Question about NEC DTL8R1 Cordless Phone
New Phone everything hooked up just as the last phone was showing disconnected on the new cordless handheld
2 Suggested Answers
  • 11 Answers
SOURCE: My cordless phone in my restaurant is finally had
No, You must use an Nec telephone, thus the price. If you need it on one line only you could connect any cordless phone on the dial tone before the NEC system. This will ring and also you can call out but you will not be able to transfer from or to it and you cannot use any NEC system features.
NEC $279.45 from me gregdownes@verizon.net
Posted on Jan 11, 2011
The handhelds wont charge
they might need new batteries .
Feb 28, 2016 | Lands Phones
HOW DO I REMOVE A CORDLESS PHONE AND SET UP A NEW ONE?
disconnect the base phone at the wall socket and put the new base phone line into the wall socket
follow the user directions that came with the new phone to set it up
Oct 19, 2015 | Uniden DECT 6.0 Cordless Telephone...
Why is there no display on base phone ?
if you have had the phone for a long period of time the display on the top part of the phone witch shows name, date,and phone number under the speaker is gone it is best to buy a new phone there is no way to replace this for a cheap amount they have handheld cordless phones you can purchase at wal*mart for the same price of the repair hope this helps you understand a bit more on why your display isn't showing .
Jun 23, 2014 | Lands Phones
Phone line is busy, but the cordless phone is hung up
If the line is busy, there's a phone off the hook somewhere or there's a bad phone jack or line cord. If this is the only phone on the line, disconnect the AC power adapter from the base and also disconnect the battery in the handset. On both units, press a couple of buttons to drain off stored charge. After a minute or so, reconnect the battery and base power, and see if the line is free. Sometimes, especially in hot weather when lots of people using air conditioners or storms can cause power line glitches, the computer in the phone gets confused. This process resets everything and may clear up the trouble.
If you don't have another phone and the trouble continues after trying the reset, see if you can borrow another phone from someone for testing. If that fixes the trouble you need a new phone.
Your phone line itself might have a problem that is causing your phone service provider to think your line is in use. There may be water in the line or some other fault outside, or some problem on your inside wiring. (A friend had a problem after she plugged in a new phone, and it turned out one of the prongs in the jack had bent and was touching the one next to it. In another case, a phone jack that had gotten wet had corroded and was shorted.)
If you have other phones on the line, disconnect them all from their jacks. Reconnect one and see if the line is free. Then you can reconnect the others, checking each time. This will let you determine which one is causing the problem.
This kind of problem can be frustrating, but it can be solved. Good luck, and thanks for using Fixya!
Aug 03, 2011 | Vtech 5867 Cordless Phone
Bluetooth prob
Last I checked, Zodiacs are not phones, but are able to connect to a bluetooth enabled phone. Google a chord for it, Google is always your friend.
Feb 05, 2010 | Tapwave Zodiac2 Handheld
I am having problem with my cordless phone.
Another tip is to remove the battery from the handset for at least 5 seconds. You might want to get a voltage meter and check the voltage on that new battery - maybe it isn't charging properly.
Mar 13, 2009 | Uniden Cordless Phone
GE Model 29265 Trimline Memory Phone
I just purchased the Trimline Model 29265 phone and in the instructions it says that it can be wall mounted if you reverse the handset hook in the base? Where is the handset hook and how do you reverse it. Nothing in the instructions tells you where it is nor how to fix it.
Mar 19, 2008 | Thomson 26943GE1 Cordless Expansion...
I dropped my phone in the toilet it was only in there for like 2 seconds. i switched the power of and tryed to try it i took everything out of it and dryed it. now my phone will not switch on for more than...
I just purchased a EX1 5560 Uniden telephone (cordless)
The face does not light unless a call is incoming. Is this normal. My other phone showed a constant readout.
Gayl Swartz
gayls@cwbanker.com
928-634-8660
Feb 26, 2008 | Lands Phones
Model28112 series cordless phone multi phones 4 total
This does not sound good. If you have one working phone and you have swapped batteries around and still the same single phone works.... you know it's not the base unit, charger stands, power supplies or batteries. You have eliminated everything but the phone itself. Unfortunatley these low end cordless phones cannot be expected to last. 6 months is pretty bad but I'm not surprized. These sell for $30 each new and I bet a replacement battery is $20.
Jul 01, 2007 | GE 28112 Trio Cordless Phone
Cordless phone doesnt disconnect?
one thing you could check immediately is the filter, they do go faulty sometimes, just swop it with another one that you know is a good one.
Jan 06, 2007 | Uniden TRU8885-2 Cordless Phone
NEC DTL8R1 Cordless Phone Logo
Top NEC Lands Phones Experts
Brian LaDuca
george  peters
george peters
Are you a NEC Lands Phone Expert? Answer questions, earn points and help others
