Question about Abit VT6X4 Motherboard
Usb shortage i need usb slots baddly and i have the two port usb port that comes with a MSI PLATNUM motherboard but that board crashed and now im running on a ABIT VT6X4 i need to know if i can hook up additional usb to that board without buying a pci usb port or a pci hub i also have two ports on the front of the stack that have prongs on them labeled [port + ,port-,-,+]can i hook these to my motherboard and if so how ?
  • 196 Answers
The easiest way is to just get a USB hub, as described here: http://en.wikipedia.org/wiki/USB_hub These are commonplace, and work very well.
Posted on Aug 31, 2007
    Novelist:
  • 231 Answers
Hi, if you get into trouble with the last solution then re-post and I will send you a diagram of the connection pattern. Its quite an easy job, goodluck mistyman
Posted on Aug 30, 2007
    Sergeant:
  • 279 Answers
There's a photo of your motherboard here: http://www.techspot.com/reviews/hardware/abit_vt6x4/ You see the part labeled "USB header for two extra USB channels." That is where you'd connect any additional USB ports. When you say you have two ports on the front of the stack, I assume you mean on the front of your computer case? Front mounted USB are handy, and just about standard on most cases. Just connect the cable from them to that connector and you should be ready to go. If you're not sure which way to connect it, just try one - you won't break anything by connecting it backwards (you'll just have to switch it to get them to work).
Dear sir, i have just purchased an asus m4n68-tm mother board with amd athlon ii x2 3.0ghz processor. im facing an strange problem. i have an external 320gb western digital hard disk. the problem is the...
Hi there, It sounds like your problem is that you haven't hooked up your front USB ports to your motherboard. If you open up your computer case, you should notice some cables coming down from the front USB ports. Those cables need to be attached to USB headers on your motherboard. You should check out your motherboards manual to see where the pins for the USB headers are, and then hook up the cable. My guess would be that no USB device works via the front panel, but after hooking up these cables all devices, including your external hard drive, will. If you need more help/clarification, let me know please! Alex
Jun 03, 2011 | ASUS M4N68TM Motherboard
K8n-neo2 platnum
No on-board video. Yes you need a video card. K8N Neo2 Platinum (supports PCI and 1.5V AGP 4X/8X.
Dec 25, 2009 | MSI K8N NEO2-Platinum (MS7025) Motherboard
Need a driver..
Here you have specs for that motherboard:
Part/Feature Support/Specification Motherboard Description
  • Manufacturer's name - N1996
  • HP/Compaq name - Argon
Motherboard Supplier MSI System BIOS Supplier MSI/Award Form Factor uATX Processor Brand Intel Maximum approved processor 2.53 GHz Intel Pentium 4 Processor Socket Type mPGA478 Processor Family Intel P4 or Celeron Processor Front Side Bus Frequency 400/533MHz Chipset Name 845E Chipset "North Bridge"
revision/stepping 845E
A1 Chipset "South Bridge"
revision/stepping ICH4
A1 Super I/O
revision/stepping Winbond
W83627HF-AW Flash BIOS Device 4MB Flash EEPROM Memory Type 2.5v. DDR Memory Speed PC2100/PC1600 Memory Sockets 2 DIMM Maximum Memory 1GB Graphics Supplier Intel Graphics Configuration Up Graphics Connector (AGP) AGP 4x TV-Out Device No Audio AC'97 Down AC'97 CODEC Device Realtek ALC202A Audio Jacks (legend below)
M Microphone M,LI,LO,SO
LI Line In
LO Line out
SO Speaker Ethernet 10/100 LAN Supplier Realtek RTL8101L Ethernet Configuration PCI Down IDE UDMA Modes ATA-66/100 Expansion Slots (AGP/PCI/Exten) 3 PCI USB Ports 6 USB Front/Back Options 2F+4B Serial, Parallel, Floppy, PS2 Kbd and Mouse 1S,1P,1F,PS2 K+M Serial Port Front Chassis Option No Available Mfg Options -U,L,A,S
A Audio down on motherboard C External L2 cache on motherboard E 1394 on motherboard G Graphics down (on motherboard or in chipset) L LAN on motherboard (Ethernet) P - PCMCIA slot S S3 power management support T TV-out on motherboard U Graphics card (up, not on motherboard) W Microsoft®) Windows XP hardware compliant
Nov 19, 2009 | Computers & Internet
MSI motherboard model 6734 AGP interface
Looks like your motherboard is a MSI KM4AM-L detailed here:
http://www.msicomputer.co.uk/index.php?func=proddesc&prod_no=572&maincat_no=1
If so, then it has an AGP slot which will run at 4x and 8x.
Remember to check the BIOS settings after you install it to make sure it is set to 8x, if that is what your card will take.
Sep 22, 2008 | MSI KM4M-L Motherboard
Where to connect card reader?
Easy, if you find where your front usb port is connected you'll see some odd ports that have 10 pins slots one of which has a missing pin, either in the lower left hand corner or in one of the center pin positions. Find the one that matches your generic (usb) card reader and plug her in. The card readers that come prebuilt in computers now are based on usb technology and fit into the same slots as the USB connectors. In fact if this is on a 915G it should plug into one of the JUSB1 or 2 slots.
Sep 12, 2008 | MSI 915G Combo-FR Motherboard
Motherboard crashed
The main thing is to find out what type the processor socket is.
Then buy a board with the same socket, and that can take the same ram type. This is your board so any equivelent should be fine.
CPU
  1. Socket 754 for AMD Athlon64
Chipset
  1. SiS 760 Chipset
  2. SiS 964 Chipset
  3. Super I/O: ITE IT8705 chip
  4. Integrated peripherals
    1. Realtek 8100C Ethernet controller
    2. Realtek ALC655 Audio AC'97 Codec
  5. Local Frame Buffer memory 64 MB
Memory
  1. Type: DDR400/ 333/ 266- 184pin
  2. Max capacity: Up to 2GB by 2 DIMM slots
Internal I/O Connectors
  1. 2 x Serial ATA connector
  2. 2 x UDMA ATA 133/100/66 Bus Master IDE connectors
  3. 1 x FDD connector
  4. 2 x USB 2.0/1.1 connectors (supports 4 ports)
  5. S/P DIF input/output pin header
  6. 2 x cooling fan pin headers
  7. CD/AUX in
  8. 1 x Game/Midi connector
  9. 1 x COM connector
Expansion Slots
  1. 1 x AGP slot (8x/4x-AGP 3.0 compliant), supports 1.5v display card only.
  2. 3 x PCI slots (PCI 2.2 compliant)
Back Panel Connectors
  1. PS/2 Keyboard / Mouse
  2. 4 x USB 2.0/1.1 ports
  3. 1 x VGA port
  4. 1 x RJ45 port
  5. 1 x COM ports
  6. 1 x LPT
  7. Audio (1 x Line-in / 1 x Line-out / 1 x Mic) connector
CPU/AGP/DIMM setting
  1. CPU FSB adjustable via BIOS
Power
  1. ATX power connector and ATX 12V connector
  2. Power-off by Windows 98/ Me/ 2000/ XP shut down and switch
Form Factor
  1. Micro ATX form factor
  2. 24.4 x 24.4 cm
H/W Monitoring
  1. System health status auto-detect and report by BIOS
  2. Hardware detecting and reporting for case open, CPU voltage, and fan speed.
BIOS
  1. 2M bit flash ROM, Award BIOS
Mar 15, 2008 | Intel Motherboard
How i can know that motherboards have built in video
none of the cards u enumerated have on board video (don't know about the last one k9a6m2 f-h )
go on the producers site, at the motherboard u want and look for the back panel I/O ports :
example :
bult_ar_org.gifBack Panel I/O Ports
- 1 x PS/2 keyboard
- 1 x PS/2 mouse
- 1 x 3 in 1 audio jack
- 4 x USB 2.0 ports
- 1 x Serial port
- 1 x Parallel port
- 1 x RJ45 LAN jack
- 1 x Graphics Card port (this is what u want)
Jan 21, 2008 | Intel Motherboard
Abit VT6X4 Motherboard Logo
224 people viewed this question
Top Abit Computers & Internet Experts
Alun Cox
Daniel Dollive
Daniel Dollive
Mike
Are you an Abit Computer and Internet Expert? Answer questions, earn points and help others
