Aiwa tv model c142ker no remote locked
Ajing aft problem showing on tv screen, remote not working any button
  • 1694 Answers
SOURCE: Locked out of TV
Use two buttons on the tv at the same time, hold four seconds.
Try menu & power or vol up & chan up.........
Posted on Nov 04, 2007
techman
  • 3130 Answers
SOURCE: FPA Locked ON
Most RCA and GE TV sets use a four digit code to control the v-chip. The code reset procedure is different depending on the model. Try each method until you find one that works:
  1. Hold down MENU on the remote and VOLUME DOWN on the TV it’s self at the same time for at least 4 seconds. The set won't say so, but the lock will be unlocked
  2. Hold down the 0 on the remote and the VOLUME DOWN buttons on the TV its self at the same time for at least 4 seconds. The set won't say so, but the lock will be unlocked
  3. Hold down the MENU button on the front of the TV and the TV button on the remote at the same time for at least 4 seconds.
  4. Hold down GO BACK on the remote and MENU on the front of the TV at the same time for at least 4 seconds.
  5. Hold down EJECT on the front of the TV and the MENU button on the remote at the same time for at least 4 seconds.
Depending on the model, one of the methods should unlock the V-chip. Now, if desired, you can change the settings on the V-chip by going to the MENU and going to PARENTAL CONTROLS, or on some sets, going to MENU and then going to TV SETUP, then to V-CHIP SET.
Posted on Jan 24, 2008
BFixed
  • 104 Answers
SOURCE: Phillips 28PW6006/05-Locked
First you need to get your remote working, without it you cannot unlock the tv. If the romote is not phisically broken (or smashed) make sure the battery contacts are clean and install new batteries.
Once you get the remote working (hopefully) Enter the MENU and select 'Features'. Set the Child Lock to OFF. If you cannot get the remote to work try a universal remote, setting it up with the codes for your tv provided in the setup manual for the universal remote.
Posted on Mar 18, 2008
mfspencer
  • 58 Answers
SOURCE: TV Locked
I hope this helps, these unit were made by akai: here is the akai fix for this problem. Hold down the "F" button on the remote (top left button) and press the mute button. This should make the key go away. Thanks
Posted on Apr 02, 2008
SOURCE: Unlock TV
use the music button on the remote
Posted on Dec 17, 2008
How do you remove "Key Lock" in Coby TV model LEDTV2928T?
Control It All With Universal Remote Codes ยป Digital Landing
www.digitallanding.com/control-it-all-with-universal-remote-codes/
Oct 22, 2012 - Why not set the universal remote codes and make life easier? ... Here are some GE codes for some of the more popular TV brands: ... Aiwa-0414; Coby-0926, 0946, 0947, 0916, 0445, 0928, 0894; Denon-0400, 0421 ...
Aug 12, 2015 | Coby Televison & Video
Why my aiwa TV -A209 is locked on one channel?
Main system control IC fault. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Sep 05, 2014 | Televison & Video
Tv error codes
This problem has been answerd a few while ago.
May 17, 2013 | Aiwa Televison & Video
My aiwa tv has been locked through remote......so what can i do?
With the TV turned on, simultaneously press VOLUME down button on the front of the TV set and the number 7 button on the remote control to reset pin code and customer ID.
Dec 27, 2012 | One For All URC-4330 Remote Control
My aiwa tv a 219 remote locked how to open it.
Aiwa television comes with the option of blocking certain channels from viewing, allowing you to control which channels people using the television can view. However, if you forget the code that you entered to block the channels, you might find yourself unable to watch those channels. Fortunately, there are a couple of buttons on the television and the remote that you can press to reset the PIN and customer ID numbers, which unblocks the channels.
Turn the television on.
Press the "Volume Down" button on the front of the TV and press the "7" button on the remote at the same time.
Enter in a new PIN code and new customer ID.
Oct 30, 2012 | Aiwa Televison & Video
I forgot my aiwa digital 40 lock password , & it lock rightnow what can i do ?
Hello
Just try this method to overcome the situation.
With TV turned ON simultaneously press "Volume Down" button on the front panel of the TV set and digit "7" button on the remote control to reset the pin code and customer ID. You have to reset the pin code and customer ID after this process. This must solve your Aiwa TV problem. OK.
Feb 27, 2011 | Aiwa Televison & Video
Dear Sir, I have AIWA A219 TV. No remote functions are working, even manual switches are also not functioning, It got stuck on One channel, The error which is coming on screen is AGING 1724H Plz...
Dear Sir, I have AIWA c142ske TV. No remote functions are working, even manual switches are also not functioning, It got stuck on One channel, The error which is coming on screen is
Oct 12, 2010 | Aiwa F2000 20" TV
Aiwa TV MODEL No. TV-A149 AGING
I have Aiwa TV MODEL No. TV-A149
The problem that I am suddenly facing is that I can't change channels or volume or use any other function. I can't even turn it off with remote control.
Its stuck randomly on a particular channel that I was watching at that point of time.
Along with that channel it now shows a message in flashing red color that reads :-
AGING
6EDEH
Now when I press ''Display'' button on remote control volume goes off and this code is shown :-
S123 K234 Y
100 000 0
The numbers in the second line can be navigated by ''CH+'' button and changed between 0 and 1 by ''Vol+'' button.
I really don't know anything about this. So, please help me out of this problem.
Sep 14, 2009 | Aiwa TV-S2011 20"
Aiwa GX1100 VCR
When safe show on the screen, it actually means that the child lock feature is on.
All you have to do is press the child lock button again on the remote and it should flash "OFF" on the screen.
Hope you have the remote :)
Sep 13, 2008 | Aiwa Televison & Video
Televison & Video Logo
24 people viewed this question
Top Televison & Video Experts
Electro Med Services...
