Can done one help me to solve tej?a error on The c252 bizhub code c4551
Can done one help me to solve tejía error on The c252 bizhub code c4551
    New Friend:
Printer will not print
Posted on Aug 12, 2013
  • janetlee Aug 12, 2013
SOURCE: konica minolta bizhub C252 printer Problem
Is anyone else having problems getting Konica to stand behind its products.
Posted on Dec 20, 2007
SOURCE: renolio
your problem maybe caused by a thermistor near the pressure roll in the fusing unit (the red roll).
Try the follow procedure and if it doesn't fix call minolta service.
1. Turn OFF the Main Power Switch.
2. Turn Main Power Switch ON while pressing the Utility/Counter key.
3. Touch [Trouble Reset].
4. Check to make sure that [OK] is displayed and the it has been reset.
5. After turning off the Main Power Switch, turn it on again more than 10 seconds after
and check if the machine starts correctly.
Posted on Mar 30, 2008
jqsababa967
  • 145 Answers
SOURCE: KONICA MINOLTA
CD231 at power up.
Solution:
CAUSE: Complete fax kit was not installed.
SOLUTION: These three items make up the complete fax kit, FK502, MK706 and MK704. If not installed together, the C250/C252 will display code CD231.
hope that helps
Posted on Nov 04, 2008
herminio_hal
  • 210 Answers
SOURCE: Bizhub Konica Minolta - Error Code C1183
First check the alignment front and rear of the finisher, check the finisher exit guide rollers if the paper is exiting properly, open both rear and the front cover and check the lower gears attach is the up/down drive belt. that lower gear one might be broken by the pin slot.
Posted on Jul 09, 2009
nchalabe
  • 4 Answers
SOURCE: Printing accurate colors from Corel draw to the Minolta Bizhub C252
HI there i have the same printer and for accurate color i follow this steps:
1 - First publicate you work in a pdf file whit high quality
2 - Go into adobe Acrobat (profesional not reader only) and pres print
3 - Then you have to select in advanced settings and select icc profile "sRGB ..."
4 - You´ll notice that the colors are very real. No oversaturated and the real deal are the fonts that prints correctly in border even if they are very small (- 6 pt.).
5 - RECOMENDATION: For intense black use a compost one 100% in every color or select in the color palette the one at the end of the palette
Greetins.
Nolasco from argentina - DPI Grafica
Error c252
no such code for bizhub c252
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Apr 01, 2014 | Konica Minolta bizhub C250 All-In-One...
Error code c252
Main Motor failure to turn, PROBABLE CAUSES:
1. The main motor (M1) has failed.
Replace M1 (p/n 4038 M101 00). If the problem persists replace PWB-M (p/n 4038 0101 05 for bizhub C250 and p/n 4038 H001 01 for bizhub C252
Jan 27, 2014 | Konica Minolta bizhub C250 All-In-One...
Konica minolta C252 error code C9401
my machine konica minolta C252 is giving the code 9401 how should I resolve and what is
Jan 30, 2012 | Konica Minolta bizhub 250 All-In-One Laser...
KONICA MINOLTA
CD231 at power up.
Solution:
hope that helps
Nov 04, 2008 | Office Equipment & Supplies
Konica Bizhub's Trays
You will need to go to the printers folder under Start, settings, & select the C252, right click on it, select properties & go to the 'Option' tab.
In here input the C252's IP address into the 'printer name or IP address' field and select gather option information.
Once done you will need to apply the settings and ok.
If you dont know the IP address you can get it by going into Utility, user settings, print reports, config page.
You should now be able to select the correct trays without errors.
Hope this Helps.
May 13, 2008 | Konica Minolta bizhub C250 All-In-One...
Error Code C-2152 wen i power the machine at begin this messge was apear c-2152
what model bizhub you have, 350 B/W or some other? cant find this code for this machine. sorry
Apr 24, 2008 | Konica Minolta bizhub 350 All-In-One Laser...
Bizhub 250 scan to email error
Try re-entering user name and password or try a different user name and password for email account saved in the machine.
Jan 25, 2008 | Konica Minolta bizhub C250 All-In-One...
Trying to use photo copierfrom the touch pad
eee, what version machine you have ?
C252 is copier
C252p is a printer version without copy function
what are you trying to to? copy ? scan ? print ? fax ?
Nov 29, 2007 | Konica Minolta bizhub C250 All-In-One...
94 people viewed this question
k24674
jasbo
jasbo
