Sears Item# 00875370000P | Model# 90365N2-01-KD
Assembly directions
I need info and / or the Safety chain-break bolt for Sears Craftsman chainsaw Model#358-350-180. Ser#00269D-202413. The machined-treated bolt/nut attaches part#530-054620 to the saw. My#7013884769.
I don't see the part number, 530054620, you've given for the 358.350180 chainsaw. Sears Parts Direct has the diagrams here: http://www.searspartsdirect.com/model-number/358350180/0247/1503220.html . I believe you need part 26 on the chain saw diagram. That is part # 503210619 and costs $4 from Sears Parts direct.
I hope this helps.
Aug 20, 2016 | Cars & Trucks
With my door closed, i push door button to open and the chain and opener continues inthe closing mode. any help?
Shop for sears craftsman liftmaste... on Google
Garage Door Opener Gear...
$31.45
Sears Parts D... Liftmaster 41C4220A Ge...
$21.75
Preferred Do... Chamberlain/l... Sprocket, Gea...
$17.95
eBay Direct Replacement f...
$20.95
Moving Up G... Liftmaster 41c4220a gea...
$31.67
North Shore... Search Results
    Liftmaster Gear And Sprocket Kit 41c4220a Chamberlain ...
    www.sears.com/search=liftmaster%20gear%20and%20sprocket%20...
    Searsmore info. + -. Chamberlain LiftMaster 41C4220A Gear & Sprocket Assembly Kit. $31.40 ... Chamberlain Sears Craftsman Liftmaster 41A2817 Gear Kit. $27.65 ...
Jan 10, 2016 | Sears Craftsman LiftMaster Chamberlain...
Sears Craftsmen Poulan leaf blower model 358.797770 How do I gain access to starter pulley assembly and spring?
Not an easy job to get to on this Weedeater made blower; have plenty of work space and a very good memory. It requires removing blower end which you will end up disassembling the whole casing.
When re-assembling don't over torque the fan mounting nut as it will cause the flywheel to bind.
Here is a link to the parts diagram at Sears Direct.
http www searspartsdirect com Craftsman Leaf blower Parts Model 358797770...
Nov 29, 2014 | Garden
Hello, we have a Kennmore ultra wash model 66513482k900. The problem is it will not run through any wash cycles at all. It will not do anything, we can select nothing on the panel. We have replaced the...
The symptom your describing certainly sounds like this is a fill overfill circuit problem. The fact that you can only drain the unit and nothing more points directly to a fill overfill problem.
If the overflow switch is activated that is exactly what the unit will do. The overflow switch is item 11 this link:
http://www.searspartsdirect.com/partsdirect/part-model/Kenmore-Parts/Dishwasher-Parts/Model-66513482K901/0582/0130000/K0908008/00006?blt=06&prst=&shdMod=
(PART NUMBER: 8268909)
Additionally if the float is stuck in the UP positon from food particulate build up on the stem it will not fill with water ever. The float assembly is item 13 of the above link. You can clean up the float assembly and the float switch most of the time and get the unit to perform normally. Occasonally parts are required but on a 2 year old unit I seriously doubt either part has failed. Just clean them up and test again. I think this will resolve the problem.
I just have issues with Sears in home service not even considering either float assembly or the overlow switch as the most probable cause of your symptom. In all seriousness if Sears was the reason for having a control panel change you have the right to ask that the part be removed and your original control panel re-installed. Your money and labor expended installing the control panel should be refunded refunded.
You really need to get in touch with the Sears Service manager and tell that person you want a competent technician that will correct the problem. I.e. do not send the previous tech out for any reason other than to reinstall the old control panel. After that... send someone else but fix it. Had you called me and I had one of my techs change a control panel that did not fix the problem the tech would be working that job for free..... The only thing you would be charged for on a call back would be labor to install any additional parts and the cost of that part. NO SERVICE CALL charges on a call back. (Just my 2 cents)
Check the float switch POWER REMOVED... by gently raising and lowering the float. You should hear a click near the top of the float travel and again as the float lowers. The over-flow switch works in the same manner. Clean up the stem on item 13.... below link and it should work.
http://c.searspartsdirect.com/lis_png/PLDM/K0908008-00006.png
Thanks for choosing FixYa,
Kelly
Sep 22, 2011 | Kenmore Dishwashers
How to change a gas range model # rga724pkwh to L.P.?
Contact Sears Parts Direct and inquire about this conversion kit
It's item # 999 on the diagram
http://www.searspartsdirect.com/partsdirect/part-model/Hotpoint-Parts/Range-Parts/Model-RGA724PK1WH/1811/0124002/H0902294/00001?blt=06&prst=&shdMod=
Part # WB28K10414 Is about $60 so the price is about right for what you're looking to do
Jul 20, 2011 | Hotpoint Ovens
Lookin for manuel for riding lawn mower model # 917.254410
Are you looking for a user's manual or a parts manual?
If your looking for a parts maunal you can go to this page and enter your model number: http://www.searspartsdirect.com/partsdirect
your model number
917.254410
They usually have user's manuals there that you can order. The manuals are listed in the parts list. Sometimes it is the first item on the parts list. Other times is is the last item on the parts list.
The Sears Direct site is currently down for weekend maintenance or I would list both of the manuals for you.
May 30, 2010 | Garden
Where can I get replacement disc pads for a Craftsman 3-D Sander (bar code number on box is ''D9M11633''). I bought replacement pads about 3 years ago at Sears, but I can't find them now).
I have purchased similar replacement discs from Kingspor's Woodworking Shop. Contact www.woodworkingshop.com
Item KD60120 for 120 grit
Item KD 60100 for 100 grit
Item KD 80100 for 80 grit
Jan 01, 2010 | Craftsman 0.5 amp 3D Sander
Craftsman Rear TIne TIller Handle
BAD NEWS, I WENT ON LINE TO SEARS PARTS AND THE HANDLE ASSEMBLY HAS BEEN DISCONTINUED AND NO REPLACEMENT MENTIONED
Sep 15, 2009 | Craftsman Garden
Power OFF button doesn't work; unit keeps running, overflows, and doesn't stop
I have the same problem! The "pcb" referred to in the previous reply is undoubtedly what Sears refers to as the "COVER ASSEMBLY, DISPLAY", part number 3551A20109B. It is possible, but highly unlikely, that the defective part is the ESCUTCHEON, p/n 3831A20079D. Sears lists the cost of the COVER ASSEMBLY, DISPLAY as $17.25 plus, undoubtedly shipping and tax. The part seems to be available only from the Sear Web Site under "PArts Direct". This dehumidifier is a piece of garbage. I previously had to replace the SENSOR ASSEMBLY, p/n 6877A30013L. This item turns off the unit when the water tank is full. This dehumidifier has my room flooded - twice - when the unit failed to turn off and overflowed.
While under waranty Sears/Kenmore attempted to repair the unit five times. They never succeeded and when the warranty ran out they would not repair the unit unless I paid for it. Thats when I started doing my own repairs!
Oct 01, 2008 | Kenmore 54701 Dehumidifier
Washing Machines Logo
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
