Question about Toshiba HDD2J54 MK3259GSXP Hard Drive HDD2J54
Laptop dropped onto floor, hard drive now clicking and operating system cannot be found appears on screen when laptop is turned on
  • 244 Answers
SOURCE: driver problem
Hi Vicient,
I have the following questions to evaluate the problem.
1) What's the port your harddrive supported? Is it standart IDE cable or SATA.
I have a hardrive utility software that can detect and access any type of harddrive but you need install it at running windows.
Please email diazphi@gmail.com and dont forget to used the subject "Driver Problem" if sound interesting for you.
Sincerely,
Philip
Posted on Oct 31, 2007
maklean
  • 1665 Answers
SOURCE: Trouble Reloading Start-Up Disk on Toshiba Satellite 1905-S301
Checl all internal cable connections (unplug-plug
Check all internal cable connection to be correct, start and observe messages to see if your HDD is recognized by bios and memory test is ok.
If problem remains try to boot from CD with original operating system disk in CDROM.
Posted on Mar 07, 2008
latinmcgyver
  • 208 Answers
SOURCE: When i turned on my laptop(Toshiba Tecra 8000), only a black screen appears and a note
what are you using a dos floppy ? lol i use a bootable live cd gparted-live-0.3.6-7.iso
Posted on Jun 01, 2008
mosesclive
  • 191 Answers
SOURCE: no drives found
Tour full installation guide
http://www.windowsreinstall.com/
This will help you to get you hdd and windows running.
Posted on Aug 11, 2008
  • 298 Answers
SOURCE: Replaced hard drive in Toshiba Tecra M9. Laptop.now refuses to re
Look on the back edge of your old HDD where all the gold pins are and on one side there is a group of 4 pins in two rows of two... and see if there is a tiny jumper installed across two of them (white or black about 1/8" tall and 1/16th wide).
Now look on the new HDD and see if there is one there. The NEW HDD must be set up exactly like the OLD one or it won't be detected by BIOS or Windows.
I am beginning to think your LT has the CD as MASTER and the HDD as SLAVE, which may require adding or removing a jumper. Some new ones come with, some without ;-) I didn't think of this earlier
Check that. Email me the result
Posted on Mar 27, 2009
HP Garden Dreams Pavilion dv5-2129wm problem.
You killed the hard drive. It needs to be replaced and you'll need a new operating system to go with it.
Sep 02, 2012 | HP Pavilion dv5020us Notebook
External hard drive- mechanical fault
Yes. Very expensive to get data. Most people take the loss.
Aug 26, 2012 | Iomega 2TB Prestige External Hard Drive
Operating system not found
Hi Jana, it is a common problem yes, your hard drive works like an old record player, with a thin needle reading off the hard drive platters where your data is stored. What most likely happened is the shock of the drop damaged the reading needle.
If it makes a clicking noise then you know your platters are having trouble spinning up.
You will need to replace the hard drive
Jan 27, 2012 | Microsoft Windows 7 Home Premium 64BIT...
Webcam is not working
Instructional steps to follow Things You'll Need:
  • File storage device (CD, DVD or flash drive)
  • Operating system recovery disc
  1. Save the files you want to keep from your laptop's hard drive to a storage device such as a rewritable DVD or USB flash drive. Unplug any USB or Ethernet cables connected to the laptop.
  2. Insert the Windows recovery disc into your computer's optical drive. Restart the operating system.
  3. Press any key when the "Press any key to boot from CD" option appears on the screen. Use the drop-down menus to select the language and time options you want to use.
  4. Click "Next" and then choose "I accept the license agreement." Select the "Custom (Advanced)" option.
  5. Click the option for the laptop's hard drive partition and then choose "Drive Options (Advanced)." Click the "Format" link in the lower right corner.
  6. Select "OK" and wait for the hard drive to be formatted. Click the partition again and then choose "Next" to reset the laptop back to its factory settings.dont forget to leave your comment by saying how helpful this tip is to you
Oct 09, 2010 | Computers & Internet
My wife drop the laptop on the floor and since then when i start the laptop it says no boot device found.
Two possibilities here:
1. When your laptop was dropped, the connecting between the hard drive & the laptop's motherboard became loose, & as a result the motherboard could not properly detect the hard drive. Solution here is simple: Try removing the hard drive & replacing it back in the laptop & see if this resolves the problem.
2. If the case did not turn out to be as described in point (1), then most probably your hard drive is damaged as a result of the fall. In this case you will also need to remove it off the laptop, but you will have to buy & install a replacement hard drive, & re-install the operating system & all other software.
The document at the following link describes how to uninstall/install a hard drive in your laptop's model:
http://support.dell.com/support/edocs/systems/latd600/en/sm/hdd.htm#1123687
Aug 25, 2010 | Dell Latitude D600 Notebook
No operating system
could be hard drive has failed. go in to bios and make sure it can see the hard drive. if not buy new hard drive
Feb 18, 2010 | Acer Aspire 6920-6621 Notebook
Pxe-e61,pxe-m0f
No; the message indicate absence of hard drive.
open the laptop and remove the hard drive and reinstall it.
if the message still appear then your hard drive is faulty.
Jan 01, 2010 | IBM ThinkPad T42 Notebook
My Compaq Presario F700 dropped approximately 2 feet to the floor from on top of a suitcase at the airport. It was in a case, but not a thickly padded one. When I tried to use the laptop after the fall,...
Try reseating the hard drive and the RAM modules, the fall may have slightly loosen these components.
The error message "Operating System not found" means the laptop could not find the hard disk, this problem could be the hard drive needs reseating, a faulty hard drive (they don't like being dropped), or a faulty disk controller.
Apr 28, 2009 | Compaq Presario 1692 Notebook
Toshiba HDD2J54 MK3259GSXP Hard Drive HDD2J54 Logo
96 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
