Question about Garden
Murray push mower
How do I cable to the engine stop lever on my 2003 22" Murray lawn mower, model # is 222210X48A
tmandink
  • 30 Answers
SOURCE: What spark plug should be used for a Murray Quantum XNP 6.5hp mow
Home Depot has the plug you need for briggs 6.5hp engines. Don't worry about it being a Murray. Buy a Briggs 6.5hp plug.
Posted on Jun 26, 2009
  • 68 Answers
SOURCE: Murray 4.5 hp Q lawn mower runs rough and smokes.
White smoke indicates that it is burning oil. The smoke would be black if it was running rich. So probably the rings will need to be replaced eventually. These mowers are prone to problems but the carbie is least likely to be the problem. So before you adjust the carbie take the cover off the top and give it a good clean and check that all the hoses are connected and are not cracked. Then make sure the airfilter is clean, blow it out with an air compessor or better still get a new one. Then try it out agian. If this doesn't help there is two screws on the carby marked L and H. Turn these only 1/8th of a turn at a time and note or make their current position. Start with the H scew with the mower at full revs. Turn anti clockwise untill you get max revs then turn it back a bit. Running too lean will over heat the motor and damage it. Then if needed adjust the L (or Low)screw. If you get black or grey smoke when you push the throttle up from idle to full its too rich so turn clockwise. If if slows before it picks up to full revs turn anti clockwise.
Posted on Sep 06, 2009
SOURCE: Need manual for Murray 20'' 3.5 hp lawn mower
sounds like its running out of gas. I changed spark plug, still sounds like its about to die
Posted on Apr 29, 2010
hunter19_46m
  • 7482 Answers
SOURCE: I can crank my murray gas lawn mower 6.5 quantum
Sounds like you will need to clean your carburetor.
Sometimes you can get by with priming it a few times, and letting it
run a few times like that and it will flush the gunk out of the jets,
but most of the time you will need to rebuild the carburetor.
If the mower is over a couple years old, then I also recommend that you
buy and install a new carburetor repair kit, because the diaphragm will
get hard and that will cause it to be hard to crank.
When you clean your carburetor and remove the jet screws, count the
number of turns it takes to seat the jets from their original position.
That way when you go to put the jets back in, you know how many turns
they were in/out.
Please rate me, Thanks
Good Luck, I hope this helped
Posted on May 15, 2010
  • 29 Answers
SOURCE: I have a Murray 6.0 hp 20 inch push lawn mower. Ho...
If there is a dip stick add some oil check the level till you get to the full mark. It should take a little more than a quart. If there is no dip stick then there is an oil fill plug down low on the engine. Fill slowly until the oil reaches the threads in the engine housing (almost overflowing). Be sure to replace the plug or you will have oil everywhere when you start it.
Don't just dump the oil in, check the level as you go!
Posted on Jun 04, 2010
I have a Murray 20 model 20213A with a Tecumseh engine. The lawnmower will start but it dies a few minutes later. What could cause this and where can I get a manual for this model lawnmower?
Use high test fuel without ethanol, and
Murray 22" Lawn Mower - Carburetor Cleaning, Nasty ...
? 7:33
www.youtube.com/watch?v=_dzcDZUh1MY
May 10, 2013 - Uploaded by mountainbikekayak But here is the link for the start up of this Murray had to replace the plug as well also ... as well: Murray 22" Lawn Mower 6.5 HP OHV -- First Start after Carburetor Cleaning - Part III - May 9, 2013 ... When I start it, it runs for 3-4 seconds and dies. ... Youcan also find you engine Model # online and view the ...
Sep 09, 2015 | Tecumseh Garden
Murray model series 760 lawn tractor speed control. Tractor won't move.
Well the lever is obviously not reaching the motor so fix the lever
Feb 18, 2015 | Murray Garden
I have a self propelled Toro walk behind that does not have a throttle control. Stalls out if grass is just a bit high. How/ where do I adjust throttle
Most new mowers do not have a throttle adjustment, the motor has a govnor that helps the motor speed up when the load requires it. The first thing you should check is that the blade is sharp which makes it easier to cut the grass. If the grass is still too high for the motor to keep up, it's usually easier to raise the deck (lower the wheels) so you are not cutting as much grass on each pass. Then lower the deck to where you want the grass height to be and make a second pass.
Jun 06, 2011 | Toro Power Lawn Mower
Murray ridinglawn mower will not start..everything is new
sounds like you have a safety switch issue, i am the proud owner of 3 different Murray mowers, you have a seat switch, a blade disengage switch, and a clutch pedal switch, depending on model and year, unplug one at a time and re try, need anymore info, email me, niteman87@aol.com :) hope that helps,
May 23, 2010 | Poulan 42-Inch Steel Deck 17.5 HP Briggs &...
Have a murray model 226111X92B 22
go to this website http://www.ereplacementparts.com/murray-226111x92b-2234-lawn-mower-parts-c-17887_17944_19048.html and find the part your looking for. i went to the site and found what you are looking for..good luck
Apr 05, 2010 | Mtd 22" Yard Machine Push Mower
The mower deck drive belt slipped off the idler pulley on my 42'' Murray riding mower deck because the idler pulley was worn out. I need to know how to loop the belt back around the pulleys after I replace...
Get the model number off the tractor, go to:
www.murray.com
enter the model number and you will find a manual with pictures of how to route the belts along with a lot of other good information
Sep 30, 2009 | Garden
Replacing the self-propelled belt on my Murray mower
Here is the link to the parts list for your mower. Though it doesn't give instruction for replacement, it does show an exploded view of the components:
http://www.outdoordistributors.com/pdf/Murray/MURRAY-MODEL-22646X92A-WALK-BEHIND-MOWER-(1999)-PARTS-LIST.pdf
I hope this helps...
Good luck
Jul 15, 2009 | Garden
Jun 26, 2009 | Garden
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
