Question about Rheem M206A 206K BTU Pool and Spa Propane Gas Heater
I HAVE A YEAR OLD RHEEM POOL HEATER PARTS ON THE DISPLAY NUMBERS WERE NOT SHOWING AND TODAY NO DOSPLAY AT ALL
    Top Expert:
  • Rheem Master
  • 8,686 Answers
Check transformer
Posted on Nov 05, 2017
  • 11 Answers
SOURCE: Pool heater sparks but does not light up
coud be several things, Do you have Gas and is gas toruned on. Is valve on. The Pilot could be dirty and need cleaned. $350+ sounds reallly pricy for a pilot assembly. Call your Gas Company and get an Estimate and a Qualifed Service tech. You may try turning Off the Power to the Heater Unit and turning it back on , and then trying to turn on heater again, So times after several atemps the valve will lock out and the power needs reset on Propane units.
Posted on Jun 29, 2010
macdirk
  • 116 Answers
SOURCE: I have a Rheem raypack pool and spa heater. I have
Error Code ROL is "HEAT ROLL-OUT SAFETY SWITCH OPEN". The heater is equipped with a cutoff device to prevent flame roll-out in the event the heat exchanger becomes blocked. This is either a "manual reset", or "Single-use" type fusible link/thermal fuse, that must be replaced or reset after any over temperature conditions have been fixed. Excessive restriction in the heat exchanger flue passage may cause the switch to disable the heater. I don't know your exact model so I'm just generalizing. If you reset or replace the switch, and it trips/burns out again, then you need to address what is causing it. make sure the heater is cleaned out well and no debris is blocking the flue. I fthis doesn't help you can always try calling Raypak Service department at (805) 278-5300.
Posted on Sep 20, 2010
john224
  • 1378 Answers
SOURCE: What is the manufacture year of the rheem
What is the serial number? The 337A series has only been around since the end of 2004 so it will be somewhere in the last 5 or so years.
Posted on Oct 27, 2010
Testimonial: "thanks. I'm selling it and the buyer wanted to know the manufacture year, and I couldn't find it anywhere on the rheem website. I appreciate your help"
adamh294
  • 310 Answers
SOURCE: Rheem 266K to 399K BTU Swimming Pool Natural Gas
ROL code means Rollout.
This heater used a one time use switch in the cabinet on the left hand side.
The switch will look like a ceramic oval disk about 1.5" in diameter. It will have two wires coming from it.
This switch is one time use because it mean your heater is getting a bad burn. This could be happening due to:
1. High wind situation (could be random)
2. Incorrect gas supply
3. Incorrect venting (if indoor)
4. Obstruction on top of the burner tray.
There was a recall on the refractory kit with some of these models, causing the fire walls to crack off and fall on top of the burner tray. Thus causing the flames to rise too high inside the cabinet and therefor trip the rollout switch. The timeline for the recall matches your heaters date.
E-mail me if you need more help.
ahudson43@yahoo.com
Posted on Dec 29, 2010
  • 366 Answers
SOURCE: PROPANE RHEEM POOL HEATER IGNITES AND HEATS UP,
sounds like you have a bad thermal governor (regulates water temp inside the heat exchanger) or your pH has been to high and your exchanger is completely scaled up.
Posted on Aug 18, 2011
My heater is displaying a sensor failure message
Year, model, and size of the heater.
What is the error message exactly?
Oct 31, 2014 | Rheem Pool & Spa
Rheem pool heater there's no power to the display
ensure proper supply voltage to the heater....either 12 or 240 vac. display screen should get 24 vac.....if screen is supplied 24 vac then replace the display screen board.....if not getting 24 vac problem is occuring before display screen
Sep 13, 2013 | Pool & Spa
Rheem digital gas pool heater fan code
The Fan code would indicate a problem with the combustion air blower. The is a pressure switch to indicate there is sufficent combustion air, and if not then unit shuts down. Either the fan isn't running, or there is an obsturction in the fan or exhaust piping, preventing enough air flow.
cfh would be call for heat, which would be a normal display when water temp is below setpoint
See the link below for a manual. Once you open the page look on lower right side for documents, then install manual
http://www.rheem.com/product.aspx?id=2388EEB7-3DEC-4601-AE76-EC7A07F17630
Jul 04, 2010 | Solar Rheem Gas Fired Pool & Spa Heater...
Rheem model p-m266a-en-c digital gas pool heater runs, shuts down
CFH is call for heat not sure what spk is, but will find out and let you know.
Jul 05, 2009 | Solar Rheem Gas Fired Pool & Spa Heater...
Rheem M206A 206K BTU Pool and Spa Propane Gas Heater Logo
95 people viewed this question
Top Rheem Pool & Spa Experts
Steve Slater
Gene Haynes
Tom Chichester
Are you a Rheem Pool and Spa Expert? Answer questions, earn points and help others
