Question about Baumatic BWE41BL Wine Cooler
Beaumatic wine cooler
Won't cool properly
Wine fridge is not getting cold anymore
Its really hard to determine without proper diagnosis, but are you sure it indeed has a compressor? does it run ? Does it have a circulating fan inside? A lot of the wine coolers I've dealt with were "Peltier" coolers. They use electronics to cool usually only to about 10deg below room temp. They require a load ( in this case wine bottles ) to operate properly. They don't have a cold control like a refrigerator.
Jun 30, 2014 | Koolatron KWD28SN 28 Bottle Compressor...
Beeping will not stop on wine cooler - red wine side
Beeping usually indicates that something has gone wrong. Probably not cooling properly. The water coming out would indicate that the unit has defrosted. Turn the unit back on again and see if the red side is cooling properly. Some wine fridges have independent evaporators which allows different cooling temps in different parts of the cabinet.
Jun 26, 2014 | Danby DWC2727BLS Silhouette 54-Bottle...
Wine cooler doesn't cool
I recommend that you maybe add more details to your question so it will be easier for Experts to understand the question and answer it.
Oct 06, 2012 | Kalorik WCL-20629 18 Bottle Dual Zone Wine...
I live in a small apartment in New York City and don't have a lot of space for a wine cooler. Can anyone suggest a good cooling system for my situation?
You should get a countertop cooling fridge. They are very compact, about the same size as a microwave oven, and can hold up to 20 bottles of wine.
Jul 31, 2012 | Furniture
Do I need a wine cooler to store my wines or can I store them in a normal refrigerator?
The purpose of a wine cooler is to store wines at their proper temperatures in a proper manner. Wine coolers are set to higher temperature ranges than other systems simply because wine should not be kept as cool as other beverages.
How do I know whether a thermoelectric cooling system is better for me than a compressor?
This depends on several factors: how much wine you keep on hand, where you will be putting the cooler (cool/warm room in the house) and if you are buying a freestanding cooler/built-in. If you never have more than two cases, plan on keeping the cooler somewhere it won't get too warm and you want a freestanding cooler, you should look into purchasing a thermoelectric cooling system.
Cannot get Danby Silhouette 166 dual wine cooler to change temperature. It stays at 70 (both upper and lower). Can you help. Just bought used brought it home and it won't cool.
I also just brought home a used Danby Silhouette 166-bottle wine fridge and it is not cooling. Did you have someone come look at yours and did you get it fixed?
Jul 13, 2011 | Danby Silhouette® DWC276BLS Wine Cooler
Haier wine cooler won't cool
Does the unit cool at all? If it is running and not cooling properly, check and clean the condenser coils on the back of the cooler.
Jan 25, 2011 | Haier BC112G Wine Cooler
Wine cooler doesn't cool properly
Few things to check here. If the compressor is not running then the problem may be a bad thermostat or the compressor start device (ptc starter). Most common would be the thermostat on wine coolers. Also need to check if the fan is running. If everything is running then you have a sealed system problem. If the fan is the only thing that is not running that will cause a no cool situation.
Oct 07, 2007 | Marvel 61WC Wine Cooler
Baumatic BWE41BL Wine Cooler Logo
19 people viewed this question
Top Baumatic Refrigerators Experts
Sal DeAngelo
Colin Stickland
Colin Stickland
Electric Dime
Electric Dime
Are you a Baumatic Refrigerator Expert? Answer questions, earn points and help others
