Hi, if you are unable to run the XP setup again and you have a lot of datd you wish to save, then a good method is to purchase XP PRO, when you run this you will get the choice of running the upgrade version, choose this , it will then load and you just need to follow the prompts and you will not loose any of your data. Regards mistyman
Was this solution helpful? Show your Appreciation by rating it:
Something is not right with your XP installation.. try to re install them... If you are using XP home edition with SP2 you can run them direct from CD ROM.. I assume you know how to do this...
