Question about Craftsman 22" Rear Bag Rear Propelled High Wheel Lawn Mower ()
How long to charge craftsman lawn mower model 917.370930 between mowings
  • 6 Answers
SOURCE: Lawn mower will not start and run
Sounds like a clogged carb or a cracked primer bulb. I would install a carb rebuild kit and new primer bulb if your mower uses one.
Posted on May 31, 2009
lasvegasrich
  • 65 Answers
SOURCE: Looking for a manual on a Craftsman Eager-1 .
http://www.searspartsdirect.com/partsdirect/getSubComp.pd?modelNumber=131.90300&productCategoryId=1503700&brandId=0247&modelName=ROTARY-LAWN-MOWER&diagramPageId=00001&documentId=00035640&pop=flush
PARTS LIST AND PICTURE.. WHAT DO YOU NEED TO KNOW OR DO??
Posted on Aug 22, 2009
  • 16 Answers
SOURCE: craftsman eager-1 lawnmower will not start
Hi, The first thing I always check for is fresh fuel (less than a couple of months old) old unleaded may well be fine in your car but low compression engines fitted to garden equipment need fresh fuel. next thing to check is that the choke flap is closing fully, dont rely on the position of the control lever, remove the airfilter cover and see that the flap is fully closed, if it's cracked open just a little bit it will stop engine starting ( unless the filter is really dirty) another thing to check is that the blade is tightly secured, on direct drive mowers the blade acts as a flywheel. did you hit an obstruction the last time you used it, if you did you may have sheared the flywheel key(poor spark on points ignition or good spark but timing out of sync on electronic ignition. hope this helps, regards Tony (England UK)
Posted on Aug 31, 2009
backwoodsctr
  • 169 Answers
SOURCE: How to change the v-belt on a craftsman walkbehind
Remove the belt cover, Remove the blade and blade adaptor. Remove belt guard and slip off old belt. Install new belt just like it was removed. Install parts and you should be good to go. Hope this helps
Posted on Nov 21, 2009
SOURCE: Craftsman lawn mower running bad with Tecumseh
http://www.tecumseh-parts.com/Tecumseh-Parts/tecumseh-vector-engine-and-parts
Posted on Oct 12, 2010
Model 56145. How can I remove mower deck?
Look, lower deck as low as it will go, look above deck, under the tractor and pull any pins holding deck to the control arms etc., and remove belt sufficiently to slide deck out from below tractor, I advise you to take pictures to make assy. easy.
How to remove the mowing deck from lawn tractor
Craftsman Deck removal How to
Removing and attaching mower deck
How to Remove the Mowing Deck From Toro eHow
Jun 17, 2012 | Toro Garden
Won't move in any gear
did the belt let go?is it a auto trans and the lever on the rear is pulled out that allows you to push it?
May 18, 2012 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
On the craftsman platinum 7.25 mower can I used 2 cycle oil in the mower
my new craftsman 7.25 platnium lawn mower stopped working, while mowing. while trying to restart it, white smoke came out of the muffler...with the smell of gas...it has not restarted since then
May 01, 2012 | Craftsman Garden
Primer doesnt prime when presses
either the passage is plugged or the bulb is torn
Apr 11, 2012 | Craftsman 675 Torque 190cc 21" Briggs ...
I have not used my lawn tractor for a long time. now it just CLICKS when I try to start it.
battery does not have enough charge to spin the starter, you might be able to charge it up. try jump starting from a car battery then mow your whole lawn without stopping. if it restarts after that you are good to go, if not go to walmart and spend 25 bucks on a new battery. replace the gas first.
Apr 13, 2011 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
White smoke coming out of mower
It sounds as though you are losing power (electrical power); see if charging the battery fully allows it to run longer or if charging the battery helps.
Jul 15, 2010 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Craftsman riding lawn mower steering shaft fell. Mower will not steer. I just started mowing, and the mower quit steering. Looked underneath, and it appears the shaft came loose that is used to steer. Any...
Look under the seat of your tractor and note the complete Model number.
(usually begins with 917. _ _ _ _ _ _ )
Next, go to THIS PAGE and use the Model Number to find an exploded view of the steering components and how they assemble.
Hope this helps,
Dolf-
Oct 15, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
1 year old craftsman model 917-376742 battery not taking a charge
sounds like it didnt take a charge; make sure all electrical connections are good and that it is getting power to the built-in charger. is there a indicator showing that its charging? are all the wires on the mower connected? you may need to get a new battery
Jun 12, 2009 | Garden
I have a craftsman electric key start lawn mower. I used the key start twice and have charged it after each mowing, but now the key start won't turn it over.
the battery probably got over charge & shorted the cells the tractor should charge the battery as it runs if it was equiped with electric start the battery charger more than likely over charged it killing the battery
Jun 07, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Mower only picks up when being pulled backward
if you have had the mowing blade replaced it could be upside down
Jun 05, 2009 | Garden
Open Questions:
Does the belt slip going uphill or with a full grass bag? My Craftsman mower lost the self propel feature. The small pulley on the top of the transmission would slip under load, There was just not enough tension on the belt to over come it. Tried a new belt and also replaced the tensioner spring...still slipping when going uphill or with full bag. Possible pulleys worn...not wanting to gamble more time and labor, I bought a 4" 1/4" cap screw with extra nuts and flat washers, a 3"16 eye bolt as well. Drill a 1/4" hole in the bracket that holds the trans activation cable in place and a 3/16" hole in the mower deck so the holes are in alignment with each other. Put the cap screw through the 1/4" hole with the threads facing toward the front of the mower. Fasten the eye bolt into the 3/16" hole in the mower deck locking it in place with one nut on each side of the metal. Now you have the 1/4" bole protruding through the eye bolt. Using a flat washer and nut, tighten then nut easily and when there is room put a second nut on it. When you have tightened it up to the desired belt tension lock the two nuts together using two wrenches. Note...do NOT make the belt incredibly tight or you will destroy the trans in a short time. Go a little at a time till the drive does not slip under load. Good luck hope this helps. Oh....you will have to trim the plastic cover that covers the transmission so the added bolt will clear it and you can put the cover back in it's proper place.
Mar 01, 2017 | Craftsman 22" Rear Bag Rear Propelled High...
See all Craftsman 22" Rear Bag Rear Propelled High Wheel Questions
Craftsman 22" Rear Bag Rear Propelled High Wheel Lawn Mower () Logo
65 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
