Question about Saws
I got a altendorf f45 and the blade is stuck on the 45degree angle and when i try to turn it back to square it reads a "E03" how do i fix it and turn it back up right???
efs_perpends
  • 1996 Answers
SOURCE: Table Saw Blade Won't Cut Straight
Inside the saw, on the end of the trunnion is a stop that is adjustable to zero the saw in to exactly 90 degrees. Either there is sawdust or something accumulated there or it needs to be adjusted. You say you cleaned it out, So you'll need to unplug it an have a look up in there. See how there's a geared piece of steel that moves when you crank the saw over to 45 degrees. Usually there's a bolt or stud with a locking nut on it, either on the trunnion itself or the lower surface of the table top. You need to break the nut loose and screw the bolt in or out to adjust, then crank the saw over to hit it, check for square with a known square, crank it all the way out of the way and readjust, etc. Until you get it right. Make sure to tighten that lock nut when you're done.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread. If I've managed to answer your question or solve a problem, please take a moment to kindly rate this post....thanks!
Posted on Apr 02, 2009
VtToolMan
  • 704 Answers
SOURCE: i need to know the right angle to sharpen my chainsaw
If your saw still has the original bar and chain, it was supplied with a .325" pitch chain and you'll need a 3/8" round file with a sharpening guide to properly sharpen it.
Here's a link to the Husqvarna site to the Rancher 455 models so you can select the correct manual to download, that matches your particular saw, based on the year of manufacture, etc.
There is some excellent information about maintaining your saw, along with a really good guide with step-by-step instructions for proper sharpening.
http://www.husqvarna.com/us/homeowner/support/download-manuals/?query=455&types=O
If you're having trouble figuring out the right manual for your saw, use the online Customer Support page and they'll reply.
Hope you find this Very Helpful - Best regards!
Posted on Aug 19, 2009
  • 10865 Answers
SOURCE: the cut is not square on 45degree miter
Hello. First of all adjust your saw on straight cuts so that it is spot on 90 degrees. Then go to the 45 and test it again. Being off a tiny amount at 90 degrees is compounded when you go to 45 degrees.
Posted on Nov 19, 2009
  • 356 Answers
SOURCE: laptop screen problem
Hi. Try to reseat the video cable from the motherboard. You might need a manual or system tear-down module for that. Try to google it. ^_^
Posted on Jun 07, 2010
  • 127 Answers
SOURCE: which bolts do i loosen to adjust the 45% angle
To adjust the bevel, (blade angle), loosen the black lever at the back of the unit, tilt the blade housing using the handle (this may require a fair bit of force) until the arrow on the scale is at 45 degrees then tighten the black lever.
Posted on Dec 27, 2010
Find adjustment lock for ryobi 81/2 chops aw to set new angle
check for an adjuster knob at the back side of the board that you hold the timber against
loosen it off , turn the saw head to the indicated degrees and screw it back down
Feb 14, 2018 | Cars & Trucks
Stuck CD
Tricky one...
I've had success in the past by using a thin knife blade, or metal ruler (a medium sized pocket knife works well)... Stick a small square of double-sided tape on the blade/ruler... IMPORTANT! Very gently slide the blade/ruler into the slot, do so at a slight angle so you first clear the edge of the disk. Then gently, but firmly, press the blade/ruler down on the disk so the double sided tape sticks... now press the 'eject' button on the keyboard (or the go to Finder and select the disk and click the eject icon), at the same time try to gently wiggle the blade/ruler outward to assist in removing the disk!
John
Apr 20, 2014 | Apple 24" iMac Desktop
MJX F645 F45 4ch LCD 2.4GHZ Large Single Blade my new helicopter but i don't know a thing about it,and would like to hear all i can learn?
With that setup you can get about 75 yard swithout any interference problems. Collective pitch is the angle of attack of the rotor blades (how much bite they take out of the air) your bird has fixed pitch blades so you have nothing to adjust or worry about. Pre-flight is a good idea and it consists of looking for loose missing or damaged parts. Do not fly with damaged rotor blades. Have fun.
Mar 07, 2014 | Toys
My fisher and paykel washing machine will not finish its cycle with a minute to go,
Can you tell me if the w/m is pumping the water out.The washing machine will not spin until all the water is out.
I would need more information ? If you tilt the washer back on a 45degree angle,you will see the pump,looks like a black fan blade on your right side.the windings should look shiny' copper' not burnt looking or white,which indicates a water mark.See if you can move the black impeller and remember to up PLUG the washing machine?
Aug 14, 2012 | Fisher and Paykel Fisher Paykel Intuitive...
Blade does not square up on c10fsh miter saw
To square up a mite saw blade, you need to eeither move the table or adjust it to be square if it is out in the mitre angle, or if it is out in the bevel angle the whole saw head needs to be adjusted, and this is done via the bevel adjustment at the back of the saw. There may be a bevel stop bolt to return the saw back to 90 degrees if moved to a different bevel angle. Usually the blade itself is not adjusted bu either the saw table or the bevel angle of the saw head itself to correct these issues.
Feb 28, 2011 | Hitachi Garden
Which bolts do i loosen to adjust the 45% angle of my blade? Ive already squared up my blade by using a square and laid it down on the deck and squared the back rail like that> but how do i square...
Dec 26, 2010 | Makita LS1214F 15 Amp 12 Inch Dual Bevel...
Adjust angle of band saw blade to align with fence
Typically the fence is attached to the table and the table can be angled to create a bevel.
Using a square, align the table so it's square to the blade. Assuming your fence is square to the table vertically, you're good.
With most bandsaws I have worked with, there is a positive stop (typically just a bolt - the head acts as the stop) underneath the table so when you tilt the table, you can return it to flat without having to re-square everything up every time. Once you've got things square, make sure to adjust the positive stop too.
Be aware you may still have to compensate for drift with your fence, though.
If this answer was useful, please vote. Thanks!
May 23, 2010 | Black & Decker 14" Hd Multi Cutter Saw
When I try to cut a 45 it seems to be cutting a little more than a 45. how do I adjust it?
Make sure the blade is 90 deg vertical to the saw table. Make sure the indicator is set approprately. Raise the blade just enough to clear the table/base. Place a swanson speed square against the fence and blade. Make sure the indicator is at 90 degrees. Here you might want to tilt the square and check that the complete blade is flush against the sqaure as high up as possible. Lay the square back flat on the table and pull the blade toward you as much as possible. The teeth on the blade should ride against the square extented completely out.
Now set the square against the fence with the 45 degree angle coming away from the table and set the blade on the 45 deg mark on the insicator scale.
The blade should touch the square all the way out fully extented.
Or just experiment with some scrap and check
May 19, 2010 | Dewalt 12" Beveling Sliding Compound Miter...
Dw703 beval adjustment
User manual for adjusting your saw here.
When you set it up, make sure you check for square to the table, square to the fence, and check square for toe-in or at a 45 deg. angle across the blade from the corner where fence meets table, like you would check a radial arm saw. (hold a framing square with one leg against line of fence/table and other leg against blade and inclined 45 to both table and fence. Make sure all three are dead square.
I never found any way to compensate for the play in the blade itself. It seems like the manufacturing tolerances are a little too loose.
You may need a heavier plated blade. You may simply need a different saw. Those Dewalts are great workhorses, and I love the design, but it's my experience that when you're trying to miter hardwoods of any substantial size there's a little bit of drift in the cut as the blade comes through the wood.
You can try cutting at a slower rate.
I've found that makitas are a little more solid through the cut, though I don't like the general ergonomics as much...
Kind of a pain, isn't it?
Well, good luck.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Sep 04, 2009 | Saws
Saws Logo
271 people viewed this question
Top Saws Experts
Tom Chichester
ray gallant
Are you a Saw Expert? Answer questions, earn points and help others
