Question about SanDisk Sansa e200 MP3 Player
Wont Turn On
I connected my new Sanisk Sansa e200 mp3 player to a speaker system and it seemed to be working fine. i left it for a while and when i came back to it the mp3 was turned off, i just presumed the battery went dead, i plugged out and turned off the speakers and the mp3 blue thumbwheel light flashed. when i tried to turn the mp3 on it wouldn't work, i have connected it to the computer to charge it but its just dead, i pressed the power button for 30seconds to reset it but theres still no change. how can i fix it or is it irrepairably damaged? Help!!
I had the same problem with no power. Take out the 4 screws, take out the battery, clean your connections with an eraser, re-assemble it and it should work.
Posted on Sep 24, 2007
SOURCE:
Sansa e260 volume will not work?
try this...
1 put on hold and hold record button while u turn on (your sansa is now in recovery mode)
2 connect your sansa to your comp via usb cable a box should show up saying the firmware version
3 close the window and disconnect your sansa (it will restart)
Mar 10, 2009 | SanDisk Sansa e200 MP3 Player
Sansa e200 is not recognized by by computer
**** this sansa e260 the piece of **** froze on me twice and both times i took it back to circuit city and just got a new one. one suggestion when you do get this is keep the repeipt for it
Mar 31, 2008 | SanDisk Sansa e200 MP3 Player
Sansa e200 4 gb wont turn on
1-866-726-3475 Sandisk Customer Support
www.sandisk.com
click on support at the top; click on MP3 players,
find your Sansa and click on it there’s a lot of info
Mar 09, 2008 | SanDisk Sansa e200 MP3 Player
My sansa e200 wont come on
try geting a new charger that what i did and it work
Mar 07, 2008 | SanDisk Sansa e200 MP3 Player
Wont turn on
Try to do a manual reset for your device.if that doens help you might have to replace the device...
Jan 04, 2008 | SanDisk Sansa e200 MP3 Player
No Drive on Connection
Hi, When i connect my sansa e200 mp3 player with my computer..it showing CONNECTED on the mp3 player screen, but does not show any disk drive in my computer. No problem with computer, my pen drive is working fine with it. can someone help?
Dec 08, 2007 | SanDisk Sansa e200 MP3 Player
Won't load main screen
Use volume + method:
These are the most common methods for recovering Sandisk's Sansa Mp3 Players. I have been almost universally successful in recovering Sansa players using one or a combination of these methods. These methods do not work if you are having synchronization or music format issues - they are for recovering a player that will not power up, freezes, flashes, is not recognized by the computer, and a host of other issues.
Reset the Sansa Player first. On most models, restart is done by holding the power button in for 15 seconds or longer. Check your specific manual to be sure. The manuals are available from the Sansa website if they have been misplaced.
Download the Sansa Recovery Tool from the Sansa website.
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/DriverDownload/driverList.asp
If these fail, then:
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
If you get the problem where MTP Device keeps popping up continuously, uninstall the “MTP Device” by going to Start à Control Panel àSystem à Hardware à Device Manager (you computer may vary slightly, depending on Windows Version).
You may have to restart your computer after each of these methods to get them to work properly. Disconnect your Sansa player BEFORE shutting down your computer.
-Tha Mp3 Doctor
Sep 07, 2007 | SanDisk Sansa e200 MP3 Player
My computer wont detect my e200
Dont turn it on and plug it in. That had happened to me and that fixed it.
Aug 31, 2007 | SanDisk Sansa e200 MP3 Player
Sansa e200 wont load music
Check if the player is in Autodetect/MTP then try retransferring the songs on the player. And before unplugging the player from the computer check if the files are transferred to the player click on the sansa e200 player on the left window to check if it had really transfferred the songs to the player. If it still wont work, try trasnferring songs using windows media player.
Jul 21, 2007 | SanDisk Sansa e200 MP3 Player
SanDisk Sansa e200 MP3 Player Logo
64 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Joe Negus
Joe Negus
Ekse
 Ben
Ben
Level 1 Expert
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
