Psb subsonic 5i schematic diagram
The fuse blows as soon as I turn on the sub. I even tried a 2A fuse when it is supposed to take a 1A. I have a PSB Subsonic 5i
3 Suggested Answers
SOURCE: PSB Subsonic 6i
Check the power cable.
Posted on May 24, 2008
SOURCE: How do i connect a psb subsonic 3 to a luxman
You can Hook the sub up to the b speaker channel
Posted on Feb 04, 2010
My NAD C326BEE amp goes into protection mode at moderate volume
The protection only should come on, when the power amplifier has to give more current than it can deliver. (electronic fuse)
If in the music is a lot of subsonic, sound, so low you can't hear and your speakers can't produce, this could cause the problem. Normal CD players will cut of all frequencies beneath 20 Hz, but it could be your PC is giving everything from 1 Hz and above.
I would certainly try to play some music over a CD player and check if that would solve your problem. Not sure if that works, what you could do to suppress the sub sonic in the computer music.
Aug 22, 2012 | NAD C326BEE Amplifier
Where is the fuse located
look in back then try a site for subwoofers.
Aug 12, 2012 | PSB SubSeries 5i Subwoofer Speaker
I have a PSB subwoofer 6i and the fuse keeps blowing every time it is renewed.
I have two in my shop right now. The power supply is to blame with these two. the manuf. has used some type of epoxy to hold down components before wave solder. This is in the high volt side of the switch mode power section right on top of the bias components . This epoxy breaks down and becomes resistive to the components below causing a direct short. There was a company years ago that had this problem with the same epoxy. A real stupid move then and a real stupid move now. If your power board is burned due to this problem your unit may not be able to be serviced. Solution is to change the supply. Of course the supply is 3/4 the cost of a new sub. Another real stupid move.
This opinion was provide by THE GREAT OZ.
Mar 29, 2011 | PSB Image Sub Sonic 6i Subwoofer
I have no green power light on my subsonic 5i which screws do i remove to replace a fuse inside
Make sure you the plug eorks before you do anything. Plug in a lamp or something. The fuse is inside where you plug the input.
Sep 01, 2010 | PSB Alpha Sub Zero Subwoofer
I need an owners manual replacement...lost the manual during a move and need to hook it back up.
the user manual for this speaker is not avail on line for download, but u can request a copy from PSB SPEAKERS at the web link below by email.
http://www.psbspeakers.com/contact
You can also call them at:
Tel: (905) 831-6555 • Fax: (905) 837-6357
Jun 04, 2010 | PSB Stratus Subsonic 7 Subwoofer
PSB Sub 5i-Starts to rumble continously when the stereo is off
Had this same problem with a Yamaha sub. Unfortunately it's the amp section in the sub. If they can't fix it in the shop (problem is they don't leave it on long enough for the problem to return), the only option is replacement. I buy exclusively on AmEx cards, because they cover this kind of stuff - an additional 1 year warranty on anything you buy.
Apr 18, 2017 | PSB Alpha Sub Sonic 5 Subwoofer
No LED light on PSB Alpha Subzero-i and keeps blowing fuses.
Others have had similar problems with the amp on this model. There is probably a circuit design error which causes some components to blow and as far as I've read, fixing it (or replacing the fuse) won't make the problem go away for long. Try contacting PSB or the retailer.
Dec 02, 2007 | PSB Alpha Sub Zero Subwoofer
76 people viewed this question
 Grubhead
Grubhead
