Question about Hayward Pool & Spa
Pool boss will run on manual, will not run on auto. Red error light comes on, on the circuit board, pool pump relay clicks and pool pump turns off. I can not figure it out.
PartsCenter
  • 125 Answers
SOURCE: We just moved into our home and there is no manual
Here is a link for the Manual and trouble shooting guide. Aqualink
Posted on Mar 04, 2009
john224
  • 1378 Answers
SOURCE: 1 year old hayward h1001d pool heater clicking
Actually, the clicking is likely causing the shaking. Inside the manifold of a H100 is a stainless steel diverter plate that send some of the passing water into the heat exchanger and lets the rest past and back to the pool. When it breaks, you will hear a 'clicking' noise at it rattles in the water path. When it breaks, the flow to the heat exchanger is intermittent and you will begin to boil the water, causing the shaking. This situation is dangerous, especially without a pressure relief in the heater or pipe. As long as your water chemistry is sound, Hayward will usually cover this under warranty even if the unit is over a year old. Contact them to get a factory authorized repair rep out at: http://www.haywardnet.com/locator/
Posted on Jun 12, 2009
  • 139 Answers
SOURCE: Service light comes on our Raypak RP 2100 pool heater.
this usually indicates a high limit condition.you must first ascertain if you have a component failure or a true high tempature condition.your model has 2 limit controls and they are both located in side panel on water in/out header
Posted on Sep 19, 2009
  • 5 Answers
SOURCE: I have Jandy RS4 system with 4-button poolside
Pull the cover off the control panel. You will probably find a button which would be accessible from outside the panel with a paper clip or pencil but is unlabeled. On the board itself by the button, in small letters it should say "reset". Push the button and see what happens.
Posted on Oct 09, 2009
thepool
  • 78 Answers
SOURCE: Pool Heater with communication (CE) Error
Code "CE" stands for communication error and describes a fault between the mother board and the display. I doubt it's the relay causing it though...
Posted on Apr 23, 2010
Motor red error light comes on, pump won't turn on
if power to motor bad pump motor if no voltage to motor bad relay
Mar 01, 2015 | Marathon Electric Marathon imPower...
Pool pump would not start , flashing red error light
Could be many different things. Shaft locked up? Low voltage? Bad start relay. Bad start windings. Red light signifies what? Have an operators manual? Hard to say at a distance.
Dec 03, 2014 | Pool & Spa
Problem with jandy rs 4. Pool heat pump Is running. We didn't turn it on and the heat pump light on the control panel is not lit
Does your pool gave an attached spa?
IF it does have a spa, dies it also have a spa side remote?
If so the first step would be to unplug the spa side remote from the back of the board.
If the issue stops then you need a new spa side remote if it persists then it nah be be main circuit board or relay for the heat pump.
Nov 01, 2014 | Jandy AquaLink RS 4 P or S OneTouch Pool...
I just replaced my circulation pump on my hot tub and now all I get is a clicking sound when I power up the tub the display works fine
That clicking sound you are hearing is probably coming from the relay on the circuit board.
The issue may not be with the circ pump but rather the circuit board.
Most of the time a customer will replace the circuit board because it has gone out but the circuit board will go out most of the time because one of the pumps or heater causes the relay on the board to go out hence once the put the new circuit board in the pump or heater now doesn't work. This is because that item was having a problem and caused the circuit board to go out.
Rod
US Parts Center
Mar 11, 2014 | Pool & Spa
Spa quip hot tub error code 07 stuck relay
Bad relay on the circuit board will require a new circuit board.
Rod
US Parts Center
Apr 17, 2013 | Pool & Spa
Hot Spring Spa pump won't run just click on circuit board....
Check for voltage at the pump, before assuming the relays are out... then check for voltage before and after the relay contacts
Apr 08, 2010 | Pool & Spa
Feb 15, 2010 | Hayward H-Series 200k BTU Millivolt Heater...
Pool pump starts & stops on its own outside of programmed run
There are several potential problems:
  • freeze protection circuit causing pump to start - could be a bad outside air temperature sensor.
  • It is possible the new relay is bad.
  • There could be a short in the control wires to the relay
  • old programming shadow stuck in memory (not likely since you changed the boards)
Yes, the starting and stopping can harm your pump.
Jun 04, 2009 | Pentair 1hp Whisperflo Pool Pump In -...
Pool & Spa Logo
44 people viewed this question
Top Hayward Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
john h
Are you a Hayward Pool and Spa Expert? Answer questions, earn points and help others
