Question about Garden
Spark plugs for a briggs stratton 17.5 hp - Garden
jgwhomeequip
  • 1902 Answers
SOURCE: 31p777 18.5 hp briggs & stratton valve cover leak
Both can cause problems. It is recommend that you do not go on a grade more the 10% for your safety and the safety for others around. But if the valve cover is leaking this can lead to major problems if not repaired on a timely matter
Posted on Apr 29, 2009
  • 86 Answers
SOURCE: gas comes out of spark plug hole
You have a Float problem you also make have gas in oil.
Posted on May 12, 2009
  • 18 Answers
SOURCE: 18 HP Briggs and Stratton OHV Model 31M777 runs rough
Have you checked the choke? Sounds like it might be stuck closed or partly closed.
Posted on Jun 22, 2009
  • 10865 Answers
SOURCE: need head bolt torque for Brigges Stratton 18 Hp
210 to 230 inch pounds. Torque in a crisscross pattern upper left lower right upper right or left or right.
Posted on Jul 10, 2009
  • 133 Answers
SOURCE: 4 cycle, 5hp briggs and stratton, lawn mower
Try taking off the engine shroud and cleaning the magnets on the fly wheel. Also clean the two little prongs on the magneto. Also clean the end of the spark plug wire. I use fine sand paper or emery cloth.
Good luck and let me know if this helps.
thanks roundo4
Posted on Sep 06, 2009
Briggs and Stratton 17 HP Riding Mower
Hi Lawrence.
There should be a few more numbers/ letters to your model number. I added a link to a website for you to check out. Click the link or copy and paste it. Hope this helps.
https://www.repairclinic.com/Shop-For-Parts/a22b303d782009/Model-42A7072653E1-Briggs-Stratton-Small-Engine-Parts
May 30, 2017 | Briggs & Stratton Garden
Twin 2 17 hp briggs stratton
It's harder to spin that what is normal compression ?
it's supposed to be harder with the plugs in. that's what creates compression
Aug 22, 2013 | Garden
Remove spark plug try to turn over motor with rope. Won't turn motor seized, replace motor. Spray some WD40 in spark plug hole.
Jun 19, 2013 | Garden
18 hp briggs and stratton no spark
unplug oil senso still no spark un \plug shutoff wire to coil still no spark replace coil
Nov 15, 2012 | Briggs & Stratton Briggs Stratton Intek V...
Spark plug gap for a rc12yc on 22 hp engine
Gap setting for a Champion RC12YC spark plug is .030
Apr 15, 2012 | Briggs & Stratton Briggs Stratton Intek V...
Lawn mower won't start
to check for firing remove the spark plug insert it in the plug boot and pull the rope while watching to see if the plug sparks be carefull not to touch the plug electrode while pulling the rope or it will shock you. If you don't have a spark, try a different plug. If still no spark the coil could be bad.
Jun 25, 2010 | Briggs & Stratton Briggs Stratton Intek V...
Briggs and stratton runs good for 5 minutes then starts to smoke
My first thought is that the throttle lever is being pushed so far forward ( max RPM's ) that you are running the engine 1/2 or better choked
Look at the choke butterfly with the throttle in your normal run position it should be completely open
This may require and adjustment in the control rods or might be as simple as not pushing the throttle wide open
Apr 06, 2010 | Briggs & Stratton Briggs Stratton Intek V...
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
