mar 03, 2009 | PC Chips M810DLU (M810DLUV75C) Motherboard
87 nissan pathfinder head lights
have you check the ground on that side of the light. it could be not properly grounded.
if there is no good ground, what would happen is that one bulb would become a ground for the other to light low where as the other one would not light anymore.
tnx again 4 using fixya,
drcool
Oct 24, 2008 | 1987 Nissan Pathfinder
Computers & Internet Logo
Top FixYa Computers & Internet Experts
Mark Magill
Mark Magill
Are you a FixYa Computer and Internet Expert? Answer questions, earn points and help others
