Question about Juicers
Bellini beje10 plastic cover broken
Hi, while operating this juicer, the plastic piece from the top cover has broken off, is there a replacement part for the top cover for this juicer available?
I would contact Macy's customer service for an answer to this question. It is not a model that has a retail parts division. Macy's should be able to provide a solution for you as they still carry these units. Otherwise, you may wish to purchase a new one from them and return your old one to them in the box you receive. It will end up costing you shipping, if you do not have one near you, but right now they are only $79.99. Model 8021
May 25, 2011 | Sharper Image 8021 700 Watts Juicer
Are the parts for my acme 11je45 the same as those for the acme 5001 and the 6001?
I have a 11je45 also, circa 1990. The only problem I had was replacing the cover.
The plastic covers for the newer Acme's will not fit unless you file the ridge down
where it fits into the juice bowl. Its a pain, but can be done. The other parts, like
the clutch nut, shredder blade, etc., should be the same. No supplier, I gooled,
says they have the older covers, but I know they are out there because I got one
when I ordered the newer version. They seem to be unaware they have them.
Mar 06, 2011 | Acme 6001 Juice Extractor
BRAKET ON JUICER WHICH HOLDS BASKET FROM MOVING IS BROKEN CAN IT BE REPALCED OVER 15 YEAR OF USE OF JUICER NOT BASKET IS MOVING DUE TO BROKEN HOLDING BRAKETS JUICER IS INWORKING CONDITION AND FINE I...
Are you talking about the clutch nut that screws
down on the basket and blade, or the small clips
that the cover rotates and snaps into. Either way
call Waring at 1 800 492 7464, they should have
the part.
Oct 16, 2010 | Acme 6001 Juice Extractor
Broken plastic screw from motor shaft
According to Jack Lallanes Support you need to buy a new motor! No replacement part for that specific part!
I have the same problem and also do not want to buy a new motor! Scam!
Dennis
Nov 21, 2009 | Jack Lalanne Power Juicer 250 Watts
The plastic screw, which the grater is screwed onto (looks like part of the motor) is broken.
I had the juicer for exactly two weeks and the same piece broke. The little plastic part in which the blade screws onto. Called the company and they were actually no help at all. Please don't waste your money!
Nov 14, 2009 | Jack Lalanne Power Juicer 250 Watts
On the shaft that produce from the Juice Extractor
ONE ACME AND OMEGA IT'S CALLED THE
CLUTCH NUT. GOOGLE THE MFG. OR
FOR YOUR BRAND'S PARTS.
Jun 29, 2009 | Hamilton Beach Juicers
HOW DO YOU take apart the jack Lalanne juicer blade and top unit to clean
LIFT UP AND SLIDE COVER RETAINING BRACKET OFF COVER, REMOVE COVER AND
PLASTIC NUT THAT HOLDS DOWN BLADE. ALL PIECES JUST LIFT OUT, BUT KEEP TRACK
OF THE ORDER THEY ARE REMOVED IN TO REINSTALL CORRECTLY.
Jun 28, 2009 | Jack Lalanne Power Juicer 250 Watts
Repair or replacement of Power juicer
The part has a lifetime warranty. Just call the customer care line at 1-973-287-5150 and give them your model number. You have to pay shipping though. Our shipping cost was about $26.
Sep 13, 2007 | Jack Lalanne Power Juicer 250 Watts
Juicers Logo
50 people viewed this question
Top Juicers Experts
eyecam
Tom Chichester
David Payne
David Payne
Are you a Juicer Expert? Answer questions, earn points and help others
