Question about Samsung Televison & Video
Samsung lcd LA32C530 double image
Double image
Have a Samsung LCD TV with double image on screen.
Hi John,
This is the problem with the LCD panel of your TV. The problem is repairable. You may find some videos on YOU TUBE regarding this fault. But better some TV Tech does it.
Good Luck.
Oct 09, 2017 | Samsung Televison & Video
Tip
How to cure double image in Samsung LCD model number LA32C530
Take out the two flat ribbon cables going from TCon board to LCD panel. Clean the ends thoroughly with isopropyl alcohol and fit them back. Ordinary cleaning may not do the job and confuse you. Beware,company guys declare the panel to be defective for this fault.
on Jul 24, 2015 | Samsung HG32NA470PF 32 LED-LCD TV - HDTV...
Double image, how to solve this ?
It has T'Con board. But, it can't be replaced. It is an integral part of the LCD pane; and inside it.
Jul 22, 2015 | Samsung HG32NA470PF 32 LED-LCD TV - HDTV...
Double image in samsung lcd tv
IF it is still under warranty, take it in to be replaced.
Aug 28, 2014 | Samsung Televison & Video
Samsung tv displays doubling images
You have a faulty LCD panel, common with older Samsung and Sony sets!
Apr 06, 2014 | Samsung Televison & Video
Samsung vertical shadow screen
Does the screen have a double image? or is one side of the screen darker and has a delay? If so, your LCD panel is failing, common problem with older Samsung LCD's. I have the same model in my dining room that had a double image, fixed it by taking the panel apart and applying thermal pads on top of the panel tabs. The set works like a champ to this day!!!
Oct 27, 2013 | Samsung LN-T4665F 46 in. LCD Television
There is double imaging on my samsung tv, i replaced the tcon board and it still has the double image.
does it go away when the set warms up? or if you tap the set? Sounds like a possible defective LCD panel tab. Samsungs and Sony's are known for this.
Dec 04, 2012 | Samsung LN40A650A LCD TV
.mkv doesnt play on LED:UA32C5000 but plays on LCD:LA32C530
Hi
I am also facing similar problem with recently purchased LED 46" P6200. Do not know the reason? Does anyone has any idea why it is so? Thanks
Jun 19, 2010 | Samsung Televison & Video
The text and images appear as "double vision"
i had the same problem with my Dell computer and Samsung 931a monitor....after being on the phone with Dell for overe two hours and setting up a technician visit, i googled "computer monitor double image".....i went to Fixya and read several tips, but the one most often repeated worked immediately!....check and tighten your blue plug from your monitor to your computer!!
Jan 15, 2010 | Samsung SyncMaster 740N 17" LCD Monitor
Picture on Samsung LCD LNT5271F is blurred sometimes, lines, color distortion, double images, then goes away and will come back.
Try reseating the LVDS cable.It runs from the main signal board to the T-con board at the top of the panel.
Dec 01, 2009 | Samsung LN-T5271F 52 in. LCD Television
Televison & Video Logo
94 people viewed this question
Jerry Greenberg
Jerry Greenberg
