Question about Garden
Stihl mm55 Tines won't turn.
mickey813
  • 472 Answers
SOURCE: THE TINES WON`T TURN
SOUNS LIKE SOME THING CAME LOOSE IN SIDE THE TRANS
Posted on Oct 02, 2009
daniel528
  • 142 Answers
SOURCE: Own an older (1990's) American
Yes, there are shear pins on the tines and on the wheels. Can you check to see if the belt actually moves when the pulleys turn?
Posted on May 13, 2011
  • 6468 Answers
SOURCE: ryobi ry64400 tiller tines won't move engine runs fine
then you need to open the gear box and find out why if it has a forward and reverse the the shifting linkage it could be stuck in one gear and adding the other will lock it up as well
Posted on Apr 21, 2012
  • 6468 Answers
SOURCE: starts and runs but tines won't turn
check for a damaged gear or shear pin
Posted on Apr 27, 2012
  • 6468 Answers
SOURCE: tiller engine won't turn over after the till was on its side to clean tines
remove the spark plug and pull it to force any fuel and oil from the cylinder hold a rag over the top of the spark plug hole as fuel and oil will spray out check the oil level before running the engine again
Posted on Aug 14, 2012
My grandfather has a stihl mm55 tiller it will start and idol but when you give it throttle it dies can anyone tell me how to fix it it has set for last 2 years
Could be adjustment if it has a fuel adjustment screw or maybe it needs the carburettor cleaning out.
Was any original fuel drained and replaced with fresh fuel?
If there are any diaphragms in the carb they could have perished in those 2 years or become hard and inflexible.
Mar 17, 2017 | Stihl Garden
Tines
Either clutch is bad or teeth are striped in bottom gear box. remove tines run engine and see if you can feel movment in lower gear box, if yes the gears are gone. If no remove engine to expose clutch.
May 20, 2013 | Ardisam Inc Earthquake Mini Cultivator
I have a Yard Machine rear tine tiller that has sat unused for 4 years. I replaced the engine and while in goes forward and backward, when I engage the tines they won't rotate and the engine bogs
Transmission/differential.
Perhaps the unit sat for 4 years because the tines would not turn and your replacement engine has not solved the real problem.
I'd say disassemble the chain case to discover what's locking the tine drive.
Apr 12, 2013 | Garden
Tines won't turn
Detatch the HEAD and rotate it and then install it. There is a good chance you have Jammed the Head and this should reduce the pressure and allow it to work.
Apr 03, 2013 | Ryobi GC720R TrimmerPlus Add-on Garden...
Ryobi ry64400 tiller tines won't move engine runs fine
Apr 17, 2012 | Ryobi Cultivator
Own an older (1990's) American Yard Products model WER500 Weedeater rear tine rotortiller. The engine runs great but when I engage to til, the tines won't turn. The belt is fine and pulleys turn...
May 13, 2011 | Garden
Primer not pumping mm55 stihl yard boss
Your Stihl dealer should have a parts department where you can get a new primer bulb. Also check the fuel lines to make sure they haven't cracked or come off.
Apr 26, 2010 | Oregon Scientific Complete Carburetor for...
Garden Logo
386 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
