Question about Refrigerators
Ge profile pfss2miyc
Water smell
4 Suggested Answers
WeListen2You
  • 538 Answers
SOURCE: GE Profile Refrigerator has an electrical smell but it still cools
sure..the drip is no biggie..the smell..can be from a variety of worrisome issues..
compressor
capacitors
wiring
motors(fan)
you planning on dissecting this one yourself_
Posted on Oct 23, 2008
  • 531 Answers
SOURCE: smelly water dispensed from ge profile refrigerator
flush the water tank put a glass press for water and keep flushing on till smell gone
Posted on Mar 31, 2009
  • 4793 Answers
SOURCE: monogram profile GE smells; can't see where water
blow out drainpipe/vent or use fine wire with a small cloth tied to end dipped in clorine bleach gunk is streptococus, grows naturally.....
Posted on Feb 09, 2010
Top load washer smells like rotten eggs when water is draining into tub
As someone who has had a deep well drilled and found water, but water contaminated with iron and sulfur, I can tell you first hand about the rotten egg smell. The water softener will remove the iron that can turn clothes orange, but doesn't do anything to remove the rotten egg odor. You will need a charcoal (carbon) water filter to eliminate the sulfur smell.
Sep 19, 2014 | Whirlpool WTW8600YW: 4.6 cu. ft. Cabrio...
Smelly water with water softener
Your local home depot sells a product called AFFRESH that is made for front loaders to clean mold as well as stagnant water smells from washing machines. I have also hear other techs suggest vinegar and water but personally I would much rather have the unit smelling nice and flowery smell instead of a vinegary smell. Also it is important to note your drain line should be at least 6" higher then the top of your washer if it were less then the water that is supposed to leave the machine goes back inside the machine thus giveing some a stagnant water smell or like bad eggs.If you have any further questions message me back
Thank you
Rick
Nov 26, 2011 | Washing Machines
About every two months the the hot water gets a sour smell. To get the smell out I turn both elements all the way up for 3 hours then drain the water heater, its good for about two months. The water heater...
The smell is from bacteria. The high temperature kills the bacteria. Some regions require water heater temp to be set at 135 because of bacteria.
A test to determine if only the water heater is causing problem: Turn off water to water heater. Smell water coming out of cold tap. Turn on water to heater, smell water from hot tap. If only hot tap smells, then water heater is suspect.
Another way to handle the problem long-term, is to reconfigure cold water pipes so you can regularly pour in 2 bottles of hydrogen peroxide during your flushing procedure. Pour in the hydrogen peroxide and let it work for a while. And then flush tank as you have been doing.
You should read up on anode rods also. Many people replace anode rods when tank begins to get odor.
http://www.waterheaterrescue.com/pages/WHRpages/English/Longevity/water-heater-anodes.html
http://waterheatertimer.org/Replace-anode-rod.html
Oct 23, 2010 | Rheem 80 GAL ELEC TALL Water Heater 6YR SC...
Foul Odor
Odor from the water softening system can be attributed to several causes.
The best way to see if it is coming from the softener is to by-pass the softener and run the COLD water only for several minutes and see if the smell continues. Now run the HOT water and see if smell is coming from the water heater.
Some causes may be:
1. Hydrogen sulfide in the water supply (the water chemistry can change)
2. Sulfate reducing bacteria. Almost all water supplies have sulfates and if bacteria gets introduced into the plumbing system it acts with the sulfates to create sulfate reducing bacteria. Which creates a rotten egg smell in the water.
3. Salt additives can have many different affects on water chemistry and organics in the water causing musty, fishy, swampy type smells.
4. If you have a system for Tannins using salts with additives will always cause foul smells as it harms the Tannin media.
5. The ANODE rod in the water heater degrades and gives off a sulfur type, rotten egg smell.
RJ
Jul 22, 2010 | Culligan Under Sink Water Filter
The water smells in my hot water dispenser
There usually is an anode rod in a water heater that is there to attract the lime from the water. This helps prevent lime build up in the bottom of the tank and makes it last longer. However, the downside of this is the sulfur smell that comes as a result of the anodization (chemical) process. You could remove the rod and plug the hole in the heater to eliminate the smell. You'd give up some length of service as a result.
Sep 07, 2009 | Buck IN-SINK-ERATOR HOT ONLY WATER...
Sulphur smell
you can remove it but this will not fix your problem, you must cut the cold side pour in about half gallon of bleach ,drain heater of a gallon and a half first, then pour in bleach wait one hour then use as normal. you will have a bleach smell for some time but this will make the egg smell disapate.try this it worked for me.
Jul 21, 2009 | Audiovox Richmond 6G40-36F 6-Year Tall Gas...
Smelly water dispensed from ge profile refrigerator
Mar 23, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
The hot water smells like rotten eggs., only the hot water
its the mag rod in water heater-if your not using alot of hot water,and water is sitting in heater it will smell like rotten eggs-u can remove mag rod from water heater.it is in top of heater-
Jan 08, 2009 | General Electric GE SmartWater Household...
Stale smell on crockery after wash
Most commonly, this relates to sulfides or other impurities in the water itself, but may also be caused by a buildup of food soil within the washer. Smell a clean glass of water. Does it smell stale also? If no, clean the screens and wash water sump/tank within the machine.
You can also clean the inside of the machine by using a commercial grade dish machine detergent and increasing water temp if possible.
If the water smells stale, consult a local water expert for guidance in resolving
Aug 19, 2008 | Dishwashers
Refrigerators Logo
24 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
