Question about Samsung Dishwashers
Relay wiring I need to know which wires go where on the relay of Samsung dishwasher model # dmr78ahs please
4 Suggested Answers
jyackle5
  • 8197 Answers
SOURCE: need to know how replace a 3 prong plug on my
On libnk below tells you how to change the plug. Step 8
http://manuals.frigidaire.com/prodinfo_pdf/Kinston/154427301b.pdf
Good Luck
Posted on May 14, 2010
Macmarkus
  • 2605 Answers
SOURCE: samsung dw model dmr78ahs/xac
Hello, Welcome to FixYa.
The 9E code as it pertains to your Samsung is as follows according to the Samsung service manual...
ERROR TYPE - Low water level detected.
OCCURING CONDITION - Occurs when low water level even after water supply resumes after low level is detected the 1st time.
POSSIBLE/EXPECTED CAUSES - a) Low level sensor defective. b) Low level sensor wire loose/not connected. c) Main PBA fault/defective ( main board )
Steps to resolve-check.
Check for foreign material in the floater of the Low Level Sensor.
- Check the voltage between both ends (pink and brown wires) of the Micro Switch.
When operating normally after water is supplied:
- Check only the Micro Switch.(Remove the connectors before checking.)
Lift the lever: Short
Lower the lever: Open
Results.
- Faulty: Replace the Low Level Sensor, Remove foreign material from the floater
- Normal: Replace the Main PBA assy.
If you don't think this is something within your scope of abilities please call an authorized Samsung service center in your area.
Let me know what you find and I'll be glad to help you in whatever manner I can. I do have a generic service manual for Samsung dishwashers ( essentially all the same as for components and repairs) but you'll need to provide an email address for me to send it via pdf attachment. Good luck.
Regards,
Macmarkus :)
Posted on Apr 19, 2011
ercupa190
  • 12223 Answers
SOURCE: samsung DMR78AHS not cirulating water
see this causes:
I can not understand your problem exactly, however i will give you the 2 possibilites:
1) water is not entering to the machine:
a) valve inlet water, can be defective test see how
b) float switch defective, is located in the floor of the diswasher see how to test.
2) water is not drain to the machine:
drain line/ air/gap is clogged repair see the diagram
b)propeller pump defective, see the diagram and replace
c)DRAIN valve/ or solenoid elecric defective repair or replace.
d)belt is broken, replace
e)motor can be defective, try to turn manually, if does is o.k otherwise is defective, replace.
f)timer defective, try to clean, loose wires, broken or open repair, If does not replace.
7_11_2012_6_36_33_pm.gif7_11_2012_6_37_09_pm.gif7_11_2012_6_37_37_pm.jpg7_11_2012_6_38_03_pm.gif7_11_2012_6_38_28_pm.gif7_11_2012_6_38_44_pm.gif
Posted on Jul 11, 2012
MY BRAND NEW SAMSUNG DISHWASHER HAS POWER BUT WONT START THE WASH THE WASH CYCLE THE TWO CYCLE LIGHTS JUST KEEP BLINKING
What 2 cycle lights? Samsung dishwashers indicate problems and errors by making different lights light up and/or flash. We would need to know the model number too.
Oct 07, 2014 | Samsung DMR78AHS 6 Cycle Stainless...
What is a 5e code on the Samsung dishwasher mean ?
According to Samsung it is a drain error. Best advice from Samsung is: Check whether the drain hose is clogged or folded. If the problem continues, close the water supply valve, and then contact an authorized Samsung service center.
My drain hose was not clogged or folded and the error code would go away at best for a day of so. Finally, it would not go away at all. My solution was to simply go to e-bay and for $27 had a new pump shipped to me. Less than 15 minutes to change out and no problem since.
Be aware that the new pump may make noise for the first few runs, but this goes away. I figure the pump just needed to run in for a bit.
Pump is on bottom. Remove and invert dishwasher. Remove screws holding bottom plastic cover and pump is right there. Unhook the wire harness to the sensor in the plastic cover. Remove the wires to the pump (two different wires, I would make a note of where each color went). Turn the pump about a quarter turn to the left and it comes right off. Put the new pump in the same position as the pump was when removed. Push in and turn to the right until it locks in place. Replace wires to pump and the plastic cover. Screw plastic cover in place, turn the dishwasher back upright and reinstall. Once in place and all plumbing and electrical connections reconnected it should work without a hitch.
Aug 20, 2014 | Samsung DMR78AHS Builtin Dishwasher
Error code He
he error code is a heating error. check the wire connections to the heater, if no problem then you need to check for continuity to the heating element. You'll need a meter to do this. The heater assembly may need replacing. I think they run around $60. We had a Samsung DW for 4 years...finally gave up & replaced with a GE which has been working well.
Jul 11, 2014 | Samsung DMR78AHS Builtin Dishwasher
Error code PE on Samsung dishwasher DMR78AHS
I too have the same problem with my dishwasher. Didn't know about the circuit breaker trick. Will give a try. My husband is ready to throw all our Samsung appliances in the trash. We don't recommend them at all. Re-modeled our kitchen 4 years ago and had all new Samsung appliances installed. What a mistake. In the 1st year we had 2 service calls on the dishwasher, 2 on the stove and 1 on the refrigerator. Have had many problems with the dishwasher. Have been in touch with the company but their approach is you bought it your stuck with it. Thanks for the trick to fix PE error code. I'm NOT getting it fixed. I'll use it till I can't use it anymore then go buy something else.
Aug 24, 2012 | Samsung DMR78AHS Builtin Dishwasher
Samsung DMR78AHS not cirulating water
see this causes:
Jul 11, 2012 | Samsung Dishwashers
Low water level sensor
Thank you, worked like a charm. So simple. It needs to be done annually, as a regular maintenance...
May 29, 2012 | Samsung DMR78AHS Builtin Dishwasher
The dishwasher does not clean glasses. They still have fingerprint and lip smudges.
Hi suzyb3,
Please look at my below Tip on how to ensure your dishwasher is working smoothly:
DISHWASHER NOT CLEANING PROPERLY...
Kind Regards :-)
* If this solution helped you, please rate it
Jul 18, 2011 | Samsung DMR78AHS Builtin Dishwasher
DMR78AHS error code HE
Hi, the HE codes refer to temperature errors. The HE codes refer to heater problems. These are all functional errors that require a certified service technician, but disconnecting the circuit breaker in the meantime can prevent the problem from growing worse.
Jun 13, 2011 | Samsung DMR78AHS Builtin Dishwasher
Have code oE is this over water level sensor is it accessed from bottom of washer? is it a sensor or is it a switch is this a common problem?
Drain Error OE
Not fully drained out in spite of 5 min. drain operation
The Drain Hose kinked or blocked. Wiring connection is OK? The drain outlet of sump is blocked. The Drain Pump/Motor or circuit is troubled.
Remove the cause of kink or block. Check the wiring connection. Measure the electric resistance of Drain Motor. (20-40 ) Replace the Drain Motor or repair the Circuit
Mar 29, 2011 | Samsung DMR78AHS Builtin Dishwasher
No power no lights samsung dmr78ahs
the electronic computer board is dead & needs to be replaced.
Jan 12, 2011 | Samsung DMR78AHS Builtin Dishwasher
Dishwashers Logo
35 people viewed this question
Top Samsung Dishwashers Experts
Dale Copeland
Dale Copeland
Are you a Samsung Dishwasher Expert? Answer questions, earn points and help others
