Question about Brother DCP Office Equipment & Supplies
Diagnostic code 22 - DCP Brother Office Equipment & Supplies
How do I run diagnostic test
Washing Machine Diagnostic Test & Error Codes (Cabrio ...
? 1:29
https://www.youtube.com/watch?v=yoCTzbl4FPs
Nov 22, 2010 - Uploaded by applianceassistant
Washing Machine Diagnostic Test & Error Codes (Cabrio, Bravo, ..... What can i do? ... I tried to put it in ...
Fix and Diagnose Kenmore Oasis / Whirlpool Duet hE Washer
? 7:21
https://www.youtube.com/watch?v=8Z1JdsJYa14
Apr 24, 2011 - Uploaded by Alprazolam
Tried to do the diagnostic test and it still won't do anything. ... If the latter, and it won't run any diagnostics ...
How do you do a diagnostic test for a Whirlpool Cab
Dec 02, 2015 | Washing Machines
What do airbag flash codes 22, and 18 mean on a 2003 Toyota corolla?
list of airbag flash codes.
12=Low Battery Voltage
13=Air Bag Circuit Shorted to Ground
14=Primary Crash Sensor Circuit Shorted to Ground
21=Safing Sensor Not Mounted to Vehicle Properly
22=Safing Sensor Output Shorted to Battery Voltage
23=Safing Sensor Circuit Input Feed/Return Circuit Open
24=Safing Sensor Output Feed/Return Circuit Open
32 Driver Side Air Bag Circuit High Resistance or Open
33 Passenger Side Air Bag Circuit High Resistance or Open
34=Driver Side Air Bag Circuit Low Resistance or Shorted
35=Passenger Side Air Bag Circuit Low Resistance or Shorted
41=RH Primary Crash Sensor Feed/Return Circuit Open
42=LH Primary Crash Sensor Feed/Return Circuit Open
44=RH Primary Crash Sensor Not Mounted to Vehicle Properly
45=LH Primary Crash Sensor Not Mounted to Vehicle Properly
51=Air Bag Diagnostic Monitor Internal Thermal FuseFuse Blown Due to Intermittent Short to Ground
52=Backup Power SupplyVoltage Boost Fault
53=Primary Crash Sensor Circuits Resistance to Ground or Air Bag Diagnostic Fault
Aug 04, 2015 | 2003 Toyota Corolla
2013 r1 code 22 error
replace the sensor in the left snorquel
Fault code No. 22 Symptomicon1.png Air temperature sensor: open or short circuit detected.
Diagnostic code No. 05 Air temperature sensor
Orde
r
Item/components and probable
cause Check or maintenance job
Reinstatement
method
? Air temperature sensor coupler
? Main wire harness ECU coupler
? Check the coupler for any pins
that may have pulled out.
? Check the locking condition of
the coupler.
? If there is a malfunction, repair it
and connect the coupler
securelyicon1.png.
Reinstated
automatically if
a normal signal
is received.
2 Open or short circuit in wire harness. ? Repair or replace if there is an
open or short circuit.
? Between air temperature sensor
coupler and ECU coupler.
(Brown/White?Brown/White)
(Black/Blue?Black/Blue)
3 Defective air temperature sensor. ? Execute the diagnostic mode.
(Code No.05)
? Replace if defective.
Refer to "CHECKING THE
INTAKE AIR TEMPERATURE
SENSOR" on page 8-91.
May 13, 2014 | 2006 Yamaha YZF-R1
What is diagnostic code 22 for a 1994 Jeep Cherokee grand limited
That code is for the engine coolant temperature sensor. "...input above maximum acceptable voltage." I would try a new temp. sensor. If that doesn't fix it, you may need to have an engine scanner hooked up, and see what the sensor is sending to the computer, and go from there.
A bad coolant temp. sensor can cause hard starting like your symptoms.
Apr 25, 2014 | 1994 Jeep Grand Cherokee
I am getting diagnostic code 22
Error Code: 22
Description: Engine Coolant Temperature circuit malfunction.
Possible Causes:
- Wiring.
- Coolant Temperature sensor defective.
- ECM.
Apr 25, 2014 | 1993 Jeep Grand Cherokee
Code 22 subaru 1998
DIAGNOSTIC TROUBLE CODE 14 AND 22 (SET/COAST SWITCH, RESUME/ACCEL SWITCH, CANCEL SWITCH)
DIAGNOSIS:
Short circuit inside the SET/COAST SW and RESUME/ACCEL SW.
Feb 28, 2011 | 1998 Subaru Legacy
Hi, I have a 2007/8 Yamaha R1...............I changed the ECU unit and the clock is showing a code 22 error.................please assist me ASAP.....................!!!!!!!!!!!!!! Dave cell no: ...
Fault code No. 22 Symptom Air temperature sensor: open or short circuit detected.
Orde
r
Reinstatement
method
1 Connections
the coupler.
securely.
Reinstated
automatically if
a normal signal
is received.
(Code No.05)
thx to Mr Ravine.
Feb 12, 2011 | Yamaha YZF-R1 Motorcycles
SONY DCR TRV350 C31:23 and C31:22 flashing code
Hi Jeany,
Please see the detail below for the said error codes C31:23 & C31:22
According to the symptom and self diagnostic system the problem is in mechanical section (tape loading section) Therefore camera just need mechanical adjustment and will work fine again. This problem aries when the insertion of the cassette is improper or forced insertion.
Thanks for using fixya.
Jun 15, 2009 | Sony Handycam DCR-TRV240E Digital...
I have diagnostic codes of 22, 23, 24 for my 1995 Saturn Sl 1
well according to your codes that i looked up for you i think its safe to assume that your timing is off. i will paste the codes so you can see for your self. i hope this is what the codes actually look like.
P0022 "A" Camshaft Position - Timing Over-Retarded (Bank 2)
P0023 "B" Camshaft Position - Actuator Circuit (Bank 2) - See Trouble Code P0020
P0024 "B" Camshaft Position - Timing Over-Advanced or System Performance (Bank 2) - See Trouble Code P0021
P0025 "B" Camshaft Position - Timing Over-Retarded (Bank 2) - See Trouble Code P0022
Apr 29, 2009 | Saturn SL1 Cars & Trucks
Diagnostic code for '95 Saturn SL
My manual shows----- code 22 is throttle position sensor, and code 83 is low engine coolant.
Jan 22, 2009 | 1995 Saturn Sl
249 people viewed this question
CheckitRight
CheckitRight
James Cagle
James Cagle
Samyfam
Samyfam
