Wharfedale ly19t1 ,Menu keeps popping up automatically
Remote control is ok ,taken batt out ,still menu keeps popping up
  • 30 Answers
SOURCE: Menu pop up
You may try to check the eeprom circuits. First check their power input line, is it stable or not? Even the power supply line to eeprom ic have a little change/not stable, then you need to suspect the voltage line have some thing not stable, please check fileter cap and regulation ic first. Any more info on plasma tv info you can go to this site to get the tips, http://www.fastrepairguide.com
Posted on Sep 08, 2007
jdbouncer
  • 72 Answers
SOURCE: Menu
Is this a plasma TV ? If so remove the back cover of tv and unplug the cable that plugs into the IR board from the SSB that receives the signal from the remote. If it stops you panel is causing interference with the signal. If it doesn't your problem is in you SSB. you might see if there is a software upgrade offered by the producer of that TV.
Posted on May 06, 2008
  • 9 Answers
SOURCE: Menu keeps popping up!
I had this same problem with the Main Menu coming up on my Dell Monitor E171FPb and I thought I would tell you what I did to fix the problem.
1. I shut down the PC.
2. I removed the power cable and video cable from the back of the monitor.
3. I removed the four screws that hold the stand for the monitor and slid the stand off.
4. I then removed the 5 screws that hold the back cover on the monitor.
5. I took two flat blade screw drivers and carefully removed the back cover.
At the bottom of the monitor case, there is a small circuit board the holds the 6 switches for controlling the display.
6. I located the button that calls up the Main Menu. It is the second switch from the left as you are looking at the monitor from the rear.
7. I used a small solder iron and heated up the four prongs in sequence while holding the switch with a pair of needle nose pliers. I had to rotate this process from one prong to the other while all the time applying slight pulling pressure on the switch pulling it away from the circuit board.
8. Once the switch was removed, I put the cover back on and tightened up the five screws.
9. Then I slid the base back in the slot it came from and tightened the four screws.
10. I connected the video and power cable and turned on the PC.
With the switch removed the Main Menu never popped up again and I am so very happy.
Posted on May 30, 2008
  • 304 Answers
SOURCE: Menu Screen Keeps Coming up on the screen
The most commom causes are One. There ia a stuck button on the tv itself. The Menu button. The membrane switch or the TACT switch is bad and needs to be replaced. The Main bd can also be bad.
Posted on Jul 17, 2009
  • 117 Answers
check remote faulty batteries/take them out see if it stops doing it also depress menu button on tv might be stuck
Posted on Nov 10, 2009
How do i channl search my tv without a remote?
depends.....whats the type of tv and model? some tvs are fully remote controlled but if ya tv has a menu button press menu then press ok then select the options displayed by using the down arrowed button press ok go to search/tunig select auto tuning/search press ok it will select all channels automatically and store them press menu to exit
Jul 08, 2013 | Televison & Video
check weather the remote controller is malfunction.if ok, check for an stuck up menu button at the tv panel.
Oct 27, 2012 | Televison & Video
Menu from Projector keeps popping up. it will clear away when we click MENU button but then within 5 seconds, it will pop up again. we are using ACER XD1150 DLP PROJECTOR. would appreciate any...
hi,
Check is the remote transmits signals for menu at any time.
to check this after clearing the menu remove the battery of the remote. if the menu didn't po pup again , the remote need cleaning .
If the menu pop up again then, you have to check the menu button (push button) on your projector.
ok
Feb 21, 2011 | Acer XD1150 DLP Projector
Instructions to tune Philips tv 54cm colour TV. Search & store channelss
Hello
You haven't mentioned about the model number of your Philips TV. Different models have different type of tuning procedures. Any way I hereby send a procedure to set it autotuned. If it Doesn't work, please inform me through Fixya, stating your TVs model number also. ok
Press "Menu" on the remote control handset, and select the installation language.
Select a language and confirm it by pressing "OK" button on the remote control.
Press ' button to return to 'Instalation' menu.
Press "Menu" on the remote control handset and select Installtion > Preferences > Location.
Select 'Home" and press "ok" to confirm.
Press ' to come to the Installation menu.
TO TUNE CHANNELS AUTOMATICLY AND TO STORE
Press "Menu" on the remote control, "Select Installation" '>' Channels '>' Autoprogram '>' Start now.
Press "OK" and allow the start installation automatically.
If you run autoprogram when you have locked channels, a messege appears asking to enter your PIN code in order to complete instllation.
Try this, if doesn't work inform me with TVs model number. OK.
Nov 04, 2010 | Philips Televison & Video
Menus pops up
The menu button on the TV itself is bad and must be replaced ( or removed ). Alternatively the whole front button assembly can be disconnected. Just follow the wire back to the main chassis and unplug it.
Apr 09, 2009 | RCA P61927 61" Rear Projection Television
Reseting lamp counter (LG)
Make sure the TV is on and:
1) Press and hold the Menu button on your TV SET
2) Press and hold the Menu button on your REMOTE CONTROL (at the same time)
3) Continue holding BOTH buttons down for 5 secconds or until the Service Menu pops up
4) Release the MENU button from your REMOTE CONTROL, then release the MENU button from the TV Set.
5) Press and hold ENTER (or OK) on the TV Set, then:
6) Press and hold MUTE on the REMOTE CONTROL (while still holding down the ENTER button on the TV SET
7) Holding both buttons down should lead to the Lamp Life Hours screen to pop up.
Release the MUTE button the REMOTE CONTROL, then release the ENTER (or OK) button on the TV Set.
9) Come back to this blog and post your HOURS on our site
10) Now press SELECT, then SELECT again to confirm the reset of the counter
** If the procedure above does not work swap steps 5 & 6.
** For a few special models (including 44SZ8D), you might have to change step 5 to:
5a) Press Enter on the TV Set to enter the Position Adjustment Screen
5b) Press and hold Enter on the TV Set (the TV should go back to the main Service Menu, continue holding Enter) and now also hold down the MUTE button on your REMOTE CONTROL. After about 5 seconds, your Lamp Life Counter should pop up.
Jun 30, 2008 | Televison & Video
Need to reset lamp life indicator on lg rear projection tv model no 525sz812-tb
9) To Check if it was a success
Jun 21, 2008 | LG Televison & Video
Televison & Video Logo
29 people viewed this question
Top Televison & Video Experts
